10-04-2016, 04:54 AM
HELP! '01 4runner VSC Trac and VSC Off Light
Like the title says. Got an 01 4runner with the vsc lights on. what causes it and how do I go about fixing it. I've googled it and found some people saying that it could be from a gas cap to mass air flow sensor to cat coverters. I'm lost. anyone with some advice.
10-04-2016, 09:19 AM
Is your check engine light on also? Get a code reader and check for codes.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
10-04-2016, 09:42 AM
official vendor
official vendor
Those lights were on when I bought my 01 four years ago. I replaced the gas cap, and lights have been off since. Not saying that'll help your cause, but it's cheap. Also, do NOT get a cheap gas cap or generic one. Go OEM on this since it'll last a lot longer.
10-04-2016, 10:11 AM
Did you have the check engine on as well?
I have all 3 on for the last month, hoping it being the cc sensor.
Its even better if its the gas cap
10-04-2016, 10:46 AM
Agreed. Getting a scanner hooked up to check for codes would be a good starting point.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
10-04-2016, 11:19 AM
official vendor
official vendor
I had code P0440 & P0442 at that time.
10-04-2016, 12:31 PM
I had the P0440 show up alone back in May and a new gas cap seemed to have resolved that code. About a month later I got a P0446 code. Haven't had the time to fix it yet but from researching it and looking at the fsm, looks like I need to check out the charcoal canister & charcoal canister components (vsv valve, etc.) for damage and the associated hoses for leaks. Will also examine the gas tank filler neck.
10-04-2016, 12:59 PM
official vendor
official vendor
I'm getting P0446 around the last 1/4 tank of gas on almost every tank. Once I fill up it goes away, and comes back on when it gets near empty. I'm going to be dropping the tank anyways for some frame work. I might as well replace the filler neck while I'm at it.
10-04-2016, 02:26 PM
it threw a p01135 code for a/f sensor heater circuit malfunction. I replaced both the a/f sensor and downstream sensor. CEL still came back. I haven't had a chance to scan it again. I'm curious to know how the a/f sensor plays a role in vehicle stability control. I would imagine bad wheel sensors would cause the VSC lights to illuminate but i dont think thats the case from what i've been reading.
10-04-2016, 03:30 PM
No role at all. Toyota just linked all the warning lights to up the visibility of the CEL. I guess folks tended to ignore just the CEL. Glad I don't have that.
My Backyard Frame Swap
02-26-2021, 01:47 AM
Real Name: John
Real Name: John
Sorry to re-kick this thread but I need some help...my buddy has an 01 SR5 2WD with a 5VZFE. The VSC and TRAC OFF lights keep coming on every time he starts the truck. They come on as soon as the truck is put in gear and the tires start rolling. He just replaced the dash lights with LES bulbs and is wondering if that is part of the problem. We hooked it up to my OBD2 reader and it is not throwing any codes??? Throwing is for a loop and any help would be appreciated! Thanks
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
