Old 10-31-2016, 09:23 PM #1
choff1212 choff1212 is offline
choff1212 is on a distinguished road
Water pump or head gasket
Good evening everyone, I have a riddle that needs a little help solving. First a little background on the truck. (I'll try to keep this short) Pick up a 2001 SR5 3.4l auto with 164,000 about 4 months ago. Clean 1-owner history timing belt and water pump changed at around 100,000 via service record, only problem was a possible charcoal canister failure. New canister and 1,200 miles without a CEL. The truck now has 169,000
Saturday night I drove the truck about 10 miles on the highway, when I pulled into the driveway I heard a hissing and saw some steam from the overflow. Once cooled I opened the radiator and found it dry with a bum radiator cap and the overflow reservoir had a quart and a half of oil in it. No power loss, rough idle, cold start white smoke from the tail pipe, pink milkshake, cloudy oil on the dipstick, chocolate mouse under the oil fill cap, visible leaks from the head/spark plugs, or overheating via the idiot gauge. Nothing looks out of place except the radiator and reservoir.
All of these symptoms lead me to believe it is one or all of the following options: Water pump crapped out, thermostat is shot, or oil cooler o-rings gave. The plan right now is to replace the radiator cap, thermostat, oil cooler o-rings, radiator, cooling system flush, engine flush, and any other maintenance that was probably forgotten by the PO.
Last edited by choff1212; 11-05-2016 at 06:27 PM. Reason: Removed unnecessary pictures and info.
choff1212 is offline   Reply With QuoteReply With Quote
Old 11-01-2016, 10:29 PM #2
stir_fry_boy's Avatar
stir_fry_boy stir_fry_boy is offline
stir_fry_boy is an unknown quantity at this point
You sure it was oil in the overflow? Usually the coolant leaks into the oil, not visa versa since the coolant is thinner and is under pressure.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
stir_fry_boy is offline   Reply With QuoteReply With Quote
Old 11-02-2016, 10:23 AM #3
J i m s t e r J i m s t e r is offline
J i m s t e r is on a distinguished road
When my head went, I had white smoke whenever the truck was going slowly. Temp guage was up and down like a bride's nightie. But either way, what you are already replacing is wise and fingers crossed will cure it.
J i m s t e r is offline   Reply With QuoteReply With Quote
Old 11-02-2016, 10:50 AM #4
Rock_Rat's Avatar
Rock_Rat Rock_Rat is offline
Rock_Rat will become famous soon enough
Rock_Rat's Avatar
Why are you throwing parts at it without troubleshooting first? At least do a pressure check of your cooling system and do some compression tests.
Always do the easy stuff first.
Go from there.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
Rock_Rat is offline   Reply With QuoteReply With Quote
Old 11-02-2016, 07:14 PM #5
The parts listed above are due to be replaced in the next 30,000k Miles anyway, figured if one or all could be failing I could get a jump on replacing them. There's about a quart of oil or some other extra fluid in the overflow tank. Oil dipstick is showing the correct oil level so I doubt that is the problem and the color is not alluding to transmission cooler failure. Maybe the previous owner put some weird leakstop in the radiator. Either way the oil and transmission fluid are getting dropped this weekend. Pictures will follow.
Old 11-05-2016, 06:25 PM #6
Here's a weekend update: Dropped the oil and took a sample of the transmission fluid and coolant. Also found that the overflow reservoir pipe that connects to the cap had fallen off; radiator cap is shot as well. Pretty much ruled out pink milkshake and blown head. Next step is tracking down the culprit in the cooling system. Let me know what you guys think. Pics taken during the process:
Trans fliud dipstick:
4runner misc
Oil dipstick:
4runner misc
Reservoir tank:
4runner misc
Rad cap:
4runner misc
Oil sample for Blackstone:
4runner misc
Reservoir tank contents:
4runner misc
Trans fluid (needs a flush asap):
4runner misc
Radiator drain:
4runner misc
Old 11-06-2016, 12:06 AM #7
Looks rusty in the overflow. Tranny fluid is due for a change like you said. The coolant from the radiator looks fine. The culprit is likely your radiator cap.
Old 11-06-2016, 01:29 AM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Yeah that's not oil, that's burnt coolant. Turns from green to rusty orange when you've overheated the system. Ask me how I know.
Get that all out and maybe, just maybe you didn't damage the head gaskets.
326WHP 347TQ
Old 11-06-2016, 03:51 PM #9
All of you, thank you for the advice. I just finished up flushing the coolant and replacing the radiator cap; test drive went smoothly. My next move is to get a systems monitor to see where all my temps are at. Hopefully the oil test comes back clean. Once again thanks for all the help. I'll keep you posted.
Old 11-06-2016, 09:07 PM #10
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by choff1212 View Post
Oil sample for greystone:
Who is greystone? The mental hospital in NJ?
Maybe you meant Blackstone?
My Backyard Frame Swap
Old 11-06-2016, 09:44 PM #11
jreask's Avatar
jreask jreask is offline
jreask is on a distinguished road
jreask's Avatar
I don't care who you are, that was funny.
jreask is offline   Reply With QuoteReply With Quote
Old 11-07-2016, 11:52 AM #12
Haha definitely ment blackstone not greystone.
Old 11-07-2016, 12:18 PM #13
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
That tranny fluid looks terrible. I wouldn't bother with a simple drain/fill, I would do a complete fluid exchange.
Mtbtim has a video showing you how to flush out all of the old fluid and replace it with new fluid.
Blackstone results will tell you a lot more. If the oil comes back fine, you should be good to go once the issue is found and resolved.
thegipper is offline   Reply With QuoteReply With Quote
Old 11-08-2016, 01:50 PM #14
TheDurk's Avatar
TheDurk's Avatar
That's good. Greystone was a seriously creepy place. You have NO IDEA. I visited a friend there 30 years ago and I'm still not over it.
Greystone reduced to rubble as demolition nears completion (PHOTOS and VIDEO) | NJ.com
Toyota 3.4l V6 head gasket, timing belt, water pump Comprehensive Parts List DustyRoads 3rd gen T4Rs 50 10-23-2015 10:23 PM
Head Gasket? Water Pump? Baffled... scrbear11 4th Gen T4Rs 7 08-14-2013 04:20 PM
No power when accelerating, possible head gasket/water pump? roguestriker Classic T4Rs 3 08-23-2011 11:45 PM
Head Gasket / Water Pump Question tjames2 3rd gen T4Rs 1 11-04-2009 04:14 PM
