06-23-2020, 01:30 PM
#151
Originally Posted by TheShowtime
Hey Charlie, how many miles does she have on her now?
It is just short of 294k miles right now. Nearly fully broken in...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-30-2020, 07:37 PM
#152
Took a day trip up to the desert this past weekend. Some friends were up there testing and tuning their rally car ('93 Impreza with built 2.5L NA motor) and figured it would be a good chance to get up there. Having an RV to meet at (with AC and a flush toilet...) is always a nice thing. Took a 4WD trip with a friend who is new(er) to 4-wheeling than me (still stock '19 Tacoma TRD) and a Jeep. Nothing crazy, just some steep hills and a good view at the end of the trail:
I took our 3-year old daughter (she hadn't been in a car for 3 or 4 months before this trip!) to see how she liked things. She did surprisingly well, dealing with 100*F+ temps and being stuck in a car seat for so long. She said she wants to go back, so I'll take that as a win...
Among lessons learned... I need install my trans cooler! Then again, the temps were pretty high, though luckily not full summer (say, 110*F+) hot. The trans was basically 190-220*F the whole time, despite using 4lo extensively. Funny thing though, is the hottest trans temps were on the way home on the freeway when the torque converter would unlock...
11-18-2020, 06:57 PM
#153
Real Name: Levi
Real Name: Levi
Charlie, I just read through most of this thread (again). After a ridiculously long time trying to educate myself, I'm finally almost ready to start a much-needed refresh of my truck. I think our goals are quite similar: comfortable on-road manners but good bang-for-your-buck off-road capability. There are two specific aspects of your build that I’m trying to wrap my head around:
1. Your choice to use the ’99 2WD front springs. It seems to me that the vast majority of people who put on aftermarket skids and bumpers and 5100s go with taller and firmer springs. Since you had to use a top plate spacer with the ’99 2WD springs, do you still think they were a better choice than the ’97 4WD springs or something like 880s or 881s? I’m planning to get either 5100s or Dobinsons’ GS59-222s up front. I was planning to get either 880s or similar Dobinsons front springs as well, but now I’m wondering if there’s any reason to not just use my existing ’97 4WD springs (which don’t seem to have sagged any despite being 23+ years old). I’ll have stock UCAs and 265/75/16 tires (same diameter as your KO2s). I’d like to maximize my front travel for the 5100s and stock UCAs and if my existing ’97 4WD springs would likely be indistinguishable from new and slightly taller ones I’ll spend the $ elsewhere! FWIW I’ll probably get aftermarket skids but stick with the existing OEM bumpers. I'll have 906s or similar Dobinsons springs in the back with 5100s or similar Dobinsons shocks.
2. Your choice to get the Addco sway bars. It doesn’t seem like too many people use them, and $500 for both front and rear bars isn’t cheap. Were you able to get yours for a good price, or did you just expect the increased on-road stability to be worth it? In hindsight, do you think they were money well-spent?
Really appreciate your time and expertise!
Levi
Originally Posted by phattyduck
And the fun part... Suspension time! I have had a set of '14 4Runner springs for at least a year sitting in the garage, along with some Bilstein 5100's for a few months, just sitting there taunting me...
First, I found what I think is the cause of the clunk/pop in the front that I was getting recently:
Disconnect your Addco front bar if you go wheeling...
So, let's get on with it... For the front, my goal is/was to get as much out of the stock front arms as possible. I took some extra time to do this with the front. I figure (and I could be wrong!) that I should go with the softest front springs possible, which ended up being my stock front ('99 2WD springs), maybe. Some measurements:
'97 4WD springs: 16mm wire, 9 wraps
'14 4WD springs: 17mm wire, 9 wraps
'99 2WD springs: 16mm wire, 8 wraps
I didn't get free-length measurements, but probably should have. The 2WD springs barely have to be compressed to fit in the shocks, so I figured they would be more 'progressive' because they aren't pre-loaded as much. I had a couple different top plate spacers (1/4" and 3/8") to mix and match to get the extended length of the shocks to match the max droop of the upper arm (stock, droop is limited by the upper ball joint without the shock in place).
