Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 10-02-2021, 10:38 AM #511
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Originally Posted by JZiggy View Post
Also, I got a couple of factory fresh OEM keys cut at the dealer!
Did they cut that based on VIN or just copy your existing key? That thing looks pretty good.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 10-02-2021, 12:51 PM #512
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Cut using VIN. They are super nice and crisp.
JZiggy is offline   Reply With QuoteReply With Quote
Old 10-02-2021, 08:32 PM #513
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
you can easily brute force a cylinder if you have the old key, just start trying wafers and it only takes maybe 10 mins and you can start reading them right off the key or get within 1 wafer number. I got kind of good at it when I did the entire truck.
I don't know the formula of how they encode it into the VIN but you can get a piece of software and it just does it for you.
I show it here
Toyota 3rd lock Cylinders - YouTube
it was a pain but having all new wafers and all new key to match every lock in the truck is nice. I have one key that lock/unlocks the door, starts the truck, locks and unlocks the glovebox, and does the up/down on the rear window.
you can also get the wafer sequence off the passenger side door cylinder that was used from the factory for all the locks.
Old 10-05-2021, 01:50 PM #514
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
I installed a Subaru Forester field monitor unit (or gauge pack) in the lower DIN mount. Took a bit of work to figure out where to hook up the wiring including the speed sensor which it needs to work. It has an outside temp gauge which is pretty cool.
Experimented with a few different bulb options since the stock ones are a little dim. Still not sure I've hit on the right solution.
While I had everything apart I made little brackets to mount the ScanGauge using the ash tray screws.
i love how this looks, do you have a schematic on how you did the wiring? i've got a kenmore excelon single din stereo and would love to add this too.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 03:14 PM #515
JZiggy's Avatar
JZiggy's Avatar
I don't, sorry.
Old 12-03-2021, 06:18 AM #516
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
The only bummer is I had to take out my little basket to fit the can. I mostly just had a quart of oil in there that followed me around...
Pro tip. You can store your quart size oil bottle in the space between the airbox and the side wall. There isn't enough space between the top of the air box and the hood for it to fly out when the hood is closed.
A quart or so of oil leaks out of my 4runner between oil changes so having somewhere to store it was essential, never had it any issues.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 12-03-2021, 07:12 PM #517
Option01 Option01 is offline
Option01 is on a distinguished road
265,8xx miles
Prompted by a bit of laggy cruise control response I wanted to make sure my throttle cables were in good condition. Thanks to this old, informative thread on throttle cable adjustment I was also prompted to check on the condition of my throttle cable bumper thingymajig located where the throttle cable connects to the gas pedal -- thanks @sleepydad for pointing that out. Sure enough, mine was pretty blown out:
I replaced this throttle cable with OEM, was fortunate to find a new one that had been sitting on the shelf on eBay for about $40. The new bumper looks like it would be a tricky thing to replicate especially since it is designed to pop onto the plastic clip.
Sorry if this has already been answered but I'm curious why you replaced the cable rather than just removing the slack using the adjustment section near the throttle body. Does that rubber bushing really help smooth out throttle response that much?
1999 SR5 V6/Auto 4WD
4.88 Gears, Front/Rear E-Lockers
1" Body Lift, 2" Suspension Lift, 285/75 R16 Tires
Option01 is offline   Reply With QuoteReply With Quote
Old 12-03-2021, 07:21 PM #518
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
I'm not JZ of course, and while I have not done this replacement on my 4Runner, I have on another ride or two... Even though I was able to adjust it to get the desired tension, I had to do so more often than what I'd prefer, due to such a part deteriorating so rapidly because of its condition. That might have been a factor here or just good preventative maintenance, which JZ does admirably.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 12-03-2021, 07:50 PM #519
Thanks Tony! My bushing is completely shot so I don't think it will get much worse at this point and I was able to take up the slack via the adjustment section on the cable assembly. Haven't taken it out on the road yet but at least it's still idling okay.
Old 01-24-2022, 02:39 AM #520
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
These were factory ones on my local Craigslist. I painted them so they look fresh. Here was my painting process:
- Scrub with simple green
- Rinse with water
- Wipe down with isopropyl alcohol, allow to dry
- Paint with Rustoleum Primer & Sealer, Gray, 3 light coats til covered, allow to dry a few minutes
- Paint with Rustoleum Trim and Bumper Spray, Matte Black, again 3 light coats til covered.
- Dry a couple days in the sun!!
I did not get the front mud guards, apparently they are quite rare. But I got some aftermarket ones and trimmed them to fit, wasn't too hard. I'll post up about that with some pictures later.
Pretty much exactly what I did with the flares on my SR5 Sport to clean them up.
Those front mud guards aren't rare anymore
3rd Gen 4Runner Mud Flap End Caps – BH3D Printing
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 07:28 PM #521
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
I have a set of these and they are well worth the $80
weekendclimber is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 08:08 PM #522
JZiggy's Avatar
JZiggy's Avatar
True! It’s great that BHicks stepped up to provide these. The OEM full length ones are still rare though.
Old 01-25-2022, 08:16 PM #523
Real Name: Scott
Real Name: Scott
Just learning now how to print in ABS, I might could modify the original model out there on thingaverse to make them look like the originals. Hmmm.....
Old 01-26-2022, 02:57 PM #524
The file for the original does exist somewhere - it is just bigger than most 3D printers. And it would be very fragile hanging down that low...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-26-2022, 04:30 PM #525
JZiggy's Avatar
JZiggy's Avatar
How about a hybrid material option? 3D print semi rigid as a short flare but include bosses for a flat rubber extension to be screwed onto.
My 1992 Toyota 4Runner "Slow build" 4runner_kid Classic T4Rs 131 04-10-2019 01:26 AM
Panman's Build & Adventures- A lot of "Crap, I hope this works" & "Eh, close enough" Panman 3rd gen T4Rs 28 05-09-2016 11:10 PM
1985 Toyota 4Runner "Build" IANSTE Classic T4Rs 10 04-25-2016 07:44 PM
M-Piers97 "on the cheap" 97 4Runner build/maintence thread M-Piers97 3rd gen T4Rs 5 02-27-2014 10:55 PM
1997 4Runner BUILD THREAD "Ruby" SilentYoda3 3rd gen T4Rs 7 10-15-2013 01:14 AM
