Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 03-06-2024, 10:07 PM #811
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Someday I've got to get out there. It's so close too.
Was there any water left over from recent storms?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 03-07-2024, 12:41 PM #812
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Yes, saw lots of folks paddleboarding in the lake at Badwater. "Lake Manly"
JZiggy is offline   Reply With QuoteReply With Quote
Old 03-08-2024, 06:50 PM #813
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Death Valley is fking awesome. I'll probably never get my 4Runner out there but I've given a rental Jeep hell out there.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 03-12-2024, 12:56 PM #814
JZiggy's Avatar
JZiggy's Avatar
Freshened up the cabin air filter
Old 04-12-2024, 07:54 PM #815
JZiggy's Avatar
JZiggy's Avatar
Time to give the manual hubs some attention! After talking with @G_Raw about his hub stud project I got to noodling about various upgrades and optimizations that may be possible with the Tacoma manual hubs. In this (picture heavy) post I'll show some upgrades hub studs and other hardware tinkerings.
The hubs are ready for some paint for sure. Rocking stock studs and acorn nuts from a 1st gen, all 8.8 grade.
A stud puller was necessary for pulling the old studs out. This one from Amazon worked great. It does mar the studs a bit so be prepared for that if you wanted to reuse the hardware.
Front Range Offroad (FROR) sells a custom set of ARP hub studs. A bit pricey, but better than the other ARP options available elsewhere. These studs are class 12+ so they dramatically increase the shear strength of the assembly. The kit comes with class 10 locknuts, which I didn't use because I don't like the idea of locking hardware here.
One swapped to show the difference. The ARP studs just barely fit. The short side uses all the threads in the blind hole in the hub with enough clearance for the taper of the unthreaded portion to seat into the hub. The long threaded side just clears the face of the hub, so we're good and have some extra length to work with.
All 6 on one side swapped out
Washers, cone washers, and hub face bolts soaked in Evaporust and wire brushed clean. It worked great for cleaning it up and left the zinc or cad coating of the bolts intact.
Fresh OEM gasket 43422-60060
Cone washers and washers
I took advantage of the extra thread length and got some tall class 10 "fixture nuts" from Belmetric. These have one flat face and one spherical rounded face made for matching spherical washers. The rounded face is installed outward for a nice finished look. Torqued to 25 ft-lbf which is standard for a class 10 M8 fastener. Stock class 8 uses 18 ft-lbf so we're getting a little more clamp force.
With the hub faces off I repainted the outers with Rustoleum Farm & Implement gloss black which should be pretty durable. The inners just needed a little Sunfire red touchup paint. Sanded the text a bit so make it show up.
Fresh face gasket 43531-60010
7 ft-lbf on the face bolts. Nice and shiny!
And the wheel center plate still fits just fine. Yay
Old 04-13-2024, 11:26 AM #816
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Perfect timing! I'll be referring to this when I swap the aftermarket locking hubs on my 1st Gen to Aisin OEM ones. Thanks!
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 04-13-2024, 12:29 PM #817
I did the SnowBound outboard rear shock mounts and noticed everything you noticed/calculated.
Sadly, mine was because the stock mount rusted through.
Yes, they are built well and the way they were shaped made them super easy to locate.
My 1992 Toyota 4Runner "Slow build" 4runner_kid Classic T4Rs 131 04-10-2019 01:26 AM
Panman's Build & Adventures- A lot of "Crap, I hope this works" & "Eh, close enough" Panman 3rd gen T4Rs 28 05-09-2016 11:10 PM
1985 Toyota 4Runner "Build" IANSTE Classic T4Rs 10 04-25-2016 07:44 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
1997 4Runner BUILD THREAD "Ruby" SilentYoda3 3rd gen T4Rs 7 10-15-2013 01:14 AM
