Old 11-21-2016, 03:00 PM #1
Jayjayb96's Avatar
Jayjayb96 Jayjayb96 is offline
Real Name: Not jay
Jayjayb96 is on a distinguished road
Jayjayb96's Avatar
Real Name: Not jay
Dash illumination wire
Hey guys
I installed two sets of spot lights on my rig and used contura rocker switches. I got it working and everything but my rocker switches have a two light funtion. Lower light that illuminates when i turn on the interior lights and upper for when im actually running them.
My question what wire can i tap into hook up #6 on the back of the rocker switch to light up when i turn on my lights at night? Ive read of prople jumping #3 to #6 but wouldnt the light be constantly on even if the truck isnt running? Yes ive used the search function and have read numerous threads and looked at the fsm. Its probably easy but for the life of me cant figure out which wire i should tap into. Any help would be appreciated!
Thanks
Dash illumination wire-img_9828-jpg
09' metropolitan 50cc low and slow grocery scoot
97' SR5 rwd stock 300k club
02' SR5. 4wd. Lifted,air locked, SC'd, etc.
Jayjayb96 is offline   Reply With QuoteReply With Quote
Old 11-21-2016, 03:16 PM #2
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Connect #6 to pretty much any green wire in the dash lighting circuit. If you want that LED to dim with dash, connect #7 to pretty much any white wire with green stripe. If you want full brightness, connect #7 to ground. You can find both those wires at the round dimmer rheostat.
http://tacoma.site40.net/4Runner_96-...mci/025ill.pdf
My Backyard Frame Swap
Old 11-21-2016, 06:27 PM #3
Jayjayb96's Avatar
Real Name: Not jay
Jayjayb96's Avatar
Real Name: Not jay
Thanks durk!
Old 11-21-2016, 08:55 PM #4
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
My rocker switches are located under my headunit. So i have a t-tap in the cigarette outlet illumination wire. And this illuminates the lower led on 3 of my rocker switches. No fuses nothing. They are small LED. Don't go crazy here. Simple t-tap and that it. Depending where your switches are. Use a test light to see when it gets power when your headlights are on.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 11-21-2016, 09:05 PM #5
Jayjayb96's Avatar
Real Name: Not jay
Jayjayb96's Avatar
Real Name: Not jay
Mine are on the left hand side below the ac vent..will tap into one of the wires @TheDurk mentioned..but good idea on the cig lighter! I would do that if my switches were there
Dash illumination wire-img_9812-jpg
Old 11-22-2016, 12:52 AM #6
Or you can add a fuse , use a line that gets power with the key on
Kenwood and Illumination wire vtferret 3rd gen T4Rs 18 12-26-2013 02:09 PM
Metra Wiring Harness - Illumination wire KAX Engines / Suspension / Wheels / Tires / Audio / Accessories 8 07-17-2012 03:17 PM
Metra wire color - illumination wure Ghostrider Engines / Suspension / Wheels / Tires / Audio / Accessories 0 09-10-2009 09:14 PM
What color is the illumination wire on the Toyota harness?? gkatmar 4th Gen T4Rs 4 08-26-2007 04:40 PM
