Old 05-15-2018, 11:18 AM #46
TwoToneT4R's Avatar
TwoToneT4R TwoToneT4R is offline
TwoToneT4R is on a distinguished road
TwoToneT4R's Avatar
Any updates?
2000 4Runner Limited Supercharged, Eibach/OME 890, 2" Coil Spacer, Fat Pats 1.5" body lift, 285 Duratracs, 2 12" Pioneer champion pro series subs, 231mm TBU, Camburg UCA's, SCS SR8's Dark Bronze, Sonoram Steel Panhard Bar, '02 Sport Hood, other little things.
TwoToneT4R is offline   Reply With QuoteReply With Quote
Old 08-29-2018, 12:19 PM #47
FreshSeabass's Avatar
FreshSeabass FreshSeabass is offline
FreshSeabass is on a distinguished road
Originally Posted by TwoToneT4R View Post
Any updates?
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20180822_194850-jpg
Zero failures in over 20k miles and two trips across the USA. I will begin the process of cutting my cover towers to build a new upper eye mount.
1996 4Runner - 3RZ - 5 Speed| Lot's of guinea pig installs, and parts. | Bilstein | Superwinch| Marlin Crawler| Front-Range Off-Road|Addicted Offroad| DIY Fabrication & Engineering
FreshSeabass is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 09:10 AM #48
Update a few years on...
It's been nearly 4 years
I installed these coilovers on a 2wd vehicle and I ultimately went through and painstakingly thought through how I would go about designing this mount to get all of the travel back out of the factory suspension.
Problem: I lost a few inches of up-travel due to stuffing an 8" travel coilover in the factory location.
Solution: Design a new mount to go in the place of the existing tower to get that travel back.
How:Prayers and CAD.
Commitment:
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-problem1-jpg
Old 08-07-2020, 09:22 AM #49
Photo dump
Problem and starting to get to the solution
Chop, chop, chop
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-problem2-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-chop1-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200526_232131-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200526_224816-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-23559-fcaa9a81e43ae400989707ad392f578d-jpg
Old 08-07-2020, 09:28 AM #50
Fitting and measuring
All of the work for figuring out the material thickness, width/length/etc. of the tower will be done in CAD, but I was getting the clearance for the coilover done with grid board.
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-fit1-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-fit2-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-fit3-jpg
Old 08-07-2020, 09:37 AM #51
4Runner May Update
Here's a photo for reference after I had chopped the fenders and attempted to fit the 35's without tubbing.... Laughing at that now!
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-4r-may-update-jpg
Old 08-07-2020, 10:22 AM #52
Here's some fun on the computer
This is sort of the progression after doing the finite element analysis for the mount. I sort of know what I'm doing, but I'm only just scratching the surface.
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-tower-2-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-tower-6-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-fea-2-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-tower-v2-8-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-coilover-tower-final-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-view2-png
Old 08-07-2020, 10:25 AM #53
Update: CNC done on the prototype and some refinement
Got the CNC to cut the parts out, tacked together, and fitted to check the dimensions. This is a very crude version and you can see that I took lots of material away afterwards and added some cleaner lines.
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200526_215127-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200526_224816-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200526_232131-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-dimensions-jpg
Old 08-07-2020, 10:28 AM #54
Update: New parts cut
Got the final part cut out, and tacked. I couldn't wait any longer so, I just got after it and started burning.
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200529_192824-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200530_003007-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200531_220341-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200715_214516-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200715_214610-jpg
Old 08-07-2020, 10:34 AM #55
Putting it back together
Re-assembly time with all the new shiny parts
External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200716_235952-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200717_214943-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200717_235459-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200717_235508-jpg  External Resi Coilovers... Not King, Icon, Fox, SAW, or Radflo-img_20200717_235433-jpg
Old 08-07-2020, 10:35 AM #56
You can see that fish plates were added to overlap the weld between the factory tower and the new one.
WTB: Icon ext. travel remote resi coilovers, 4th Gen. San Diego Ca grantprior13 Want to Buy/Trade 0 07-31-2016 06:16 PM
Icon 2.5 coilovers (parts), King 700lbs coils, Sway Away shaft and rebuild kit justinh For Sale: Suspension/Wheels/Tires 3 10-15-2015 10:23 AM
Icon Resi coilovers and upper control arms lift spindles for sale..... 4runnerwithasack For Sale: Suspension/Wheels/Tires 5 08-08-2012 10:22 AM
Fox vs King remote resi coilovers Foosmatrix 4th Gen T4Rs 4 11-29-2010 06:29 PM
I need a comparison btw Icon and Radflo Coilovers... tomhaney1 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 10-22-2010 11:30 AM
