Old 07-02-2022, 12:45 PM #46
Old Gravy leg Old Gravy leg is offline
Old Gravy leg is on a distinguished road
Originally Posted by habanero View Post
You'd have to get manual locking hubs for the 1st gen Taco, the older version is different. I'm assuming your Taco is set up for manual hubs and not a.d.d. since you're not interested in that part.
Then I guess my question would be what is the inherent difference between Aisin lockouts that go on my '94 Toyota 4Runner IFS and the Aisin lockouts that I want to put on my 1st gen Tacoma/3rd 4runner (with inner hub conversion)? As stated before, I checked spline count And I know someone before stated to check spline count but it seems the same from my research. I can't imagine Toyota changing much between the years. Maybe the diameter of axle that sits in the lockouts are different from 2nd gen 4runner to 1st gen Tacoma? Can anyone confirm this?
Old Gravy leg is offline   Reply With QuoteReply With Quote
Old 07-02-2022, 12:57 PM #47
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If you already have everything to swap it over then why not try it and let us know if it works or not?
Old 07-02-2022, 01:07 PM #48
I guess that's true haha. The reason was because I'm still waiting on an axles to come in and one other part and I kind of wanted to know sooner so could move this project along to see if I have to order/find different lockouts. But I guess I can wait a little and do some testing.
Old 07-02-2022, 02:31 PM #49
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
The positioning of where the hub meets with axle splines with respect to the knuckle is different. On the 3rd Gens the hub body is inset.
Try it out and see if it fits though!
JZiggy is offline   Reply With QuoteReply With Quote
Old 07-03-2022, 12:42 PM #50
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
I finally found where the quote in @habanero 's signature came from!
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 07-03-2022, 03:15 PM #51
Picked mine up from a local T4R member. 30K on the bearings installed on ABS spindles complete with silicone boots CV axles
Old 07-03-2022, 03:17 PM #52
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I pulled a set at a local pick and pull..
brillo_76 is online now   Reply With QuoteReply With Quote
Old 07-03-2022, 03:38 PM #53
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
I wished that they'd explained why it was a weird question and why question it at all...
not everyone here shaves their legs, I guess.
Years and years of bolo and not a manual hub in sight in the local self-serve yards, lucky you.
Thanks @JZiggy too, for clarifying. I knew they wouldn't fit and was thinking it was something like that, but couldn't remember the exact details.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
habanero is offline   Reply With QuoteReply With Quote
Old 07-03-2022, 10:44 PM #54
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Bogus. I know some parts are harder to find. Especially when lots of yards now like to leave vehicles so long then crush and get rid of them. Thus making it harder to find a lot of things...
Old 07-05-2022, 08:46 PM #55
Jaysen4runner's Avatar
Jaysen4runner Jaysen4runner is offline
Jaysen4runner will become famous soon enough
4runner 5 spoke manual hub with center cap cover
Manual locking hubs for a 3rd gen ?!!?!-hub-jpg
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
Jaysen4runner is offline   Reply With QuoteReply With Quote
Old 07-06-2022, 09:52 AM #56
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I didn't want to have my '99 apart for a long time while I had my donor non-ABS manual hub Taco hubs pressed into ABS housings, so I got some ABS uprights from a junkyard. 3rd gens are hit and miss in the PnP style yards these days, slowly becoming a bit less common, so I looked up the parts interchange and found that first gen Sequoia/Tundras use the exact same part number. And for whatever reason, those are generally easier to find in the PnP yards, so that's what I ended up getting.
And good thing, between two different machine shops, the presswork (disassemble and reassemble with new bearings) took around 2 months. The first machine shop wasn't busy, but after 2 weeks gave up and said they couldn't get it to budge. The second shop is busy as hell, because they get stuff done. But it takes a while.
Installed them with new upper ball joints (I recently did lowers) last weekend. Oh, another thing that took several months? Getting OEM rebuilt CV shafts. The donor manual shafts I got were fine, but the boots were a little tired yet. Not yet cracked and leaking, but soon. I thought it would be nice to save those as spares and get rebuilt ones. Especially since the rebuilts were barely more than the cost of new boots. And the Toyota dealer was happy to take ADD CV shaft cores in return, I specifically mentioned they weren't manual shafts, and they were OK with it. But yeah, after almost 2 months they initially came up with a pair of rebuilts, and when I went to pick them up I opened the boxes and found one manual shaft, one ADD. It took another month or so to find a second manual CV shaft.
JohnMc is offline   Reply With QuoteReply With Quote
Old 07-06-2022, 10:26 AM #57
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I have my buddy working at LKQ with an alert for ANY 1st gen Tacoma that comes through their network. NADA, ZIP. Zilch.
They are just not out there. I found a yard in Amarillo with a set, they had been gone for months...
I am just going to be patient. I can piece together a "new" setup for around 600 dollars...
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 07-06-2022, 12:00 PM #58
4WD 3rd Gens in the yards in SoCal are few and far between, 1st Gen Tacos, or almost any Tundra/Sequoia, are as rare as hen's teeth.
ORS has kits, partsgeek has one, too. ORS sells the locking tool and bearing retainers. Yotamasters has stud and cone washer kits (studs are a tad longer, needs open nuts). Nobody has half shafts in stock, except TrakMotive 8029 in parts stores (Rockauto has them for $43 each). All the seals can be ordered from the dealers. You can do it ABS or non-ABS.
Everything can be purchased aftermarket or OEM except the spindles. The press work is what it is. If you really want it, it's out there and do-able.
Unless you like playing the luck of the draw waiting game why not just pull trigger on the kit?
Old 07-06-2022, 12:11 PM #59
shadow247's Avatar
shadow247's Avatar
Because I'm liable to do something stupid like chop all the IFS and throw a Solid Axle under it if I come across the right parts. The manual hubs are sort of an "it would be nice to have, but I don't need it" type of mods.
I'm likely going to be building some gusseted spindles soon, so I may end up doing the conversion at the same time. Really depends how my bank account looks when I do the gussets.
My friend Nick did the conversion on his 3rd gen, and spent about 500 on the parts. I'm honestly holding out for him to go ahead and SAS his rig...
The 4Runner Show
Old 07-06-2022, 12:25 PM #60
Look for a Chevy 4x4 truck with 14 bolt/Sterling axles and add the factory electric locker option.
You have a better chance of finding those in the yards than vintage Toyota parts.
AISIN Manual locking hubs Singtoe 3rd gen T4Rs 201 05-07-2016 11:12 PM
Manual Locking Hubs ???????????? Paramedic 3rd gen T4Rs 3 03-13-2016 06:54 PM
Are manual locking front hubs possible? K_Labs 4th Gen T4Rs 3 05-29-2015 06:21 PM
Auto to Manual Locking Hubs lonewolf98765 General Discussions 3 02-17-2014 03:27 PM
CV Boots and Manual Locking hubs SixxiA Classic T4Rs 3 04-16-2011 01:13 PM
