It was finally time to retire the old Sumitomo Encounter ATs and get something new. Those tires really did great and we less than $700 out the door. Put probably 50k on them without a single issue, but they were down to 4/32" tread and getting a bit of dry rot cracks and I was ready for something more capable. Splurged and got a set of Wildpeak AT4s! These have 15/32" tread new, nice and chonky
Shoutout to the great folks at Gran Turismo East who sold me the tires and did the alignment. I've never experienced such a professional alignment job. After installing the tires they put the truck up on the alignment rack with me in the driver's seat! Reason being that the driver's (not inconsiderable) weight needs to be accounted for when aligning. They also had me put the wheel to exactly where I felt was centered and locked it in there. The tech shared that the rear axle is a tiny bit out of alignment, but not enough to need to be addressed -- adjustable links would be necessary of course. He also noticed that I had marked my adjustment points (LCA bolts and outer tie rods) and placed fresh marks with a pen that even matched the purple color I typically use. Outstanding service!
I also decided to finally do something about my funny rear end links. After installing the Sonoran Steel bracket lift (after doing the suspension lift) it kicks the front eye of the bar forward 1/2" causing the links to sit at an angle. Not a big problem but not ideal.
These cheapo links (basically Moog knockoffs) already have some wear in the socket so I figured I could experiment with them. Fortunately this link design has a really beefy center rod so I was able to heat & bend them without worrying about them breaking or bending more during use (I hope). Made a little template to figure out what bend I needed, hit the center with a torch for a minute, and bent to shape on my arbor press
Now the top of the link is happily vertical and mates properly with the upper mount.
In the future I may get a fresh pair, bend them again, and paint them for longevity.
