Old 12-14-2017, 10:29 PM #31
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Originally Posted by kfriede View Post
Can anyone input on how these hold up over time? With weight, rust, etc?
Over time, will take time... The first units are still in transit. That said, Alex and team have been using them for some time now I believe...
And, since they are aluminum, rust will not be a factor. Hardware I believe is stainless steel.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 12-14-2017, 10:34 PM #32
kfriede kfriede is offline
kfriede is on a distinguished road
That's a good point, I forgot that they're probably aluminum. Thanks, might me next on my mod list.
kfriede is offline   Reply With QuoteReply With Quote
Old 12-14-2017, 10:47 PM #33
TonyB66's Avatar
TonyB66's Avatar
Full length steel racks are like 80 pounds, this one, less than 40.
A neat little tidbit... I recently removed the five cross pieces on the stock rack, leaving just the rails. This rack I believe mounts to those factory rails. Those removed cross pieces are about 10 pounds (9.8 lbs). So, the actual weight delta for this rack is less than 30 pounds as compared to stock.
Old 12-14-2017, 11:49 PM #34
I do like the low-profile look anyways. That's a nice bonus!
Old 12-27-2017, 04:56 PM #35
TmAnBuIcK TmAnBuIcK is offline
Real Name: Trevor Dean Gregory Hunt
TmAnBuIcK is on a distinguished road
I've got a 5th gen limited with stock rails and no crossbars. Will/How will the curt mount up?
TmAnBuIcK is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 06:07 PM #36
TonyB66's Avatar
TonyB66's Avatar
Trevor, I have no idea on the 5th gens.
Old 02-13-2018, 05:52 AM #37
drtyjerz47 drtyjerz47 is offline
drtyjerz47 is on a distinguished road
[QUOTE=Toy2play;2453380]I've received a few comments on my rack I built out of the Curt Rack that you purchase on Amazon for fairly cheap.
Old thread, I know, hopefully you can still help. Would I still need those landing legs you put on there to run 1 extension.
Its going on a 5th gen and I don't want to run 2 ext. Because of the sun roof
This is the most budget friendly set up that doesn't have a 6" high basket
[B] 2004 Sport edition V8 Natty white-
Sold: 1999 T4R Limited Imperial Jade mica, 2017 T4R SR5P magnetic gray metallic
drtyjerz47 is offline   Reply With QuoteReply With Quote
Old 02-13-2018, 01:13 PM #38
Nooga_Rock's Avatar
Nooga_Rock Nooga_Rock is offline
Nooga_Rock is on a distinguished road
Nooga_Rock's Avatar
Can you post some pics of this? I think id prefer to do only one or no extensions to avoid drilling a hole in the roof and being able to mount on factory rail would be great.
Nooga_Rock is offline   Reply With QuoteReply With Quote
Old 02-13-2018, 03:32 PM #39
TonyB66's Avatar
TonyB66's Avatar
I'd post a picture if I had one.
The rack cross pieces I was referring to are everything on the stock rack that traverses from one side to the other (left / right). What's left are two "rails" or "channels" running front to back on each side... Hopefully that helps a little.
Old 02-13-2018, 05:19 PM #40
Nooga_Rock's Avatar
Nooga_Rock's Avatar
Okay gotcha. Some people earlier in the thread mentioned that the rack is a little bit too wide and doesn't sit level. Was just wondering if you figured out another way.
Old 02-13-2018, 09:31 PM #41
Toy2play Toy2play is offline
Toy2play will become famous soon enough
[QUOTE=drtyjerz47;2909390]
My sister runs this rack on her 5th gen with 1 extention just fine. Mounts to the stock cross members. You dont need to make anything to get it to mount. Everything is included. Just need to buy the rack and 1 extention.
97 Charged, lifted, armored, geared, locked SR5.
Toy2play is offline   Reply With QuoteReply With Quote
Old 07-30-2018, 09:03 AM #42
Silver Supra's Avatar
Silver Supra Silver Supra is offline
Silver Supra will become famous soon enough Silver Supra will become famous soon enough
I just finished installing this on my 3rd gen and am really happy with the results. For the investment you really can't beat this setup. Thanks again @Toy2play for sharing this!
Here are some pics...
Silver Supra is offline   Reply With QuoteReply With Quote
Old 07-30-2018, 05:03 PM #43
Looks great! The rack helps a lot during our 4 adults in the runner camping. Lots of useful space. Glad i could help out.
Edit: super jealous of that lift in your garage!
Old 07-31-2018, 08:59 PM #44
ivopivo ivopivo is offline
ivopivo is on a distinguished road
What did you use as the support? Looks like a long L bracket welded/bolted to the aluminum tube/channel? I have been trying to figure out how to do this best and had the same/similar thoughts. I'm thinking to use the aluminum square tube as the main support and bolt that along with an angle/L to the roof. Then bolt the rack into the angle/L from the side (just like your photos show) so that I can 1. remove it easier and 2. maybe even fab some cross members in case I want to remove the rack and pop those in place at exact bolt locations for rack. This would be to maybe carry a canoe, etc. where I need only a flat roof.
either way, very interested in what exactly you did and why.
ivopivo is offline   Reply With QuoteReply With Quote
Old 07-31-2018, 09:16 PM #45
Also, what gauge/thickness aluminum tube are you guys using?
cheap rack , curt rack , full length rack , roof rack
Full-Length Roof Rack askjiva 4th Gen T4Rs 26 12-20-2019 04:44 PM
Diy: Oem style full length roof rack Freb_mc 3rd gen T4Rs 17 04-08-2019 05:25 PM
FS Full Length Roof Rack for 3rd Gen , late 2nd drabbits 3rd gen T4Rs 99 12-26-2018 03:19 PM
WTB 3rd gen full length WMW roof rack jstim Want to Buy/Trade 0 08-13-2016 08:19 PM
FULL LENGTH 3rd Gen Roof Rack Whitson Metalworks For Sale: T4R Items 16 10-06-2012 05:45 AM
