Old 10-30-2016, 03:45 PM #1
mphillips_90's Avatar
mphillips_90 mphillips_90 is offline
mphillips_90 is on a distinguished road
Radiator blew up
Hey guys, Ive only had my 4runner a few months. It has never had overheating issues until yesterday. One of my hoses on the back of the engine near the temp sensor cracked and was spewing coolant everywhere. So today I fixed it no problem. Filled it back up with water until I could stop by the store and get coolant. Figured everything was good so I went for a drive. About 8 mins inti the drive my radiator blew up. Pretty nuts. Idk if I cracked something when replacing the line because I had to lay on my motor to replace the line or what. Anyone ever had this problem? New waterpump and tstat are on the motor and considering I never had problems until I replaced that line I couldnt imagine it be something preexisting I didnt know about.
Radiator blew up-img_2076-jpg
mphillips_90 is offline   Reply With QuoteReply With Quote
Old 10-30-2016, 04:00 PM #2
99SR5rva's Avatar
99SR5rva 99SR5rva is offline
99SR5rva is on a distinguished road
99SR5rva's Avatar
Radiator blew up
I was having over heating issues back in august at 215k miles. Replaced the Tstat, new water pump, new coolant and was still having problems. A new radiator fixed it for me. Looks like your going to need one anyways so I'd give that a shot unless your worried about the new one blowing up..
99SR5rva is offline   Reply With QuoteReply With Quote
Old 10-30-2016, 04:04 PM #3
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Attachment 224954
The top of the radiator is plastic and is a common failure point. If you have a lot of miles on your rig, it was probably due for a replacement anyway. However, if you were putting your body weight on the top of the radiator to get to that hose on the back of the engine, I can see how you could have accelerated it's demise by stressing the plastic and putting some micro cracks in it.
But, since you'll be needing to replace your radiator, I have a video that might help you out. And, this might be a good time to consider adding an external transmission cooler while you're doing it.
And, you may as well clean your AC Condenser while you're at it.
Old 10-30-2016, 04:10 PM #4
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
Kind of hard to see, but is that rust inside your radiator, or just the nasty dried-up remnants of your coolant?
"Variety is for your mind, not your body " —OS
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 10-30-2016, 04:32 PM #5
Thanks for the replys. I am a little worried itll happen to a new radiator but Im about to go pick one up. Got the old one pulled out already. I think its probably a mix of rust and broken down old coolant.
Old 10-30-2016, 04:38 PM #6
Real Name: Woody
Real Name: Woody
Before you put new coolant in, be sure to do some flushes with distilled water and a flush chemical. Get whatever the hell that is out of there before contaminating new coolant.
Probably a good time to swap out the t-stat with an OEM one since you have the radiator out.
Old 10-30-2016, 04:40 PM #7
185Runner's Avatar
185Runner 185Runner is offline
Real Name: Ryan
185Runner is on a distinguished road
185Runner's Avatar
Real Name: Ryan
I had mine blowed up too. Replaced the rad and everything seems to be fine. The suggestions on here were that it was just the rad and it seems to be accurate. Previous owner had green coolant. I used the Toyota red! Go OEM!
1996 Limited 4x4 E/lock 3" Toytec/Bilstein lift
2008 Chevy Cobalt - Wifes Car - Selling $4k 115k miles
2000 Subaru Legacy GT
1986 Ford F250 Diesel - My First Car, Still have it. Want to buy it? Let me know.
185Runner is offline   Reply With QuoteReply With Quote
Old 10-30-2016, 07:45 PM #8
CalBlackSheep's Avatar
CalBlackSheep CalBlackSheep is offline
CalBlackSheep is on a distinguished road
Yep, it happens. Happened to me at 190k+. Just remember when you replace stat to position the jiggle valve at the six o'clock.
Sent from my SAMSUNG-SM-G900A using Tapatalk
CalBlackSheep is offline   Reply With QuoteReply With Quote
Blew the top of the radiator off JHILDE 3rd gen T4Rs 16 05-15-2017 12:58 PM
Radiator Blew cv4runner 4th Gen T4Rs 10 05-01-2015 10:54 AM
blew the top radiator hose rocky_ride Classic T4Rs 9 03-12-2014 02:22 PM
2004 Radiator Hose Blew Off samIam Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-26-2013 02:14 PM
Urgent need help-- radiator hose blew Terminator_T4R Maintenance/Detailing 1 04-30-2012 05:55 PM
