Old 10-25-2016, 11:00 PM #1
4eigner's Avatar
4eigner 4eigner is offline
4eigner is on a distinguished road
4eigner's Avatar
Hood latch differences. Fitting a sport hood on a Limited
I'm attempting to transplant a sport hood from an 01 to a 99 Limited. The sport hood fully closes with about a full inch vertical gap between the top of the fenders and the hood at the very front (leading edge). Being that there's no adjustment on either the hood's anchor loop nor the hood locking mechanism, could there be a difference in dimensions between the Limited's "theft deterrent" hood latch (p/n: 53510-35160) and the regular Sport's hood lock (p/n: 53510-35170)?
BTW:Toyota states that these part numbers are for 99-02 T4Rs. I'm not sure how much of a difference there might be with earlier versions from the newer ones.
Also, imagine if you will...
As odd as it may seem, it appears as though the Limited's hood is more flat across the width of the hood at at the plane of the hood anchor loop whereas the Sport hood appears to have a more convex curve designed into it which brings the loop further down (away from the hood and closer to the ground). This is all from underneath, not atop.
☆Floor Mats
4eigner is offline   Reply With QuoteReply With Quote
Old 10-25-2016, 11:23 PM #2
Tucson4runner's Avatar
Tucson4runner Tucson4runner is offline
Tucson4runner will become famous soon enough
Not sure what the problem is but I put a sport hood on my limited a year ago and didn't run into any problems. It wasn't oem though, it's a certifit hood
Sent from my SM-N930V using Tapatalk
work in progress
Tucson4runner is offline   Reply With QuoteReply With Quote
Old 10-26-2016, 12:16 AM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
HOOD ADJUSTMENT 1. SUBSTITUTE BOLT WITH WASHER FOR CENTERING BOLT Since the centering bolt is used as the hood hinge set bolt, the hood cannot be adjusted with it on. Substitute the bolt with the washer for the centering bolt.
2. ADJUST HOOD IN FORWARD/REARWARD AND LEFT/RIGHT DIRECTIONS Adjust the hood by loosening the hood side hinge bolts. Torque: 13 N·m (130 kgf·cm, 9 ft·lbf)
3. ADJUST FRONT EDGE OF HOOD IN VERTICAL DIRECTION Adjust the hood by turning the cushions.
4. ADJUST HOOD LOCK Adjust the lock by loosening the bolts. Torque: 7.8 N·m (80 kgf·cm, 69 in.·lbf)
326WHP 347TQ
Old 10-26-2016, 12:29 AM #4
4eigner's Avatar
4eigner's Avatar
Thanks for the tips. However, there's at least an inch gap between the hood and the cushions with the hood locked into place. I'm failing to see how loosening the bolts to the lock afford any vertical gains or losses; the bolt holes are not slotted.
☆Floor Mats
Old 10-26-2016, 12:42 AM #5
4eigner's Avatar
4eigner's Avatar
Just for reference, does anybody else have a latch that looks any different dimensionally than this one? This picture was taken directly in front of it with the grille removed.
☆Floor Mats
Old 10-26-2016, 12:55 AM #6
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Can you post a picture of your hood gap?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 10-26-2016, 01:18 AM #7
4eigner's Avatar
4eigner's Avatar
☆Floor Mats
Old 10-26-2016, 11:43 AM #8
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
My grill is still off so it was easy to look at mine. My '99 SR5 (non-theft deterrent, I assume--but it looks just like yours.) lines up exactly as yours, with the bottom of the slot directly cut through the middle by the top of that square profile that juts out of that top body cross-piece. So I don't think it's your latch.
What makes it 'theft-deterrent'? Both latch p/n's are listed for my frame number/VIN. I don't have the alarm, but it looks just like yours.
My Backyard Frame Swap
Old 10-26-2016, 12:05 PM #9
4eigner's Avatar
4eigner's Avatar
At the very least, it appears that there's an electrical contact switch built into the latch.
☆Floor Mats
Old 10-26-2016, 01:34 PM #10
Real Name: Jerod
Real Name: Jerod
Ahh, I see. The post above is from the 02 manual but if it's not even hitting the cushion then there's nothing to adjust except the latch, which hardly moves at all.
I would try and get an '01 latch, they are cheap at a junk yard or on ebay or ask someone on here like DeathCougar if he has a latch like that for sale from a part-out. That must be what's going wrong here then.
By chance is the loop on the hood that goes into the latch larger/smaller the the last hood you had?
326WHP 347TQ
Old 10-26-2016, 02:46 PM #11
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
Is your latch opening before you try and close the hood? In the pic it looks closed.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 10-26-2016, 04:13 PM #12
TheDurk's Avatar
TheDurk's Avatar
I was going to say the same thing. I definitely have the non-deterrent latch with no switch so it's not your latch. I'm thinking you're closing on to an already closed latch.
Old 10-26-2016, 04:17 PM #13
DeathCougar's Avatar
DeathCougar DeathCougar is offline
DeathCougar will become famous soon enough
I third the closed latch issue.
All hood latches are identical from 96-02, and starting in 1999 they added the switch on the Limited for the factory security. But changing latches won't solve your issue, since they are literally all identical. Assuming your truck hasn't been wrecked and the hood is straight, you have another issue here....such as the latch being in the closed position already (sometimes they stick).
Parting Multiple 4Runners HERE
Also parting 1996, 1997, 1998. 1999, 2000, 2001, and 2002 4Runners! PLEASE PM any requests or visit my page PNW 4Runner Connection
DeathCougar is offline   Reply With QuoteReply With Quote
Old 10-26-2016, 04:34 PM #14
4eigner's Avatar
4eigner's Avatar
The latch is not closed prior to dropping the hood. It seats all the way down to the bottom of the groove.
I spent some time in a salvage yard comparing and found minute differences in pre and post '99 latches.
I think the hood loop/anchor was pulled down in an accident. It's the only explaination I can think of. Luckily/unfortunately, the outer shell of the hood looks great though. Hopefully I can "press" it back up without distorting the top of the hood. Otherwise I may have to massage the latching mechanism to make it fit right.
☆Floor Mats
Old 10-26-2016, 05:19 PM #15
JBurt's Avatar
Real Name: Jeff
JBurt's Avatar
Real Name: Jeff
Can you post a picture of your hood loop/anchor?
Build
WTT: 5th gen Limited hood for Trail/SR5 Sport hood with scoop 124runner Want to Buy/Trade 0 02-06-2015 01:50 AM
Sport hood fitting On a 96t4r hondafmx1000 3rd gen T4Rs 9 11-29-2012 07:32 PM
WTT Limited hood for Sport hood w/matched grill Zakadee Want to Buy/Trade 0 02-11-2012 05:56 PM
Trade My 2004 Limited Nautical Blue Hood for Your Same color Sport Edition Hood kraftwerkauto Classifieds - buy & sell (no commercial ads please) 6 04-30-2009 06:29 PM
Trade your Sport hood for limited hood TeCKis300 Classifieds - buy & sell (no commercial ads please) 23 10-05-2005 12:59 PM
