11-20-2016, 08:01 PM
OEM Foglight Installation?
I would like to install some OEM fog lights on a 1999 SR5 that that did NOT come from the factory with fog lights. The bumper has the holes for the fog lights.
Can someone tell me if the wiring for the lights is already in place in the harness? I will also have to replace the multifunction switch, but I don't know if it is plug and play, or there is more involved than just replacing the switch.
Is there somebody that has attempted this? If the installation is more work than it's worth, I may just mount some Rigid lights on the bumper.
My other 4Runner is a ford
11-20-2016, 09:16 PM
The wiring should be there for the fog lights to plug in. You can wire up your own switch or find a factory switch.
OEM fog lights
It's the 10th link down on the left.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
11-20-2016, 09:42 PM
Thank you, Sir!
11-21-2016, 04:39 PM
That's what I did... If pre-wired (SR5 should be), all you need is:
- Relay
- Fuse
- New headlight stalk (look for Camry/Solara/Sienna used switches with no DRL control)
- Fog lights
That's it. All plug-n-play.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-21-2016, 07:46 PM
Thank you, also! Good to know.
02-06-2017, 01:09 AM
Real Name: j
Real Name: j
Which fogs fit in the factory hole on a 2001?
01-23-2019, 11:04 PM
Real Name: Erick
Real Name: Erick
I found out that the OEM headlight/fog light switch from 96-99 is diferent from 2000-2002.The Fog lights and Realy are the Same on all years.
For my 2001 SR5 I used part #84140-14120 (SWITCH ASSY , HEADLAMP
Also need a Fog Relay,Fog Lights,15A Fuse The rest is plug and play!
01-24-2019, 02:10 PM
- Relay
- Fuse
- Fog lights
To be clear, you need the foglights plus the support brackets, if you are going to use the factory holes. Or fab your own. Many of the used lights for sale on eBay do include the brackets. My '99 SR5 is pre-wired, but no support brackets--just a blind hole in the valence.
My Backyard Frame Swap
01-24-2019, 02:42 PM
I know the fog light switch is different from 96-98 and 99-02, but is it common for the earlier 96-98 models to come pre-wired for fog lights?
I know the type of fog lights are different too between those years
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
01-24-2019, 05:18 PM
None were. It was a dealer/port installed option... similar to how the keyless/alarm systems were on the '96-'98's.
