08-26-2016, 10:12 AM
Location: Mall Crawlin @ 36.1911° N, 44.0092° E,37.7460° N, 119.5329° W
Oh shoot help ASAP!!!!
So I fired her up after the engine swap. Well I have a massive fuel Leake and thank god it didn't hit the headers and they were not that warm yet. This small fuel line is not hooked up on the back side of the intake. We're the hell dose she go and am I going to have to pull the lower plenum to plug this line in. Please help asap guys I'm not sure we're this stupid thing goes and it's just streaming fuel out of this hose. It's a small fuel hose!
Blue
0369
“Be polite, be professional, but have a plan to kill everybody you meet.”
Gen. James Mattis USMC
"AKA Mad Dog Mattis"
08-26-2016, 10:13 AM
I guess a picture would help out.
0369
08-26-2016, 10:14 AM
Blue
There fuel rails on each side have a in and return. Follow all these lines and see which one is not hooked up.
08-26-2016, 10:26 AM
I just found it. It's the one that's in the back center of the intake. That strait up scared the shit out of me fule just pouring out on the engine. I'm to tired of this kinda non sence this morning.
Blue
0369
08-26-2016, 10:29 AM
Real Name: Alex
Real Name: Alex
Blue
Glad you found it. That's the line that goes into the fuel pressure regulator, right?
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
08-26-2016, 10:43 AM
That's the line that goes into that brass looking one next to the fuel pressure reg. It comes strait up from the lower intake. It's a small little nipple really. Has a spring clamp on it. Righr buy the coolant temp sensor under all that gagle **** of wires also.
0369
08-26-2016, 10:46 AM
fuel pump test? check.
08-26-2016, 11:03 AM
Real Name: Alex
Real Name: Alex
You've got me scared.
I don't believe there should be a fuel line "nipple" coming out of the lower intake. Should only be to the banjo bolt fitting (supply) on the passenger's side, and from the fuel pressure regulator (return) on the driver's side. From the fuel pressure regulator there's a section of about 5" of hose, then a hardline, then another section of hose.
There are a couple vacuum nipples, and a couple coolant nipples...
Can you take a better picture showing a larger view of the area?
08-26-2016, 11:10 AM
Is he pumping fuel into a vacuum line connector?
08-26-2016, 11:23 AM
Real Name: Alex
Real Name: Alex
Sure hope not... Kinda sounds like it though unless I am TOTALLY forgetting about a fuel line back there.
08-26-2016, 11:27 AM
Real Name: Jerod
Real Name: Jerod
Pretty sure he's got the right one, there is a nipple-looking line coming from the FPR. It also comes out from the lower intake.
If he has it wrong it's not like he's going anywhere lol.
08-26-2016, 12:48 PM
Hey give me break I have been up for 30 something hours. When I primed the fuel system after getting oil pressure up there was not enouph in the system yet until it ran a minute. Scared the shit out of me.
Let me try. I got it back on and just used the factory spring clamp again no leaks anymore.
Yeah that hose attaches to the lower intake. See attached pic of my extra intake.
0369
08-26-2016, 01:05 PM
Real Name: Alex
Real Name: Alex
pretty sure that's a vaccum or coolant port, Amigo. Not a good spot to store fuel.
08-26-2016, 01:16 PM
I'm going to go through each line before I do anything else.
Blue
0369
