Old 10-05-2016, 10:51 AM #1
ranchdog ranchdog is offline
ranchdog is on a distinguished road
Any reasons why I should not buy a 1998 5 speed with eLocker
I think I have a lead on a 1998 4Runner with 5 Speed manual trans with the eLocker option on it. ~160k Miles looks clean but I have to check for rust.
Any reasons why its not a good option, I will only do minimal upgrades for hunting with where its muddy. No ice or rock crawling.
Thanks for any feedback
Rnachdog
ranchdog is offline   Reply With QuoteReply With Quote
Old 10-05-2016, 10:56 AM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
5 SPD and E-locker? That's hard to come by. You could wait a long time to find another with both options.
If it looks in good condition I would grab it.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 10-05-2016, 11:54 AM #3
Any thoughts from anyone else ??
Old 10-05-2016, 12:01 PM #4
Denis_Ruso's Avatar
Denis_Ruso Denis_Ruso is offline
Denis_Ruso is on a distinguished road
Denis_Ruso's Avatar
Buy it!
Insta: @Ruso_Denis
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
1997 Toyota 4Runner Limited 4WD, Rear Diff Lock, 3" Toytec Lift, Diff Drop, CBI Hybrid Front Armor, ARB Air Compressor, HID Spotlights, 32" Tires
Denis_Ruso is offline   Reply With QuoteReply With Quote
Old 10-05-2016, 12:01 PM #5
Bijan's Avatar
Bijan Bijan is offline
Bijan is on a distinguished road
Bijan's Avatar
E lockers are over rated.
If you're not doing terrain where you know youre gona get stuck, there's no need for em in my opinion.
Bijan is offline   Reply With QuoteReply With Quote
Old 10-05-2016, 12:03 PM #6
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
Yes, buy it if it's in good condition. The only downside is that it doesn't have the 99+ upgrades but you could add them later.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 10-05-2016, 12:09 PM #7
What are the desired upgrades ??
Thanks Ranchdog
Old 10-05-2016, 12:19 PM #8
We have the nasty clay mud around here that is like grease. I kid you not. During hunting season which is our rainy season. I have an F250 and its so heavy 4WD just almost sinks it in this greasy clay.
Ranchdog
Old 10-05-2016, 12:22 PM #9
ThorInc ThorInc is offline
ThorInc is on a distinguished road
Here is a decent summary thread & I am also sure that there is one on this site as well:
https://www.4runners.com/threads/3rd...30/#post-15774
No pink milkshake issues with a 5 speed transmission so frame rust, rockers, fenders, LBJs, etc. are all things to inspect. It will serve you well for what you need it, given checking for the above items. Prices are area dependent.
1997 T4R SR5 3.4L 5 speed with factory e-locker bought new with almost 1km on it
ThorInc is offline   Reply With QuoteReply With Quote
Old 10-05-2016, 12:28 PM #10
Sean K.'s Avatar
Sean K. Sean K. is offline
Sean K. is on a distinguished road
Sean K.'s Avatar
Personally, I think it's the best factory ($265-305) option one could possibly get in a 4wd. With it....you at least have 3 wheels with power.
Sean K. is offline   Reply With QuoteReply With Quote
Old 10-05-2016, 12:31 PM #11
Sean K.'s Avatar
Sean K.'s Avatar
To the OP, I have a '99 5spd. I personally prefer it as it feels like it has a lot more power on acceleration than the auto.
If it's in decent shape at a good price, buy it....."don't think about it, buy it".
https://www.youtube.com/watch?v=k4rPIuK8RaY
Old 10-05-2016, 12:34 PM #12
Wouldn't you have 4 wheels under power in 4LO, with E-lock on ? like both front wheels turning and both back wheels turning ? I have no idea so this is more a question..
Thanks, RD
Old 10-05-2016, 12:39 PM #13
Sean K.'s Avatar
Sean K.'s Avatar
Originally Posted by ranchdog View Post
wouldn't you have 4 wheels under power in 4LO, with E-lock on ? like both from wheels turning and both back wheels turning ? I have no idea so this is more a question..
Thanks, RD
Not in low traction situations where one front wheel has none.
4WD trucks aren't really driving all 4 wheels because the differential allows them to have more manageable highway manners so the wheels on the same axle can turn at different speeds while negotiating a corner.
When you add a rear locker and turn it on in the case of the elocker, both rear tires are driven at the same rate, regardless of traction or turning. It's effectively like a spool when engaged.
Which means....you have two tires driving in the rear, but up front, you may only have one if say the passenger side tire is in the air or is spinning helplessly in mud. In that case, you really have only 3 wheel drive, but the truth is, the one in the air that's spinning isn't doing you any good in terms of forward motion. What you then have to hope happens is the rear "pushes" the front forward enough for the front end to regain traction. The better solution is a front locker....then all 4 wheels will pull (with say an ARB for example and to simplify the discussion).
Old 10-05-2016, 12:46 PM #14
Ok, Thanks I have much to learn for I am Grasshopper
Ranchdog
Old 10-05-2016, 12:51 PM #15
Sean K.'s Avatar
Sean K.'s Avatar
Ranchdog
No biggie....I certainly don't know everything about 3rd Gens....and I've owned mine since new. We all gotta start somewhere. There's plenty more I need to learn as well.
FS 1998 4Runner SR5 3.4l 5-speed 4x4 190K Miles danthemanx07 For Sale: Vehicles 1 06-11-2016 05:30 PM
My 1998 Toyota 4Runner 5-Speed billyd 3rd gen T4Rs 6 04-29-2014 08:35 PM
**SOLD** 1998 Black/Tan 4Runner 5Sp, ELocker, 3.4l,Leather,Power,Keyless hkspwrsche Classifieds - buy & sell (no commercial ads please) 3 03-11-2010 03:52 PM
