10-15-2019, 03:02 PM
#286
Real Name: Scott
Real Name: Scott
Originally Posted by JZiggy
Thought ya'll might want to see my latest Blackstone oil report. I'm considering extended the oil change interval since 5k seems to be nothing for a full synth 5W-40 diesel oil.
I just started doing this, but ef'd up in how I took a sample according to their directions (got a sample right during the start of draining the oil, rather than mid-way through). My only issue with extending the interval is that I don't drive the thing more than about 2.5-3k a year. My OCD has me changing the oil at least every 6 months.
10-15-2019, 03:33 PM
#287
Real Name: Leon
Real Name: Leon
I use the oversized Wix XP part# 51516XP filter. I actually just changed to Mobil 1 turbo diesel truck oil since I have a stash of it. Seems to be a very similar product to T6.
Jordan, for noobs like me, is the turbo diesel truck oil close to Mobil 1 (that's what I use), or a whole different animal?
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
10-15-2019, 04:42 PM
#288
Well it’s a diesel spec oil and not gas, so it follows the CK rating rather than SM, SN, etc. Functionally a diesel oil will have less focus on friction reduction (for efficiency) and more on anti-wear and high detergency to control for diesel combustion byproducts. The only downside if that if your engine burns oil it can poison your catalytic converter.
For more info see bobistheoilguy.com
10-16-2019, 09:16 AM
#289
Saw that you're back in Atlanta. Is it permanent or do you travel between GA & CA? I moved to Marietta last year but was in Midtown before that.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
10-16-2019, 10:34 AM
#290
I'm a permanent ATL resident now.
10-16-2019, 02:17 PM
#291
Welcome back! I sent you a PM with my number if you ever needed a place to wrench or wanted to nerd out about 4runner stuff. Next beer's on me.
10-17-2019, 02:18 AM
#292
@ mtbtim
we have been replaced
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
10-17-2019, 07:19 AM
#293
Originally Posted by infamousRNR
Never gonna happen
10-17-2019, 11:55 PM
#294
Only thing is, I've got zero film & editing skills so I wouldn't be much of a replacement but just looking out for extended t4r family instead. However...you guys may want to think about upgrading to Georgia too. With the housing prices in Cali, you could easily sell your homes & probably buy a nice drug dealer level house & still have enough left over dough to retire. Between the 4 of us we'd have plenty of 1st, 3rd & 5th gens to crank out some 4runner vids. Master plan?
10-18-2019, 12:21 PM
#295
Real Name: Tim
Real Name: Tim
Yeah man, we could be like Tony Montana sitting in a big bubble bath in our mansion cursing at the TV and demeaning our wives. That would be awesome.
10-20-2019, 03:18 AM
#296
Real Name: Ash
Real Name: Ash
Say allo to my leetl fren....!
1998 SR5 - 3.4/Auto/151k. Toytec, OME, Savage Off-road, Addicted Off-road, 4Crawler, Spidertrax, TBU, ePCK, B&M, ViAir, '00 grill/headlights, Firestone MT, CB mod, RB mod.
12-12-2019, 02:56 PM
#297
12-12-2019, 03:01 PM
#298
I also did the "AC on with defrost delete" mod. Unplugging this little guy makes it so that the AC doesn't automatically come on when the defrost mode is selected. On cold mornings it can be nice to have the hot air go through the defrost ports so it is more indirect -- but to not have the AC cycling at the same time.
12-12-2019, 03:19 PM
#299
Real Name: Durwin
Real Name: Durwin
[QUOTE=JZiggy;3408151]Decided to swap out the window trim on the four doors with fresh OEM stuff. It just snaps out and back in but it does take some force. The rear passenger door fits a bit wonky but I think it was repaired many years back.
[/QUOT
Jordan, nice touch to freshen up the window molding. Do you have part #'s you could share?
Also, like your post about AC compressor delete when defrost is on. Where exactly is that wire connection located.
Thanks
Durwin
99 2.7l 5spd ARB locked F & R, 5.29's, dual cases, Shrockworks front bumper w/ Warn M8000s, King 25001-151EXT coilovers, OME 861/LC shocks, Stubb's sliders, Shrockworks full skids, custom built rear bumper, Kenda Klever RT 35x10.5r17 on FN FX pro 17x8's, TBU
12-12-2019, 03:20 PM
#300
Real Name: Leon
Real Name: Leon
I replaced mine a year ago, and it really freshens up the look. But my rear ones keep sliding up out of position slightly, have you had a similar issue?
Oh, are you doing the rear window trim as well?
