08-19-2016, 10:19 AM
Real Name: Ivan
Real Name: Ivan
2001 abs module/booster leaking
i don't feel like taking this apart but is it an O ring on the side where the control box is? was driving and brake, trac off and abs lights came on. got under to look and fluid leaking down the lines. damn thing new is expensive and no one in my area has one. i need to replace asap.
2001 SR5,
thundercloud, tundra brake upgrade with 231's, 906's/billies rear, 5100's/stock coils on 4th groove front, ISR/deck plate mod, ford trans cooler mod, 99-00 grille swap, led conversion, 17" 2014 SR5 wheels wrapped with cooper AT3's, 265/70/17
08-19-2016, 01:13 PM
Real Name: Ivan
Real Name: Ivan
check engine came on and the speedo stopped working. is that part of it?
2001 SR5,
08-19-2016, 04:05 PM
Real Name: Ivan
Real Name: Ivan
need info on this. need to fix asap. looked at some info but didn't explain much. something about an abs control module to replace but no mention as to location. the master is leaking but i don't know if that will solve my issue.
2001 SR5,
08-19-2016, 04:30 PM
Here's a blown up view of the brake unit..
Hope it helps?!
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
08-19-2016, 06:23 PM
Real Name: Ivan
Real Name: Ivan
the master is leaking so that will get replaced. but i don't know if that caused the P0500.
2001 SR5,
08-21-2016, 02:00 PM
Real Name: Ivan
Real Name: Ivan
any replies? i read to replace the module, i've read to replace all the speed sensors on the wheels. is there not a sensor on the transmission as well?
2001 SR5,
08-21-2016, 02:04 PM
Real Name: Ivan
Real Name: Ivan
is there a speed sensor in the tranny causing the speedo to not work?
2001 SR5,
08-22-2016, 10:00 AM
the speedometer gets its signal from the tranny speed sensor.
01-11-2019, 02:13 PM
What did you do to fix this?
01-28-2019, 12:01 AM
Real Name: Ivan
Real Name: Ivan
replaced with low mileage used one.
2001 SR5,