Turns out, with 4Runner 5100's (and the 4600's they replaced) that a 3/8" top plate spacer is all you can fit before the upper ball joint is the limiting factor. The shocks are about 1/4" shorter than full droop, so that pretty much maxes that out. I checked full compression of the shocks and the shock shaft has a little less than 1/2" compression when the truck weight is on the bump stop with no springs:
So, with upper arms, you might be able to get another 1/2" to 3/4" of wheel travel before shock damage occurs with 'stock' length shocks. As it stands, hub center to wheel well measurements after all was said and done:
Full extension: 25.25"
Full compression: 16.75"
At ride height: 21.25"
I only 'lifted' the front a little over an inch from stock. That is a 3/8" top plate spacer and the 5100's on the second perch and using springs meant for a 2WD 4Runner. Out of the 8.5" of travel available, I currently have 4" of droop and 4.5" of compression. I was a bit surprised when I first measured the new ride height (~22"), but I realized I forgot to put my front armor back on for that measurement. Back on, it dropped that much!
1997 3.4L 4WD auto SR5, nearly 200k miles, pretty much all stock
11-18-2020, 08:25 PM
#154
Levi
I'll do my best to answer...
1. For best front articulation / use of the available travel, you want the front to be as soft as you can without regularly bottoming out. Well, that's my theory, at least... Take a look at any of the 'flex' pictures out there of 4Runners, and you will see that the rear does most of the work, which isn't ideal. I didn't want too much of a lift with stock arms/geometry in the front, then you just lose a bunch of droop travel. My 4Runner is definitely 'undersprung' in the front, but it isn't horrible on road (just a bit of float). No issues with bottoming or anything like that. I might change out to the '97 4WD springs if/when I get a winch up front. I haven't tried other spring options though, so don't take my word as gospel.
2. I got the Addco bars used for a good price. The on-road performance change is very noticeable. I don't think its worth buying them new unless you are going to stay on road only. Here's a bit of swaybar info you may not have seen: Toyota 4Runner Handling Modifications Addco Sway Roll Bars I don't get off road all that often, and when I do, the front bar gets disconnected. I would seriously consider going back to the stock rear bar if I was going to spend significant time off road.
02-08-2021, 02:23 PM
#155
Had plenty of adventure/hassle installing a trans cooler over the past week or so. I decided to go a bit of an unusual route with the cooler, and created plenty of challenges along the way. In the end, I think the result is worth it, though I need a lot more testing to know the performance.
I went with a TruCool LPD4921, which is basically the width of the radiator:
To get it to fit between the hood latch support and the radiator, I had to space the AC condenser back ~1/2". For the top, I made new brackets out of some aluminum:
On the bottom, I reversed the side of the condenser bracket that the lower mounts bolt to (you have to reverse the bolt direction and slot the bracket to fit it all together):
I also had to cut off the unused tab on the condenser on the drivers side to be able to mount the cooler close enough to the condenser for everything to fit. Sadly, I first tried to bend the tab - which broke the condenser. So, ~$100 in parts later (new condenser, drier, R134a, etc.), I had to re-modify the new condenser and install it...
I was able to bolt in the trans cooler on all 4 corners fairly easily with the strapping included with the cooler:
I drilled new holes in the core support and fit rubber bushings that tightly fit the hose and holes in the panel to pass the hoses through to the engine bay:
Into the bay, below the battery:
The hoses are strapped to the lower fan shroud removable panel so that the shroud can still easily be removed for engine maintenance and those hoses will have minimal movement between the engine/body/frame movements.
I did not bypass the radiator trans cooler, as the radiator is very new. I did, however, install a thermostat for the whole system to avoid over cooling the trans fluid (and help it heat up faster in the mornings).
