I was able to hit up a few yards yesterday with my wife (and she had a lot of fun! She actually said that this was more fun than shopping at the mall! I really scored with her!)
Found a few Tundras, but all had the brakes completely removed already; most even had the front axle completely gone too. Is there an axle swap that I missed somewhere? Haha.
No Sequoias at all.
I DID find a leopard print bra in the front seat of an Explorer though...most likely from the distracting hooker that caused the crash...
Originally Posted by shootmymime
dont listen to these naysayers. i have bought many from pull yards my pair, and 2 other pair (sold them) all in from the start i have my TBU in it $100 total. super easy. cut the brake lines, and use the 19mm IIRC to remove the bolts and it pulls right off.
That was my next more serious question with this; the socket size, which you answered. I had read 17mm, and maybe 19mm, depending on the vehicle, and I only have a 17mm. So i'll be getting a 19mm, just in case for when I go again in a few days.
Originally Posted by Scramble
I would not use calipers from a junkyard. Brakes are pretty important. For a few dollars more you could get rebuilds from Napa using OEM housings. They'll be nice & shiny & you could paint them a pretty color...
As for the concerns with the 'used' brakes, I'm really not too concerned. I've almost only ever heard of brake rebuilds on forums like this, where the members are the loudest representatives of a group of owners with 0 problems at all.
My dad has worked at a Firestone off and on for almost the past 30 years, and he said that rebuilds are very few and far in between, and almost NEVER Toyotas.
I bought my 4runner with warped rotors a year and 23k miles ago and STILL haven't changed them, so I'm used to bad brakes.
Obviously I'll visually inspect them first, though, and I'll be sure to make them nice and pretty too.
Originally Posted by Yoter
If you do end up getting them at PNP, Just in case you don't already know not all Tundras had the same brakes some had smaller 199mm Rotors and the larger brakes are the 13WL Calipers. The Calipers will "13WL" cast into the side of the caliper.
I have the Limited with the 17'' 5 Spoke wheels, so either size of the Tundra should fit fine with no filing, unless I'm mistaken. I'd like the 231mm, but the 199mm are still better that stock T4R
