Old 08-12-2020, 05:24 PM #361
Originally Posted by papabeach View Post
Maybe the trans mount is just collapsed? That would explain the droop at the rear of the transfer case. There is a lot of extra weight back there right now...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-12-2020, 05:29 PM #362
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
It runs, it shifts and it goes very very SLOOOOWWW!!! First test drive was a success. Looks like my plan to modify the crossmember for the crawlbox mount isn’t going to work, not enough driveshaft clearance. I was hopeful it would be ok but only on level ground…can barely get a finger under the driveshaft. I am thinking either custom mount or more likely the TG mount and customize it later as others have done. I was surprised to see how low the rear case hangs down…lower than the rear crossmember. Still need to finish modifying the shifters (I bent them a little already but need more heat/hammer and then piece the interior back together. It was interesting driving down the road with the hole in the transmission tunnel open…could hear the gears whirling a bit, made me smile. I am thinking about pulling the front driveshaft for now, not want to bang it up and don’t need it right now, though not sure if it is ok to drive much without better support. Anyone know if it is ok to drive like this for a bit or am I dancing with badness? Big thanks to everyone who offered advice/tips…I am excited to get this on the trail with everything locked up and in low/low just to see…]
You can also bend the transmission shifter a bit to keep it away from the t-case shifters
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 09:21 PM #363
papabeach's Avatar
papabeach papabeach is offline
papabeach has a spectacular aura about papabeach has a spectacular aura about papabeach has a spectacular aura about
papabeach's Avatar
I think this will be a must! I used a MAP gas torch/press and hammer/drift to bend the RadDesign Sticks...still need to go a bit further....will probably do the same with the transmission shifter though I like the way you cut yours down...may go this route. It is a total custom job, right? Go until you are happy. Also, just ordered the HD detent springs. Shifting from N to L in the rear case seems soft...kicking myself for not doing this earlier but live and learn...
Honestly, I feel a little silly now. My buddy reminded me that our front drive shafts don't move much...our front 3rd members are fixed...the CV's do all the flexing. Here is a pic at full droop....minimal to no change with clearance, so for IFS...clear is clear it seems. I am fine unless I SAS (which might happen in the future). I was thinking with my old 80 series brain...IFS is a different...doh. Trans mount is in great shape...inspected it while it was out...shocked at how well it has stood up. Kinda made me wonder if running an OEM rubber mount on the crawlbox would be a good idea. I already have plans for the HD mount but kinda curious now.
Also, looks like my sag is similar to that of the pic I thieved from @rkntoy below.
I spoke with TG today and their crossmember/skid is meant to follow the "natural" angle of the driveline but simply provide more support. Agree with others that it is just too low. Stinks to buy such an expensive product and then need to cut it up. Its the price you pay though... I am wondering how much I can stuff it up before I have to get adjustable rear control arms and change the pinion angle without causing vibrations...
(SOLD)1999 4Runner SR5, 5spd-R452d 5th, 4x4 “Highlander”
Supercharged, Lifted, Dual cased, Dual Locked, Geared, Armored and more...
Papabeach Mod Thread
(SOLD)1997 Land Cruiser FZJ80
1979 FJ40L-KC
papabeach is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 03:26 PM #364
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
Trail Gear Dual Case
Found that my TG case had gears running metal on metal a while back, TG couldn't answer why but sent out a new 4.7 gear set, I installed said set and have put roughly 150 miles on my rig. Decided to change the fluid so that i could check for issues and found that the same thing was happening. As far as I can tell the only thing that would cause this is the output shaft bearing deflection... this is why marlin use a double row main shaft bearing. Feel like I paid Trail Gear to do their R&D for them, I've had to R&R their case 8x since I 1st installed (popping out of gear, to reseal leaking fluid from them not completely sealing, gears eating each other). Waiting to hear back from them, so far they have been very professional in their treatment, hopefully they continue and I don't end up stuck with a large paper weight.
The Official 3rd Gen Dual Case, Dual Locked Thread-81920aa-jpg
The Official 3rd Gen Dual Case, Dual Locked Thread-81920bb-jpg
clearock is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 10:03 PM #365
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
I already have plans for the HD mount...
Whatever mounts you end up running, use the same material for the entire drivetrain. Either stick with rubber for everything or switch everything to poly, including the engine mounts.
Don't forget that you have a clockable adapter plate. Obviously it would be a bit more work, but you can clock the case and get it back above the crossmember.
midcoma is offline   Reply With QuoteReply With Quote
Old 08-28-2020, 05:50 PM #366
papabeach's Avatar
papabeach's Avatar
@midcoma I appreciate the tips. I ended up sticking with OEM rubber for now. I added a spacer to the top of the crossmember so I could raise the driveline enough to use my Shrockwork skids without any additional modification to them and also add the new mount on the back. I think it turned out pretty nice. I don’t really notice too much in the way of new vibrations...had expected more so am pretty happy. I might clock the setup sometime in the future but for now this was the easiest answer. I also ordered a TG TC shifter as it is easier to bend then the one Marlin sent. Then more shifter mod fun...
