11-25-2016, 03:09 PM
#151
Official Vendor
Official Vendor
I don't have a clear understanding of why the bumpstops are spaced with several of the common kits - is it just for driveshaft/tank interference? Shock bottoming?
I'm inclined to NOT design to a reduced-travel setup (meaning go with a panhard mount drop on passenger side) but I may be missing something.
In any event, once we flesh this out, I'll draw up the appropriate part for our 3" comrades.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
11-25-2016, 03:15 PM
#152
Official Vendor
Official Vendor
I also like that a PDB for 3" solution makes this scalable; you can increase lift without changing PLB.
keith
eimkeith.com
11-25-2016, 05:59 PM
#153
Real Name: Sam
Real Name: Sam
I believe that the bump stops are used to limit the up travel and keep the tires out of the fender well. Personally I would rather clearance the finder than lose the up travel. I am running 8 wraps in the rear and have about 4.5" of lift. I am happy to have a 2" PLB and will balance with a 2" PDB. Should work really well. Thanks for a great looking and I'm sure working product.
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
11-25-2016, 08:40 PM
#154
Real Name: Chris
Real Name: Chris
I'll jump on this wagon...count me down for 1 please!
11-25-2016, 08:58 PM
#155
Real Name: Ash
Real Name: Ash
Tank skid contact
On topic. So I finally got around to hanging my new longer sway bar end links this afternoon. Check out what I discovered at the rear inside corner directly next to the universal joint...
Yup that is torn pealed back metal..... What is strange is I could not find any trauma on the universal joint or the driveshaft. Any thoughts from the experts...?
1998 SR5 - 3.4/Auto/151k. Toytec, OME, Savage Off-road, Addicted Off-road, 4Crawler, Spidertrax, TBU, ePCK, B&M, ViAir, '00 grill/headlights, Firestone MT, CB mod, RB mod.
11-25-2016, 09:20 PM
#156
Real Name: Tim
Real Name: Tim
That is bizarre. The driveshaft shouldn't come close to hitting the skid for the gas tank unless the rear end has got abnormal movement side to side which I imagine you would feel big time. My educated guess is a piece of road debris kicked up into the driveshaft and then the driveshaft smashed it into the gas tank skid.
11-25-2016, 09:31 PM
#157
Official Vendor
Official Vendor
shoot me a PM with your email address for paypal and your shipping address!
keith
eimkeith.com
11-25-2016, 10:23 PM
#158
Real Name: Levi
Real Name: Levi
Attachment 228228
Pretty normal when you flex it off road with longer then stock shocks . Grind it off or beat it flat or it will continue to hit worse and worse . Bet you your grease zert is gone !
96 SR5 5 speed, 4:88s with rear ARB , 255/85/R16s , some armor and lights
11-25-2016, 11:16 PM
#159
This is completely normal running more that 3.5" rear coils. The rear will flex the driveshaft into the gas tank. It's more prominent when not running rear sway bar. If you don't cap the rear driveshaft zerk it will sheer off. Notching the gas tank skid works pretty well.
11-25-2016, 11:23 PM
#160
Real Name: Tim
Real Name: Tim
I never knew the rear end could move that much side to side. It can obviously articulate up and down and the amount is dependent on your suspension choice and whether the rear sway bar was connected but that much side to side movement is a surprise to me.
Recently, I was helping
@ infamousRNR
pull his rear slip yoke to lubricate it better to get rid of the slip yoke binding clunk he was experiencing and I noticed his zerk fitting was broken off. I figured he dragged the driveshaft across some rocks but now I'm thinking he might have just flexed his rear end enough for the driveshaft to come in contact with the fuel tank skid.
This is why I love this forum. Always learning something.
11-25-2016, 11:52 PM
#161
Real Name: Tim
Real Name: Tim
So there's a plug you can buy for the zerk fitting hole?
11-26-2016, 12:17 AM
#162
I believe I have a 6mm Allen button bolt. You can get it at any hardware store.
11-26-2016, 12:43 AM
#163
Real Name: Ash
Real Name: Ash
Thanks guys. Well I'll be glad when I get the eimkeith PLB installed which will hopefully help contribute to a straighter running axle to get it away from the tank and back to near inline where it belongs. I am also planning to get the SS adjustable Panhard bar.
The basic facts at this moment. I'm running the OME 890 3" lift springs. With sway bar (now with extended end links as of today) connected. I'll crawl under Snowden tomorrow and check the status of the zerk. I neglected to check for that today as I was just sort of blown away with the skid discovery. One other curious thing is; when looking at the rear wheels they both seem to measure equal distance under the fender wells. I would have thought the driver rear would protrude out the left side slightly further.
11-26-2016, 01:10 AM
#164
Real Name: Tim
Real Name: Tim
Hey Ash,
With a lift in the rear, the rear axle will want to pull to the passenger side, not the driver side. As the panhard bar rises up, it will drag the rear end to the right side (passenger side).
When I helped
@ infamousRNR
with his adjustable panhard bar install, we used a level resting against the fender flare going down to the tire and then used a tape measure to check the distance from the frame to the level.
11-26-2016, 01:11 AM
#165
Real Name: Tim
Real Name: Tim
Thanks, we'll need to get one for
@ infamousRNR