As of now, I haven't even driven the 4Runner since the install (just idled while refilling the AC system). I need to drive it, warm it fully and add trans fluid still (and put on the front skid plate). Working from home means not too much driving these days. I'll report how things work after a few drives. Stress testing will come later when I can get off road and/or summer really hits.
02-13-2021, 03:06 PM
#156
thanks a big ol' cooler! good to see something other than your typical B&M. a little variety is good to see.
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
05-10-2021, 05:40 PM
#157
And now she's finally fully broken in!
(and quite dusty)
09-03-2021, 11:55 PM
#158
Did you ever get the soft brake pedal fixed? I own a 2005 tundra and had some brake issues a few years ago. Turns out I needed to adjust the rear shoes manually. It seems like 3/4 of the pedal travel was used up in applying the rears and once they applied to a certain pressure, the fronts would apply along with the rears for the last 1/4 of pedal travel. Was pretty sketchy for a while until I figured it out.
09-07-2021, 06:29 PM
#159
Yeah, an ABS actuation and another bleeding session and things are pretty good. I'll probably do it again to see if I can get that last little bit of performance out of it.
I know the rear brake adjustment issue - that has long been fixed. If the rear parts are working (not seized), it should stay in adjustment if you just use the parking brake regularly.
01-31-2022, 07:55 PM
#160
Figured I should do some updates.
I added flat mud flaps to reduce a bit of the mud on the doors:
I also got a Sherpa Matterhorn rack and got it installed over the weekend. I never liked the idea of the pressure feet at the front and I kept the roof rails from my 4x4 swap parts truck... Which means, extended rails! While I was at it, I removed, cleaned and painted the old and a new rail sections and did a rare clay and wax of the roof (sorry, not going to polish the roof):
After checking it out, I realized that rivnuts would stick up above the roof and lift the rails up, which wouldn't work. Instead, I used the same rivnuts with a couple washers, then a fender washer under the roof. The support under the roof is about 1" diameter to reduce the chance of pull-out. They are siliconed under the roof skin. (if they fall off when someday if I need to remove the tracks, it is easy to drop the headliner a bit to fix it) The added front section of track is aligned with an insert that I made between the two and a flat bolt-on plate you can see on the top where they meet.
The last bit of the puzzle is bending the front feet mounts a 5-10* to match the bracket angles to the roof rail and track and a couple M6 stainless bolts from my stash:
Final install, with a bit of Toyota Ricing, errr... Racing strips:
11-02-2022, 05:08 PM
#161
official vendor
official vendor
Charlie, do you have any photos of drilling/installing the rivnuts for this rack? I'm contemplating the same rack, and I like the idea of extending the OEM rails instead of using the bumpers.
11-02-2022, 08:15 PM
#162
I'm sure its a horror show under there...
The widest washer is a 3/8" stainless fender washer, which is what allowed the top of the rivnut to sit flush with the roof sheet metal. From there, it was just a pyramid of washers to spread the load as much as reasonable.
If I had planned ahead and had the material, the right way to do it is with a flat bar drilled and tapped to match the holes in the track on the outside of the roof. On the first installation, silicone it up there and it should stay if you need to remove the rail later. I can't remember if there are ribs in the way though - and if you have a sunroof, it gets more complicated.
11-02-2022, 09:09 PM
#163
official vendor
official vendor
Sounds like I better have a look at in the junkyard, since I do have a sunroof... Just so I know what to expect.
11-07-2022, 01:17 AM
#164
Looking good Charlie!
EXPERIENCE AMAZING
Toyota & Lexus Connoisseur
Current: 2020 USC10, 2002 VZN185
Previous: 2004, 2005, 2003 - JCE10, 2007 GRS191, 2009 USE20, 2011 GSE31, 2015 GRL10, 1994 UCF10
11-07-2022, 01:25 PM
#165
Let me know if you ever come back to visit SoCal!
