Old 10-14-2016, 11:35 AM #1
Pemrick's Avatar
Pemrick Pemrick is offline
Pemrick is on a distinguished road
Pemrick's Avatar
Door handle removal help
So I'm getting ready to paint and I REALLY want to take the door handles out so I don't have to tape up around all the door seals and such. I got the front driver side out after yanking and pulling and cussing for about 30 mins. I went to do the rear driver side door and stopped dead in my tracks. I know there are suppose to be 2 bolts to hold in the handle but i can only see one. Where is the other bolt? Do i have to take the door striker out to access the bolt?
Im also lost for how all the do-dads come out of the rear hatch (i.e. wiper rest, wiper stud, license place holder, rear sprayer). It looks like there is a brace in the way of a lot and when i went to take the license place holder out i can't reach some of the clips. Anyone have any tips on how to get those out without breaking anything?? anything would be much appreciated!
'99 Runner. Manual. Limited. Daily driver+project.
Pemrick is offline   Reply With QuoteReply With Quote
Old 10-14-2016, 01:10 PM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I've only taken apart the rear hatch once and I also had to break stuff. Couldn't figure it out.
326WHP 347TQ
Old 10-14-2016, 03:22 PM #3
nissanh nissanh is offline
yes
Remove the plastic cover to access the 10 mm bolt that holds the outside door handle. You will see a small about a quarter sized sticker covering another bold
Old 10-14-2016, 04:10 PM #4
Pemrick's Avatar
Pemrick's Avatar
My front door had the sticker that covers the hole but my rear door doesn't have one. Just took it apart for the second time and still can't see anything other than going thro the door lock
Old 10-14-2016, 08:59 PM #5
I_bRAD I_bRAD is offline
I_bRAD is on a distinguished road
If you're talking about the plate bezel/handle assembly on the hatch, lower the rear window an inch and then unbolt the 4 bolts holding the window regulator in place- now you can move the whole thing out of the way and access your fasteners.
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
I_bRAD is offline   Reply With QuoteReply With Quote
Old 10-15-2016, 08:19 AM #6
Pemrick's Avatar
Pemrick's Avatar
What about the rear doors? Any experience with getting those handles out?
Old 10-15-2016, 09:33 AM #7
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
We take em out for paint jobs. If I recall, you have that little swivel plastic clip that needs to be rotated off the rod, and then just get the bolts out. It's easy once you figure it out, don't give up. It'll never look right if you don't remove em before spraying. That goes for rear hatch surround, antenna, etc.
Try this
absalom is offline   Reply With QuoteReply With Quote
Old 10-16-2016, 06:32 AM #8
Pemrick's Avatar
Pemrick's Avatar
Try this
I'm trying to figure out where the 2nd bolt is on the rear doors. I know how to get the handles out I just can't seem to find the second bolt. And I'm sure it's behind the latch on the door. Is there an access hole somewhere I just over looked or do I have to more the latch to get to the bolt
Old 10-16-2016, 10:35 AM #9
absalom's Avatar
Real Name: Jordan
absalom's Avatar
Real Name: Jordan
IIRC, the second bolt is hidden by a sticker behind the moisture barrier.
Old 10-16-2016, 11:18 AM #10
Rock_Rat's Avatar
Rock_Rat Rock_Rat is offline
Rock_Rat is on a distinguished road
Rock_Rat's Avatar
I can't help you on the other items, but the wiper stud you're referring to is the actual wiper motor exiting the rear lift gate. The stud goes through a rubber grommet. I can assure you, wiper motors are NOT fun to replace. It's attached with three shock-mounted bolts. Here'a pic.
EDIT: If you remove your interior panel from your lift gate, you may be able to see how the spray nozzle and wiper rest are attached. I think there's just one bolt where the strap is and the rest are the white push in style interior molding fasteners. Once disconnected, it slides UP away from the window track.
Door handle removal help-wiper-motor-exit-jpg
2001 Imperial Jade Gold Letter Sport Package - Original Owner
Rock_Rat is offline   Reply With QuoteReply With Quote
Old 10-16-2016, 01:51 PM #11
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
Pics of rear door handle removal: from a write-up for repairing the door lock module so scroll to find what parts you need....
habanero's 1996 4Runner Build-Up Thread - Page 74 - YotaTech Forums
Which includes how to access the bolts....
T30 torx to unbolt the door latch:
Unbolt outside door latch w/10mm here:
And here:
and more!
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Driver door handle won't open door anymore? Jason B 3rd gen T4Rs 19 07-08-2016 12:54 PM
help with door handle removal silversx 5th gen T4Rs 7 12-09-2015 10:34 PM
Door Handle Removal Stuck CAPS 4th Gen T4Rs 4 04-05-2013 12:11 AM
exterior door handle removal? mole177 4th Gen T4Rs 3 08-19-2009 06:01 AM
