11-30-2016, 08:01 PM
#61
Originally Posted by Rockdawg84
Totally understand Great looking rigs!!
What CV axles are you running on that beast?
97 Charged, lifted, armored, geared, locked SR5.
11-30-2016, 11:35 PM
#62
Real Name: Sam
Real Name: Sam
Just OEM remans from O'Rielys with life time warranty. My hope is that they will hold together since there is very little shock load on them in double low
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
12-01-2016, 03:24 AM
#63
Real Name: Russel
Real Name: Russel
Subscribe....
I've never thought about doing it this way. I've always planned to go with an Atlas II transfer case. Has anyone use an Atlas...or is this the preferred method?
Thank you
- Russel
12-01-2016, 06:34 PM
#64
Originally Posted by RussToy
Subscribe....
Thank you
- Russel
I've got both....an Atlas II in my buggy and I've had dual Marlins in a 91 Hilux and now a 99 T4R. IMO, the Toyota cases are a better design in terms of packaging....though you can't argue they are as strong as the Atlas. I also have a 3 speed TWF Hero case for my next buggy....but I can't tell you anything about that as I haven't run it yet. If money's no object, get the Hero....but from most rigs, a dual Toyota case is fine.
12-01-2016, 09:14 PM
#65
Official Vendor
Official Vendor
you will need a reduction box from an early (pre tacoma) 4cyl pickup or 4runner. preferably 1985-1988. .
what's a reasonable price for a complete transfer case for this? (semi-local guy has one)
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
12-02-2016, 12:23 AM
#66
Real Name: Sam
Real Name: Sam
I don't know about your area but here in Arizona I have seen them from $150 and up, I wouldn't pay more than $200 because you can get a brand new heavy duty box from Advanced Adapters for like $199. What is he asking? Remember, I would encourage you to put a set of bearings in the case since the old ones are probably 30 + years old and usually abused as in never having the oil changed etc, and since you have to buy a 23 spline gear in it you are really just paying for the case, and some bearing retainers, syncro hubs and shift forks. The syncro hubs will be the hardest to get.
here is the link for the Case from AA at Lowrange offroad:
http://www.lowrangeoffroad.com/toyot...e-51-5911.html
Shift forks
http://www.lowrangeoffroad.com/toyot...ion-kit-a.html
12-02-2016, 08:46 AM
#67
Official Vendor
Official Vendor
and if it comes with 4.70 gears?
keith
eimkeith.com
12-02-2016, 11:54 AM
#68
Had some time yesterday so zapped off a few emails to try and locate a vendor willing to do a group buy on adapters and related parts.
More to come hopefully...
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
12-02-2016, 01:20 PM
#69
Real Name: Sam
Real Name: Sam
The box is clearanced for 4.7 gears but doesn't come with them. That would be a killer deal.
12-02-2016, 03:37 PM
#70
Official Vendor
Official Vendor
I'm still not clear about the 21/23 spline but and how it relates to the gearing..
If the 1st gen transfer case has 4.7:1 gears included, would they necessarily work with the 23 spline conversion?
It looked like at least on one of the gears was made into the shaft (from what I could see in the little internet photo)
Is this not the case?
keith
eimkeith.com
12-02-2016, 04:05 PM
#71
Real Name: Sam
Real Name: Sam
So this is a good discussion that we haven't had here yet. The 21/23 spline issue really has nothing to do with gearing except as it has to do with input spline count. Originally Toyota only made 21 spline transfer case input shafts that are yes on the reduction gear. Then when Toyota released the 22ret (turbo) they increased the spline count and therefore shaft size to 23 to deal with the increased torque and power output. Our trucks with the 3.4L engines all have 23 spline transmission output shafts. There is a sleeve that goes between the transmission output shaft and the input shaft of the transfer case. So we have to change the gear set in the reduction box to go from 21 spline to 23 spline so they can work together. If you found a transfer case from a turbo truck or Runner then you wouldn't have to change the gear since it would already be 23 spine, but they are like hens teeth. So since we have to change the gear set to match the spline count it gives us the chance to change the gear ratio at the same time.
Clear as mud I know. LOL
@ eimkeith
is the case you are looking at already have 4.7 gears in it? if so make sure you confirm that it has 23 spline, if it doesn't then I would pass as they most likely want to much for a case you will have to change the gear set in anyway. But if it is in good shape you could sell the gear set to a mini truck guy to recoup some of the cost.
BTW. For guys doing this with the 4cyl. I believe that you have a 21 spline transmission so that makes things a little less expensive in this process.
12-02-2016, 04:40 PM
#72
@ eimkeith
Due to this 21-23 spline issue, I've realized that it makes sense to just go ahead and do a 4.7 setup, but are you saying that doing so requires modification to the box to clear this different gear set?
12-02-2016, 07:46 PM
#73
Official Vendor
Official Vendor
@ eimkeith
It doesn't; it is a stock case that comes with this additional 4.7 gearset
So, I'm hearing that the gearset in question cannot be converted to 23 spline, correct? (judging by the photo, I'd've assumed that I could just buy the correct shaft from TG...)
keith
eimkeith.com
12-03-2016, 12:04 AM
#74
Real Name: Sam
Real Name: Sam
Yes some minor dremel work is required to fit the 4.7 gear set but nothing major. There is a cost savings if you stay with 2.3 and just change the input gear.
23spline 2.28 Input Gear - Trail Gear
about $375 savings over going with the 4.7 set. Also, there is an argument that the 4.7 is too low. I can honestly say I can not imagine a situation where I would need lower than my current double low.
Correct that Gear set won't work for you. If he will sell the case without the gearset for a good price then grab it Also make sure it is a top shift and not a forward shift case. A forward shift case will have shift forks sticking out of the front of the case Top shift will not.
12-03-2016, 12:21 AM
#75
Official Vendor
Official Vendor
cool. moving forward on case only. thx.
keith
eimkeith.com
