Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 01-26-2022, 05:19 PM #526
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Originally Posted by weekendclimber View Post
Just learning now how to print in ABS, I might could modify the original model out there on thingaverse to make them look like the originals. Hmmm.....
Originally Posted by phattyduck View Post
The file for the original does exist somewhere - it is just bigger than most 3D printers. And it would be very fragile hanging down that low...
Originally Posted by JZiggy View Post
How about a hybrid material option? 3D print semi rigid as a short flare but include bosses for a flat rubber extension to be screwed onto.
I like the collaborative approach. We (I) need more trusted forum members with the brain power & skills to bring discontinued parts back to life. The oem discontinued/unavailable parts list is expanding too quickly.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 01-26-2022, 05:57 PM #527
I actually have a flat mud flap on mine now too, using the same 3 bolt locations that Tacoma front flaps use, like this:
Basically, the two on the OEM mudflap location and one inboard through the square hole in the body stiffener. I used a little aluminum bracket to hold the inner section in the right location. The downside/risk there is if you are pushing tire size, the flap pushes the mounting bolts even closer to the tire...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-21-2022, 01:04 AM #528
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
I haven't had a lot of new updates for the 4Runner recently, mostly due to spending my time working on the used Sienna I picked up for the family. Figuring out basic maintenance, refreshing some old components, and thinking of sicmods of course
But here's an exciting one to share: I finally got my cabin air filter (V2) from The 4Runner Show and got it installed tonight. I wanted to show a few pictures of the product and the install.
Packaging is quite nice
The manufacturer took a round charcoal filter and 3D printed a top and bottom base onto it. The design is clever and the fit & finish is good. The top plate has 6 snap fits and the COO and intended vehicle application embossed onto it.
The bottom plate has an integral cone the directs the incoming air outward into the pleats of the filter. It also seals the bottom of the filter media.
The filter is designed to install above the fan and extends downward into the fan itself.
Here is a look up into the AC box with the fan removed. The top base of the filter snaps into the hole of the steel frame.
The fan goes right back in without interference.
Running the fan with the filter installed everything seems fine. The airflow is still good and there is plenty of power from the fan. The sound of the fan is a little bit different -- just a change in the tonality. It'll be interesting to drive around and see how it sounds and if I can tell any different from the driver's seat. I'm also excited to have this in place for pollen season in Atlanta which is right around the corner!
For future exploration I'll be interested to see how easily the filter comes back out for replacement or knocking out dust. I occasionally get a leaf or two into the fan and I expect that this issue will be improved because the crap will just sit in the filter rather than hitting the fan blades and knocking it out of balance (which I can usually hear).
Overall, this is a great product and a welcome and much-needed upgrade for the 3rd gen community!
JZiggy is offline   Reply With QuoteReply With Quote
Old 02-21-2022, 09:24 AM #529
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
Very interesting. Will be watching to see how often you'll have to replace it, or pull it to knock out the dust and detritus. At least it's not all that difficult to pull the blower motor and, if you have those outdoor allergies, I could see how it would be so worth it to have a clean air space.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 02-21-2022, 12:48 PM #530
PrinceValorum's Avatar
PrinceValorum PrinceValorum is offline
PrinceValorum will become famous soon enough
Does the filter media appear to be glued to the printed end caps? It looks awesome, such an ingeniously simple solution.
PrinceValorum is offline   Reply With QuoteReply With Quote
Old 02-21-2022, 02:13 PM #531
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Where can we each get one of them things?
JZiggy's "Grown Up" 4Runner Build-giphy-4-jpg
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 02-21-2022, 03:09 PM #532
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Attachment 392907
3rd Gen Cabin Air Filter
Old 02-21-2022, 04:00 PM #533
Originally Posted by Bad Luck View Post
Thanks!
Out of stock, and, website not taking orders lol
Old 02-21-2022, 10:03 PM #534
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
I've been contemplating that cabin air filter too.
How does the filter media seem as far as durability? Think it can be cleaned out and reused? I noticed K&N makes cabin air filters now for other vehicles so something like that would be great for our use.
I'll be interested to see how it impacts the AC/heat function, if at all. That's one of the great things about the 3rd gen, the AC is fantastic in the southern summers.
If you get leaves down in your blower you may want to check your cowl. There's a fine mesh behind the plastic grates that had started to come loose on mine. I JB welded it back up into place where the factory attachment points had given up over the years.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 02-22-2022, 09:50 AM #535
JZiggy's Avatar
JZiggy's Avatar
It seems pretty sturdy. There's also quite a lot of filter area as the pleats are deep and its a circular configuration.
Yeah I don't get leaves in there often and the mesh seems to be in place from what I can tell. Sometimes the water oak leaves still sneak in there somehow
Old 03-09-2022, 09:14 AM #536
JZiggy's Avatar
JZiggy's Avatar
After routing my CB antenna cable through the flap door of the pressure vent I got to thinking that there must be a cleaner solution that doesn't defeat the dust-sealing function of the flap. A T4R member alerted me to the fact that some of the 01-02 4Runners had a different pressure vent with an incorporated hole for the trailer wiring (sorry I can't recall who -- I'd give you props if I did!)