The Official 3rd Gen Dual Case, Dual Locked Thread-c6529461-d9d0-4239-a54a-06bcdcc13abd-jpeg  The Official 3rd Gen Dual Case, Dual Locked Thread-ba7334a6-2ecb-4560-9228-e0e1c7bff895-jpeg
1979 FJ40L-KC
Old 08-30-2020, 02:13 PM #367
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Sweet man. Once you wheel it all that work will be so worth it. It really is a game changer.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 04:05 PM #368
Had to send my TG case back to them again. My conclusion after digging a bit more is the spacer they used to stop my popping issue to deep into the case, the output shaft snap ring is what controls the spacing based on the case. I suspect that the case was not machined to correct specs which caused the popping out of gear issue and when they shimmed the output shaft bearing it closed the space to much, said combined with the bearing deflection was causing the rubbing (u can c it in the pic but the parts rubbing r concave which supports the bearing deflection). TG is sending me back an all new dual case except the trans to dual case adapter plate. With all that said I've returned my DD 4runner back to single case and thinking atlas maybe the way 4 me to go on my new build. Probably going to just sell the new TG case coming off. When I took the output bearing and spacers out it was pretty obvious things were forced. The custermer service has been great but i wish a little they had been dicks to start so I would have asked for my $ back at the start.The Official 3rd Gen Dual Case, Dual Locked Thread-20200821_121644-jpg
The Official 3rd Gen Dual Case, Dual Locked Thread-20200821_120954-jpg
Old 09-16-2020, 09:12 PM #369
papabeach's Avatar
papabeach's Avatar
Originally Posted by clearock View Post
Had to send my TG case back to them again. My conclusion after digging a bit more is the spacer they used to stop my popping issue to deep into the case, the output shaft snap ring is what controls the spacing based on the case. I suspect that the case was not machined to correct specs which caused the popping out of gear issue and when they shimmed the output shaft bearing it closed the space to much, said combined with the bearing deflection was causing the rubbing (u can c it in the pic but the parts rubbing r concave which supports the bearing deflection). TG is sending me back an all new dual case except the trans to dual case adapter plate. With all that said I've returned my DD 4runner back to single case and thinking atlas maybe the way 4 me to go on my new build. Probably going to just sell the new TG case coming off. When I took the output bearing and spacers out it was pretty obvious things were forced. The custermer service has been great but i wish a little they had been dicks to start so I would have asked for my $ back at the start.Attachment 369136
Attachment 369137
Bummer to hear...that’s a lot of work. Maybe give the new case a go? If it works...it might just be worth it.
1979 FJ40L-KC
Old 09-17-2020, 02:15 PM #370
My plan was to move the TG case over to my new build, I'm concerned that with my increase in power that even if everything is good now that I'll destroy it with said. I can get the most $ for a new case. Plus I need to set my axles pinion angle and all my housing bracketing based off the case position so to have to go back and change over to a atlas if it failed again... my guess is I'd start snapping input/output shafts and I couldn't blame TG for that with my setup...
Old 09-17-2020, 02:54 PM #371
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
LOL! - that's the first time I've ever heard someone complain about good customer service. Love it, lol.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 01:58 PM #372
papabeach's Avatar
papabeach's Avatar
Finally got my custom boot from Redline. They did great, highly recommend for those that want to go this route. Oh and more importantly, I got to use the gears recently at Uwharrie, NC during the 2020 Overland Challenge. Not sure I “needed” the gearing but the added control was great.
1979 FJ40L-KC
Old 11-17-2020, 01:23 PM #373
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
That looks really good. Where did you get the shift knobs?
hntz4x4 is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 08:31 AM #374
papabeach's Avatar
papabeach's Avatar
Thanks!
Advance adapters
1979 FJ40L-KC
Old 11-18-2020, 02:54 PM #375
Trail Gear did end up sending out a completely new case with new internals. I ordered a 4 speed Atlas II with the 10:34 to 1 low gear, currently working on adapting the 2jzgte A340 (3F310) 2wd transmission to the Atlas.
Dual Case Questions eimkeith 3rd gen T4Rs 121 04-15-2018 03:19 PM
Few dual case questions? Jaysen4runner 3rd gen T4Rs 7 06-27-2016 02:53 AM
how to dual t case? resurectedvikin 3rd gen T4Rs 17 07-27-2015 11:06 PM
97 FJ80 Dual Locked or 99 SR5 5speed w locker???? Ol'Blue General Discussions 18 12-17-2014 01:27 PM
Dual Transfer Case(s) 304-Runner New Members 5 06-02-2013 04:04 AM
