Originally Posted by AssBurns
Also do we know compressed and extended lengths? Will the spindle hit the coils at full droop?
When I first installed the coils I still had the OEM UCA in place and at full droop the spindle/arm were very very close to the coil spring. I would say if you plan to run stock height on them you'll be fine, but if you are lifting at all get arms to be able to correct alignment and get correct geometry. Chas of MRT may have a suggestion as well and maybe the access to those other measurements from Bilstein
