Originally Posted by csp
Actually the calipers are the same within any year. 78 and older are different than 79 and newer, however, with the newer ones having metric banjo bolts.
Where did you take it for the shakedown run? Didn't really need 4WD I take it?
I just took it up to Rainbow Falls in Divide, CO. Nope, didn't really need 4WD, ha ha. It was just to make sure driveshaft angles were OK (I was concerned about the angle on the front, pretty steep), and just to make sure everything else was okay too. Hadn't tested the front axle since swapping everything over like the gears, axle joints, hubs. I wanted to make sure that if something broke a tow truck could get up in there to get me out.
I wish I had pics and video of the last run I took it on. Truck did amazing but that's when it bent my sway bar links.
