Old 11-19-2016, 12:21 PM #1
Rock_Rat's Avatar
Rock_Rat Rock_Rat is offline
Rock_Rat is on a distinguished road
Rock_Rat's Avatar
Replace Fuel Pump - Drop Fuel Tank?
Quick question...Is there any way to replace the fuel pump without completely dropping the tank? So far it looks pretty straight forward with the tank removed. Thanks!! I've seen a few comments on here mentioning no need to remove tank.
Yes...I've done my due diligence and searched the site. @the great him has a good DIY with pics.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
Rock_Rat is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 12:28 PM #2
Sean K.'s Avatar
Sean K. Sean K. is offline
Sean K. is on a distinguished road
Sean K.'s Avatar
You have to drop it unless you cut an access hole in your floor. Careful...there's a connector on the top that must be unplugged after folding the rear seat forward and pulling up the carpet. Lots of guys miss this, try to drop the tank and rip that connector out.
Sean K. is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 12:38 PM #3
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
So unlike the 2cnd gens there isn't an access plate under the rear seat that allows you to change the pump?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 01:04 PM #4
Paperjam's Avatar
Paperjam Paperjam is offline
Real Name: Alex
Paperjam is on a distinguished road
Paperjam's Avatar
Real Name: Alex
There is an access hole but you physically cant remove the pump through it. Its an easy tank to drop anyways. I can have it out in <30mins or so.
1998 T4R, 2.7 4wd/5spd swap build thread
Paperjam is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 01:07 PM #5
Sean K.'s Avatar
Sean K.'s Avatar
There's an access hole...and it's fairly big, but it's just for the tiny plug (Makes no sense). The hole isn't big enough to change the pump though.
Old 11-19-2016, 01:22 PM #6
Rock_Rat's Avatar
Rock_Rat's Avatar
Thanks guys. That's what I thought. No plans to cut a hole in the floor. Great weekend project along with a few other things.
Old 11-20-2016, 03:12 PM #7
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
I'm with you man. I'll be replacing a few more gas tank parts along with the fuel pump but my parts won't be coming in until Tuesday. It'll probably be the friday after thanksgiving when I'll have time to replace my parts. I was wondering if the tank could be partially lowered to do the job but for the sake of having complete access to the top of the tank I thought completely removing it would be best.
Are you just replacing the fuel pump or anything else on the tank?
Were you having any symptoms leading to replacing your fuel pump?
Which fuel pump or parts did you end up going with?
I highly recommend doing one of your awesome write ups with some sweet pics and posting it before next friday...
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 11-21-2016, 03:25 AM #8
Rock_Rat's Avatar
Rock_Rat's Avatar
Sorry I won't be much help here. No write ups before Friday and no "heavy" maintenance on Friday. Pretty sacred day with the Apple Cup.
I don't have any problems with my fuel pump. I'm just replacing the OEM pump with a larger volume pump. It's a Denso but it's from a Mitsubuishi Evo 8. This is just to support the SC once it's installed. I'm waiting on a new 2.2 pulley which is on back order.
The Great Him did a pretty good write up on the tank removal. I have a link in post #1.
Old 11-21-2016, 06:40 AM #9
fourfive's Avatar
fourfive's Avatar
I've gone through a couple write ups, was partly giving you a hard time but you do have some very good write ups. The sc will be sweet man. Interested in your feedback once everything is complete.
Old 12-17-2023, 03:10 AM #10
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Am having a hard time prying out the fuel pump from the housing, am having a p0230. Have swapped relays, changed fuel filter..but the pump is appearing tough to pry out from the housing. Any tips on removing the pump?
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 12-17-2023, 02:23 PM #11
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Not sure what housing your referring to but the fuel pump assembly is connected to the top of the fuel tank with 8 or 10 screws. It should come out easily unless somebody used sealant on the gasket. If that's the case then you'll have to carefully pry it out. The only thing holding the pump to the assembly is a short piece of fuel hose pushing the pump against the bottom of the assembly.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 12-17-2023, 05:33 PM #12
Oh, wrong section.
Mine is a 4th gen.different fuel assys
Gas leak around fuel pump on top of gas tank TeamUSA 3rd gen T4Rs 5 07-09-2015 08:51 AM
Fuel Tank Replace Questions!! Opinions please!! 004wd 3rd gen T4Rs 6 04-27-2015 11:47 PM
Looking for gas tank with fuel pump and sending unit Reggie Want to Buy/Trade 0 10-20-2013 08:08 AM
URGENT! Need help with Fuel Pump/Tank removal Zonly1 4th Gen T4Rs 4 05-12-2012 12:15 AM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
