Old 11-19-2016, 06:52 PM #1
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
Need help diagnosing Error Codes
I have a 2001 4runner 2WD with 190,000 miles and it has been running like a champ until lately I have been having some error codes pop up and need help diagnosing the cause.
Earlier this year in June I did some maintenance work for stuff that hadn't been done (plugs, wires, DS 02 sesor, pads, air intake hose, fuel filter, cleaned Throttle body, PCV valve with hose and grommet, etc) and then I moved from Alabama to Idaho which was a lot of driving with no problems. But in the last month or so I have been having these codes come on and can't figure it out. I am not the most mechanically inclined so please bear with me, but any input will be greatly appreciated.
The codes are: C1201, C1223, C1224, C1253, and P0420.
Ser1clymb is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 07:26 PM #2
Black798's Avatar
Black798 Black798 is offline
Real Name: Phoenix
Black798 is just really nice Black798 is just really nice Black798 is just really nice Black798 is just really nice
Black798's Avatar
Real Name: Phoenix
The P0420 is a code saying your catalytic converter isnt operating at the right efficiency, so that could either be a failing rear o2 sensor or the catalytic converter needing to be replaced. As near as I can tell from some googling the codes starting with a c are related to the abs system having a fault. Hope this helps some.
This link might also have some better info. http://www.toyota-4runner.org/proble...ine-light.html
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
Black798 is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 07:26 PM #3
Paperjam's Avatar
Paperjam Paperjam is offline
Real Name: Alex
Paperjam is on a distinguished road
Paperjam's Avatar
Real Name: Alex
Post the descriptions for the C codes. Those are chassis codes
P0420 means you need a cat on bank 1
1998 T4R, 2.7 4wd/5spd swap build thread
Paperjam is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 09:00 PM #4
Magmotor's Avatar
Magmotor Magmotor is offline
Magmotor is on a distinguished road
Magmotor's Avatar
Here are the codes and descriptions. Scroll down to your PO code then scroll further down to the C codes. I would take the codes to a Toy mech and at least ask for their opinion, at least you'll know what they are talking about....good luck...!!
http://tacoma.site40.net/4Runner_96-...es/repair.html
'01 SR5 2WD
Magmotor is offline   Reply With QuoteReply With Quote
Old 11-20-2016, 12:38 AM #5
Ser1clymb's Avatar
Ser1clymb's Avatar
I have checked the descriptions, but don't know the best way to diagnose the cause. I know the C2101 is default when the CEL comes on.
C2123 is ABS control system malfunction
C1224 indicates the NE Signal Circuit
C1253 indicates the motor relay circuit
Is there a way to distinguish between the cat and the 02 sensor other than changing the 02 sensor and seeing if it goes away?
Old 07-13-2020, 04:00 AM #6
Arthur1988 Arthur1988 is offline
Arthur1988 is on a distinguished road
Please help
viber-image-2020-07-13-11-48-59 — ImgBB
who knows what's wrong?
Please help me
Arthur1988 is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 04:18 PM #7
spartacus's Avatar
spartacus's Avatar
Please help me
your in 3rd Gen section. all I can see is the low tire pressure and airbag light.
Help/Advice on Diagnosing Error Code P0442 BigRogers 3rd gen T4Rs 7 09-19-2015 03:54 PM
Codes, Squeaks, and a snapped belt. Some help diagnosing please. 4orRunner 3rd gen T4Rs 0 07-17-2015 08:49 PM
HELP! Lots of error codes! '00 T4R bayank 3rd gen T4Rs 9 04-14-2011 11:36 AM
Multiple Error Codes spj512 Problems & Warranty Issues 0 09-21-2010 12:01 PM
error codes jamesek9 3rd gen T4Rs 5 02-22-2006 09:23 PM
