Old 10-18-2016, 08:20 PM #1
4Running29 4Running29 is offline
4Running29 is on a distinguished road
EVAP code and CEL
I am a relatively new member so I hope I am posting this in the correct place and I will try to keep it as simple as possible.
I have a 2002 SR5, auto trans, 3.4L V6 with roughly 260,000KM (approx. 100,000 miles)
a few months ago I got a CEL and EVAP codes. I patched a hole in the fuel tank that was leaking fuel, got a new filler neck and fuel canister and the codes and CEL went away.
a couple weeks ago however I got the CEL and the EVAP codes again (don't have the exact code, sorry), however this time my mechanic is telling me its not what was fixed before but the problem now is the EGR. he said it wasn't an expensive fix and it was something I could do myself.
When I came here and did some searching I found out that the 4Runners didn't have an EGR after '96.
I have attached pictures of what my mechanic pointed to when he was explaining the issue.
MY QUESTIONS TO YOU ARE:
Since apparently it can't be called the EGR since they didnt have them post '96, what is the part that is shown in the pictures.
And could this part be the root of my EVAP and CEL problem??
any help is greatly appreciated and if you need any further info please ask!
EVAP code and CEL-img_1731-jpg  EVAP code and CEL-img_1732-jpg  EVAP code and CEL-img_1717-jpg
4Running29 is offline   Reply With QuoteReply With Quote
Old 10-18-2016, 10:41 PM #2
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
Looks like the TPS (throttle position sensor to me. As far as I know EGR's were only on 4 cyl 4runners. Not sure what years or if all years of 4 cyl.
Stay away from that mechanic. Go spend $40 on a code reader and find out the codes.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 10-19-2016, 03:14 AM #3
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
Possibly a bad VSV or a leaky charcoal canister. They can develop cracks. Mine cracked and threw a code. So I pulled it out and hit it with some rtv and I was back in action.
I think on a 2002 the charcoal canister is underneath by fuel tank. You need to find out what code(s) your getting though. Everything is just random speculation until then.
"Variety is for your mind, not your body " —OS
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 10-22-2016, 06:16 PM #4
Thank you guys for your input and suggestions. I am going to get the codes read and ill post them here so we have a better idea of what is actually going on to help determine the problem.
I really hope it's not related to the filler neck and canister I replaced a few months ago as that would mean I paid for work that really wasn't done!
Will reply shortly with the codes!
Old 10-22-2016, 07:55 PM #5
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Do you remember which codes you had?
Did you test your VSV using a multimeter or 9volt battery?
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 10-22-2016, 09:06 PM #6
Real Name: Woody
Real Name: Woody
P0446 is the main one I recall. As mentioned in this post about the EVAP monitor not wanting to run the test.
I think I hooked it up with a 9v.
http://www.toyota-4runner.org/2218784-post16.html
How I felt once I fixed it....
cel , evap , evap code
Evap code P0451 and the culprit Johnate0 Maintenance/Detailing 2 01-30-2023 03:10 PM
Evap CEL Code toyoman25 3rd gen T4Rs 2 12-13-2014 05:14 AM
01 with P0442 evap code 01thunder 3rd gen T4Rs 1 09-05-2013 11:11 AM
P0456 EVAP system error code Red 4th Gen T4Rs 3 11-15-2012 07:01 PM
Howdy all, and evap code question SR54Runner01 3rd gen T4Rs 5 11-13-2011 11:48 PM