Standard vent: 62940-35010
Special vent with hole: 62940-35020
Regardless of the wiring upgrade I'm glad I took this old pressure vent about because the flap was about to totally deteriorate
Note that the new vent did not come with the grommet. That part is a Daystar universal firewall grommet which worked perfectly for the application.
Installed with the CB wire running through it.
BTW, I have no idea what the little tab below the hole is for. Maybe the OEM trailer wiring is clipped on here or something?
Note that the top hole of the new vent is a little smaller but the stuffing from the vent inside the interior panel still fit in there fine.
Update to the cabin vent thingy! I installed the Four Cam Engineering cabin vent cover from OPT Offroad as some insurance for the
vent flap.
This is the one for 01-02 4Runners with tow wire
Popped the bumper quarter off. Everything still looks good.
The cover snapped on nicely with the bracket on the LH side removed. Rather than gluing it I just drove a little screw into the yellow plastic housing
The edge of the bracket had to get peened back 1/32" or so but now it holds the cover snugly. A bit of 3M tape across the joint ensures the cover can't slip off.
While I was in there I went ahead and just bundled up my CB wire and zip tied it. Might use it again sometime, dunno. Recent experience has shown me that the little Baofeng VHF/UHF radios are the way to go!
Old 04-01-2022, 10:15 AM #537
JZiggy's Avatar
JZiggy's Avatar
Spindle gusset install, part 1!
Got me some spindle gussets from Heavy Friction via OPT Offroad
I spent a decent amount of time trimming, sanding, and bending to get them to line up perfectly. I also clearanced the top to prevent it from hitting the top strut mount.
Sacrificial bolts installed to protect the JBA adapters and the LBJ bolt holes. I also masked over the other mounting holes and seals.
We also had to bend out the center cheek to get it to follow the curve of the spindle. All fitted up and ready to tack on
Welding! Nice to have a blacksmith friend
We then added a 1/8" thick wrap around the top section. Tack, heat, bend, cut, weld in place.
Finished! We opted to do partial welds along the length on either side rather than full welds down both sides. The partial will be more than strong enough and minimize the amount of heat to potentially distort the spindles.
Old 04-01-2022, 10:17 AM #538
JZiggy's Avatar
JZiggy's Avatar
Spindle gussets part 2 -- odds & ends
After priming and painting here's how things turned out
In the course of welding on the top reinforcement we fiddled with the snap rings and got a bit of weld on one of them. I opted to replace them. Turns out they are 1-3/4" sized snap rings which are gettable on McMaster here: McMaster-Carr (I actually have like 8 extras so lmk if you need a couple)
But before the final install we have some more bonus items!
1) Eimkeith strut tower reinforcements! I went the lazy route and just bolted them in. I'm sure welding it in will make it 150% stronger but it will still be an improvement over stock and add to the rigidity significantly. I can always weld 'em in another time.
2) Upgraded LBJ bolts to ARP!
3) Brake hose relocation bracket. The gusset interfered with the mounting of the brake hose and shifting it over 3/4" with some 1/4" aluminum did the trick.
And finally, here's the before and after
Only have about 1/8" clearance with the tire but it will be easy to trim some metal away if it turns out to be an issue.
Woo!
Old 04-01-2022, 06:24 PM #539
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Thanks!
pretty sure these were made in Russia... so... these might not ever be back in stock?
Old 05-22-2022, 09:11 PM #540
JZiggy's Avatar
JZiggy's Avatar
Been doing a little R&D on the ol' door holder open thingies (aka door stoppers or door checks) especially now that our Russian source has dried up thanks to you-know-who. The manufacturers are a small shop, nice folks, and do good work so it's a bummer all around.
I wanted to see if I could successfully 3D print a replacement part. Short answer: yes I can. The tan part is made of high-temperature wear-resistant plastic. Did this as a small side project only, I will not be able to sell them unfortunately, but perhaps someone else will want to do this at a larger scale.
Here they are installed and lubed up with moly stuff
So, if you recall I replaced my driver's door stopper using the Russian kit back 1.5 years ago, detailed here: https://www.toyota-4runner.org/3575845-post365.html
This was a good opportunity to see how these units wear after 1+ year of use and try out my new 3D printed prototype. Comparison:
Here are the worn Russian units
Compared with a fresh one:
So there's a small wear patch, which I expect, but it's only worn down 0.01" or so -- not very much and the holding power is still very good. But just how good is it?
The force to move the door past the first stop from full open is about 9 pounds when pulled near the fabric door handle
After installing the 3D printed ones it went up to 16 pounds. Noticeably more and the action is rougher due to the bumpiness of the surface. Perhaps it will wear down over time. If I make another attempt I will have the top printed layer be parallel with the stop rod direction rather than perpendicular, which I believe is what is causing the roughness.
Anyway, that's it for this episode of "screwing around with esoteric 4Runner crap and attempting to reengineer it"
My 1992 Toyota 4Runner "Slow build" 4runner_kid Classic T4Rs 131 04-10-2019 01:26 AM
Panman's Build & Adventures- A lot of "Crap, I hope this works" & "Eh, close enough" Panman 3rd gen T4Rs 28 05-09-2016 11:10 PM
1985 Toyota 4Runner "Build" IANSTE Classic T4Rs 10 04-25-2016 07:44 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
1997 4Runner BUILD THREAD "Ruby" SilentYoda3 3rd gen T4Rs 7 10-15-2013 01:14 AM
