Originally Posted by JayRolla
So this is installed on the driver side as a lift? How about lift to frame contact?
yeah, it's just a cleaner version of AssBurns lift bracket, except it gets a full 2 inches - the corner that contacts on his bracket is at the same height as the corner on this one (so it should just touch like his does.)
the UNANSWERED question, as AB posited - is what happens at full compression on both sides (although I'm not sure when this happens, maybe climbing a perpendicular rock face?)
I'm going to go ahead and have metal cut and bent for this for myself - if I have mild contact issues at full stuff, I'll just shim my bumpstops to compensate. (I'm thinking that the roll center and axle centering benefits for 95% of my driving situations outweigh the possibility of nicking the crossmember during 1% of operation on the off-chance that it is an issue.) Since I'm looking at a minimum run cost, the more the merrier to keep this affordable!
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
