07-31-2018, 09:43 PM
#46
Originally Posted by ivopivo
What did you use as the support? Looks like a long L bracket welded/bolted to the aluminum tube/channel? I have been trying to figure out how to do this best and had the same/similar thoughts. I'm thinking to use the aluminum square tube as the main support and bolt that along with an angle/L to the roof. Then bolt the rack into the angle/L from the side (just like your photos show) so that I can 1. remove it easier and 2. maybe even fab some cross members in case I want to remove the rack and pop those in place at exact bolt locations for rack. This would be to maybe carry a canoe, etc. where I need only a flat roof.
either way, very interested in what exactly you did and why.
I used the 1" square tubing like the OP, and added an aluminum L bracket on top of it. I used longer bolts to go thru both the L bracket and the square tubing, no welding, but may do that in the future since I have a TIG welder.
I like the extra lateral stability the L bracket provides and I used the wing nuts to make removal quicker/easier. This way I can leave the supports on and take the rack off. I was thinking of maybe putting some cross bars up for mt. bikes, or whatever.
It's not hard, but a little tedious when it comes to lining up all the mounting bolts. By the way I used angled head bolts and countersunk the holes so they are flush.
Hope that helps. Let me know if you want to know what hardware to get, I went to Ace hardware about a hundred times figuring it all out and would happily help you avoid that!
07-31-2018, 10:14 PM
#47
If you want to list some hardware that would be great. I think we had the same idea in mind, you just made it happen .
As for the 1" tubing.. I meant to ask what thickness aluminum did you guys use? I'm thinking of the 1/8" instead of 1/16", same for angle.
08-10-2018, 06:12 PM
#48
Can someone confirm the aluminum tube size/thickness? I assume it's the 1/8 but figured I'd ask what the others are doing. I'm hoping to have all this done by next weekend.
08-10-2018, 06:47 PM
#49
Here is what I used
I got it from Home Depot.
08-10-2018, 07:49 PM
#50
Real Name: T
Real Name: T
Me too, but a bit smaller...
I got a curt with the extension, but I should have done what you did and doubled down. I like what you did. After I repaint my 4Runner, I’ll have to extend it more.
I coated my rack in Rustoleums truck bed liner too for extra protection. This rack has way less rust issues than the Cabelas brand I had prior.
-T
Current project: ‘98 4Runner, stick shift, 4x4, 160k!
@over_the_rivers
08-21-2018, 11:11 PM
#51
I think i have 1/8 and it was a bit overkill.
Edit: confirmed its 1/8, i probably would have gone with 1/16 if i did it again.
97 Charged, lifted, armored, geared, locked SR5.
08-22-2018, 06:35 PM
#52
Overkill in what regard? I thought 1/8 was too thin haha.
08-23-2018, 01:28 AM
#53
I've had quite a bit of weight up there and the 1/8 thick tubing doesn't budge at all, I'm pretty sure 1/16 would be the similar. Your roof would probably collapse from the weight before anything happens to the tubing.
10-29-2018, 01:51 PM
#54
Toy2play, what light bar are you running on the front of your Curt rack?
10-29-2018, 09:48 PM
#55
Its a cheap no name from Amazon. In reality i dont use it a lot. The glare from the hood is kind of annoying for me so I use two hella 500's converted to HID and two flood lights that are near the front bumper for my offroad night excursions. I dont find myself on the trails at night much though.
10-30-2018, 10:23 AM
#56
Thanks for the reply. Do you recall what length bar it is? With the Curt rack listed at 37" wide, I'm guessing in the 30-32" range? This is exactly the type of light bar/mount system I'm looking for, if not the exact brand/model.
10-30-2018, 09:42 PM
#57
Went out and measured it, 31.5" across. I want to say they advertised it as a 32 inch, but i cant remember.
10-31-2018, 07:57 PM
#58
Real Name: Chris
Real Name: Chris
So i’ve had mine operational for almost 2 years now. It’s been on several extended trips loaded to the gills.
1.) weld it together instead of using the screws.
2.) paint the whole rack in rustoleum or similar. I sprayed on a layer of rust reformer followed by Rustoleum semigloss black.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
11-30-2018, 01:55 PM
#59
~$170 off brand curt rack
I got this today! Im going to see if it fits. Its off brand curt rack already extended 64”. And bout another extention
12-23-2018, 01:27 AM
#60
Nice I use the very same green boxes as you. Keeps the dust and water out, been using them for years. Rack looks great too.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
