11-19-2016, 03:53 AM
#46
Official Vendor
Official Vendor
The Official 3rd Gen Dual Case, Dual Locked on 35's Thread
Originally Posted by Rockdawg84
I will measure what mine was in the morning but because different stuff may have differing dimensions I would not just go off of my measurements.
I'm probably going TG adapters also if I do this, so your box & adapters measurement would be appropriate for my driveshaft calculations.
cup holder is one way but I used RaDesigns triple shifter. it allows you to not cut your floor up as much. Great product.
Can you explain how the levers work with that setup? Does the factory lever still have its J pattern?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
11-19-2016, 04:08 AM
#47
Real Name: Sam
Real Name: Sam
So the Left lever is a hi/low for the rear (stock) Case.
the center lever is a hi/low for the front reduction box.
the right lever is the 2wd/4wd lever.
if you look at the pic of the transerfcases you can see that the center shifter is simply the top shift of the reduction box. the two outer are connected to a rod that actuates a lever at the back case to operate the hi/low and the 2wd/4wd. This brings up another issue that is exclusive to the triple stick set up. you have to remove the interlock pins so that the hi/low side can function apart from the 2wd/4wd. So no j-shift with triple sticks.
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
11-19-2016, 04:18 AM
#48
Official Vendor
Official Vendor
Ok, so just like my military truck, terrific.
Factory knob on reduction box was throwing me.
keith
eimkeith.com
11-19-2016, 04:22 AM
#49
Official Vendor
Official Vendor
Also; insomnia? ;)
keith
eimkeith.com
11-19-2016, 01:48 PM
#50
Real Name: Sam
Real Name: Sam
LoL It was throwing me so I switched it to the right lever. After the pic was taken of course.
11-19-2016, 02:17 PM
#51
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
11-20-2016, 11:26 PM
#52
BJust got mine, haven't have time to install yet. Maybe after the new year, Front case is MC 4.7 all 23 spline, bolt back to my h-n-l rear mult-mode case. Future plan is to run just a twin stick setup only(front case h-n-l, rear h-n-l). I have manual locking hub, so I figure no need for low 2wd stick. Oh yes its a Automatic not sure how I'm going to stop it yet! hahaha
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
11-21-2016, 12:43 AM
#53
I'm a gen 2 early here as I have dual cases in my 90' Runner. I have the Marlin dual ultimate crawler setup with the stock 2.28 case in front of a 4.7 case.
It's definitely an investment as others have mentioned. You'll need the new drivelines, custom cross member, ideally a 23 spline input shaft to handle all the torque, and I'd recommend new motor mounts.
I also had to relocate my rear window switch as the 4.7 shifter now comes up through the floor there.
But once you are setup you got:
-20 forward gears and 4 reverse, you have the right gear for any situation
-A crawl ratio of about 220:1 in your lowest gear
-2lo in any gear , 2lo w/ the rear locked if you want
-Lots of fun shifters to play with
11-23-2016, 03:22 AM
#54
Real Name: Sam
Real Name: Sam
Very nice! Now you have to update your build thread. Your on the list, so get that bad boy in and document it and it's awesomeness. LOL
11-23-2016, 03:31 AM
#55
Real Name: Sam
Real Name: Sam
Originally Posted by MandAtaco
Awesome, just found this thread! I just dug out my Tacobox from under the workbench last week and started rebuilding it. I've got it all cleaned up and waiting for a bearing to come in before I put it back together. I have a short shifter for the rear case, but am going to order triple sticks from Radesigns for it. My wife hated not having that second cup holder in my Taco. Following this thread closely!
Cup holders are nice, My wife really agrees, and having the triple stick is great. I wish I had replaced the bearings in my crawl box while i had it apart. I get some growling if I short shift to soon on the street. next time it is out (hopefully no time soon) I will be putting new bearings in.
11-23-2016, 12:49 PM
#56
@ Rockdawg84
, I don't have a built thread due to others who have their own opinion. All my built even my 3gen pickup SAS I don't have one. People always have different way of building their shit. Some just have to stick their 2 cent in it. I rather not deal with it! But I'll keep update.on pics coming! Here a few of my truck sas, 37s, dual cases, 5.29, air lockers, blah blah. .lmao
IG: Jaysen4runner
11-23-2016, 02:00 PM
#57
Real Name: Sam
Real Name: Sam
@ Rockdawg84
Totally understand Great looking rigs!!
11-30-2016, 02:12 PM
#58
Real Name: Robert
Real Name: Robert
Thanks for this post. I'm getting ready to go with dual cases in my 99 3rd gen and it's helping a lot.
11-30-2016, 05:01 PM
#59
We need to pull together a group buy with Trail-Gear on adapter kits.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
11-30-2016, 07:47 PM
#60
Official Vendor
Official Vendor
Yes!
keith
eimkeith.com
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
