Old 09-15-2006, 11:42 AM #1
Orion Orion is offline
Orion is an unknown quantity at this point
Greasing driveshafts?
Could you use this product on the driveshafts to reduce or eliminate that annoying clunk? I plan to pump some grease into the u-joint, double-cardans, and slip yokes when I get a chance.
Redline CV-2 grease
http://www.redlineoil.com/products_c...ubCategoryID=8
What brands of grease do you all use? I believe the Redline CV-2 is a synthetic moly based nlgi2 but I haven't been able to locate any synthetic lithium based product yet. Can I mix synthetic with conventional stock grease? I presume whatever's in the driveshafts now is probably just conventional.
So to summarize:
u joints and slip yokes - lithium base grease
double cardan joint - moly based grease
is this correct?
Orion is offline   Reply With QuoteReply With Quote
Old 09-15-2006, 06:27 PM #2
MARSHALLMAY's Avatar
MARSHALLMAY MARSHALLMAY is offline
MARSHALLMAY is an unknown quantity at this point
if you regularly grease your fittings, using anything other than regular grease is a waste of money.
WE are the people bred, raised and nurtured to maturation to live life in the pursuit of acquiring status-ensuring product in a never ending pilgrimage to find value in themselves through the indulgence of materialism...
ohyea, 98 4x4 ltd
MARSHALLMAY is offline   Reply With QuoteReply With Quote
Propeller Shaft Greasing V8 4WD 2004 hyperthread 4th Gen T4Rs 15 12-13-2011 11:01 PM
Propeller Shaft greasing Frenchie Maintenance/Detailing 6 11-10-2008 10:52 PM
Problem greasing u-joints toy4x4boy Maintenance/Detailing 10 12-12-2006 08:49 PM
Greasing the Propeller Shaft liquidvw 4th Gen T4Rs 5 09-25-2006 08:29 AM
Greasing U-joints? spooner Maintenance/Detailing 9 02-29-2004 05:56 PM
