10-23-2016, 09:50 PM
Extended sway bar links
What r u guys doing to extend sway bar links. I've done alot of research on here and no one has a real good awnser or shows how they do it. Is there another toyota I can buy them off of and use or do u just extend factory ones?
Sent from my SM-G900T using Tapatalk
10-23-2016, 10:36 PM
Real Name: Levi
Real Name: Levi
96 SR5 5 speed, 4:88s with rear ARB , 255/85/R16s , some armor and lights
10-23-2016, 11:12 PM
Originally Posted by hounddogman
Do you remember what part numbers you used for the elbows ?
And the bushing kit is it just the stock 4Runner energy suspension kit??
I also pmd you.
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
10-23-2016, 11:16 PM
@ MStudt
makes extended disconnects front and rear. Contact him. You can run 2nd Gen 4runner rear links and are about 1" longer. I believe the fronts from 2nd gen may work also but never tried so dont quote me on that. Only other person making disconnects are wabfab. To me almost 2 months to get my fronts from them and they are known for bad customer service.
10-23-2016, 11:50 PM
Built my own. Used the generic 4 inch kit from Autozone and done 1200lb working load galvanized eye bolts from Lowes. Worked great, handles great, cost me maybe 40 bucks.
18 Audi A6 3.0T - APR Tuned, RS6 Interior 19 Audi A6 3.0T
10-24-2016, 07:40 AM
official vendor
official vendor
Here's an example of my links. Boots can by added that'll completely enclose the heim.
10-24-2016, 08:23 AM
Where did u get the hems at
10-24-2016, 08:31 AM
Heims
10-24-2016, 10:18 AM
official vendor
official vendor
If you go that route do NOT use stainless, and I can't emphasize that enough. Stainless isn't the strongest, it stretches, and it's more expensive than a stronger Grade 8 or Grade 9.
Metric stuff will also be a lot more expensive, and 7/16 is only a fraction smaller than 12mm. Make sure that the race has some kind of self lubricating lining to keep them from squeaking too.
10-24-2016, 11:41 AM
Originally Posted by JayRolla
@ MStudt
I know I use 2nd gen rear links on the rear of mine, and I believe I have them no the front too. You should be able to get away with using the rear links from a 3rd gen on the front, if you want extended as they are a bit longer.
I never disconnect my sway bar in the rear. For the front, I just take the links out completely and zip tie the sway bar to the frame so it doesn't hang down... takes 10 minutes or less and not a huge deal since I only offroad 1-2x a month.
-2005 4Runner Limited V8 AWD - Toytec Boss Suspension, SPC UCAs, 285/70/17 Level 8 MK Wheels (17x8, -10), Tandem Rock Sliders
-1998 LX470 (Stock)
www.KeenanOffroadFab.com
10-24-2016, 11:45 AM
I found these for 6. I'm just going to make my own
10-24-2016, 11:46 AM
Real Name: Phoenix
Real Name: Phoenix
I extended mine in the rear by 1/2 an inch. Took about half an hour and works great. There's more detail on page 1 out 2 of my build thread.
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
10-24-2016, 09:27 PM
Real Name: Levi
Real Name: Levi
McMaster-Carr These are what I used but they were not as expensive back when I bought them . The stainless rod and hardware was something I had on hand so I used it. So far it's held up and it does get stressed as I never disconnect . If I ever break one I'll use some 10.9 rod instead as the galling issues alone make the stainless not worth it.
10-24-2016, 09:55 PM
do you sell these or did you just make a set for yourself?
1999 Limited
Overland build in progress
10-24-2016, 10:16 PM
He sells them to members. Send him a PM.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
