10-02-2021, 10:38 AM
#511
Real Name: Robert');DROP TABLE Students;
Originally Posted by JZiggy
Also, I got a couple of factory fresh OEM keys cut at the dealer!
Did they cut that based on VIN or just copy your existing key? That thing looks pretty good.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
10-02-2021, 12:51 PM
#512
Cut using VIN. They are super nice and crisp.
10-02-2021, 08:32 PM
#513
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
you can easily brute force a cylinder if you have the old key, just start trying wafers and it only takes maybe 10 mins and you can start reading them right off the key or get within 1 wafer number. I got kind of good at it when I did the entire truck.
I don't know the formula of how they encode it into the VIN but you can get a piece of software and it just does it for you.
I show it here
Toyota 3rd lock Cylinders - YouTube
it was a pain but having all new wafers and all new key to match every lock in the truck is nice. I have one key that lock/unlocks the door, starts the truck, locks and unlocks the glovebox, and does the up/down on the rear window.
you can also get the wafer sequence off the passenger side door cylinder that was used from the factory for all the locks.
10-05-2021, 01:50 PM
#514
i love how this looks, do you have a schematic on how you did the wiring? i've got a kenmore excelon single din stereo and would love to add this too.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
10-05-2021, 03:14 PM
#515
I don't, sorry.
12-03-2021, 06:18 AM
#516
Real Name: N/A
Real Name: N/A
The only bummer is I had to take out my little basket to fit the can. I mostly just had a quart of oil in there that followed me around...
Pro tip. You can store your quart size oil bottle in the space between the airbox and the side wall. There isn't enough space between the top of the air box and the hood for it to fly out when the hood is closed.
A quart or so of oil leaks out of my 4runner between oil changes so having somewhere to store it was essential, never had it any issues.
1998 4runner 2.7 manual
12-03-2021, 07:12 PM
#517
265,8xx miles
Prompted by a bit of laggy cruise control response I wanted to make sure my throttle cables were in good condition. Thanks to this old, informative thread on throttle cable adjustment I was also prompted to check on the condition of my throttle cable bumper thingymajig located where the throttle cable connects to the gas pedal -- thanks
@ sleepydad
for pointing that out. Sure enough, mine was pretty blown out:
I replaced this throttle cable with OEM, was fortunate to find a new one that had been sitting on the shelf on eBay for about $40. The new bumper looks like it would be a tricky thing to replicate especially since it is designed to pop onto the plastic clip.
Sorry if this has already been answered but I'm curious why you replaced the cable rather than just removing the slack using the adjustment section near the throttle body. Does that rubber bushing really help smooth out throttle response that much?
1999 SR5 V6/Auto 4WD
4.88 Gears, Front/Rear E-Lockers
1" Body Lift, 2" Suspension Lift, 285/75 R16 Tires
12-03-2021, 07:21 PM
#518
Real Name: Tony (no surprise)
I'm not JZ of course, and while I have not done this replacement on my 4Runner, I have on another ride or two... Even though I was able to adjust it to get the desired tension, I had to do so more often than what I'd prefer, due to such a part deteriorating so rapidly because of its condition. That might have been a factor here or just good preventative maintenance, which JZ does admirably.
2000 Limited, E-locker
Maintenance/Build Thread
12-03-2021, 07:50 PM
#519
Thanks Tony! My bushing is completely shot so I don't think it will get much worse at this point and I was able to take up the slack via the adjustment section on the cable assembly. Haven't taken it out on the road yet but at least it's still idling okay.
01-24-2022, 02:39 AM
#520
Real Name: C8H18 Mike
These were factory ones on my local Craigslist. I painted them so they look fresh. Here was my painting process:
- Scrub with simple green
- Rinse with water
- Wipe down with isopropyl alcohol, allow to dry
- Paint with Rustoleum Primer & Sealer, Gray, 3 light coats til covered, allow to dry a few minutes
- Paint with Rustoleum Trim and Bumper Spray, Matte Black, again 3 light coats til covered.
- Dry a couple days in the sun!!
I did not get the front mud guards, apparently they are quite rare. But I got some aftermarket ones and trimmed them to fit, wasn't too hard. I'll post up about that with some pictures later.
Pretty much exactly what I did with the flares on my SR5 Sport to clean them up.
Those front mud guards aren't rare anymore
3rd Gen 4Runner Mud Flap End Caps – BH3D Printing
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
01-25-2022, 07:28 PM
#521
Real Name: Scott
Real Name: Scott
Originally Posted by octanejunkie
I have a set of these and they are well worth the $80
01-25-2022, 08:08 PM
#522
True! It’s great that BHicks stepped up to provide these. The OEM full length ones are still rare though.
01-25-2022, 08:16 PM
#523
Real Name: Scott
Real Name: Scott
Just learning now how to print in ABS, I might could modify the original model out there on thingaverse to make them look like the originals. Hmmm.....
01-26-2022, 02:57 PM
#524
The file for the original does exist somewhere - it is just bigger than most 3D printers. And it would be very fragile hanging down that low...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-26-2022, 04:30 PM
#525
How about a hybrid material option? 3D print semi rigid as a short flare but include bosses for a flat rubber extension to be screwed onto.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
