swing out the carrier and look at the back of each hinge. you'll see a small hole and that is where you grease the pins. no need to remove the plastic covers.
EDIT: alternatively, you can put several drop drops of thin oil at the top of each hinge and swing the carrier in-out repeatedly until the hinges become lubricated.
btw, the plastic covers are removable but become brittle after some years so be careful when removing them.
Originally Posted by RunnerLimited
I was thinking of using white lithium grease, but should i just spray at the joints and swing it open and close till it starts getting easier to swing? I heard the plastic caps are removable i was thinking of removing it and spray a $hit load in there. I didnt do this retrofit so im not sure if it is removable LOL
