Old 11-11-2018, 11:17 PM #31
96 ToyRunner's Avatar
96 ToyRunner 96 ToyRunner is offline
Real Name: Nelson
96 ToyRunner will become famous soon enough
Real Name: Nelson
So I may or may not have to swap out my engine and I was wondering before I do or buy anything do I need to buy a new computer with the new motor I’ve never done it but I’m going to have people that know what there doing helping me out but again wil I need a new computer or will mine work
Off road runner
-Toyota 4runner
96 ToyRunner is offline   Reply With QuoteReply With Quote
Old 11-12-2018, 01:26 AM #32
Renegade_Medic's Avatar
Renegade_Medic Renegade_Medic is offline
Renegade_Medic will become famous soon enough
You retain your computer and wiring harness, as long as it's the same motor (5VZ->5VZ).
99 4Runner Ltd 4x4
Build Thread
Renegade_Medic is offline   Reply With QuoteReply With Quote
Old 11-12-2018, 08:19 AM #33
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
It depends.
If you find a motor from the same year with the same drivetrain (rwd/4wd), than you won't have to swap anything related to the ECM.
I swapped a 99 engine into my 97 and had to use the engine wiring harness from my 97. The ECM's are different (connectors) so I either had to re-pin the wiring harness (truck side) to work with the 99 ECM or I could use the engine wiring harness from my 97 on the 99 engine, to be able to keep the 97 ECM.
It was easier for me to just swap the engine wiring harness from the 97 and use it on the 99 engine. Everything hooks up fine (engine side) which allowed me to keep the 97 ECM. I believe 96-98 ECMs are the same assuming its the same motor and same drivetrain. It took maybe an hour or so to swap the engine harness. You do have to pull the upper intake manifold off to get the harness off but it only took maybe an hour or so to do the swap.
Hope that isn't too confusing. The easiest solution is to find a donor motor from the same year/model/drivetrain but other years can work.
So in summary, the ECM's on 3rd gens did change throughout the years.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 03:21 PM #34
daYoda daYoda is offline
daYoda is on a distinguished road
I have a '99 Auto with 221k mi. I want to do a manual swap, so I picked up a '96 manual with 126k mi and the RR locker, complete [frame rotted to hell!]. Both are 4wd SR5's.
So far I've removed the tranny, crossmembers and yanked the 5ve-fe from the '96. Took me a couple weekends and some friends.
The '99 is sort of my DD, but I have another car. -> this is my summer project.
Reading thru the thread I noticed a lot of comments about the differences between the wiring harnesses for the differing years. On another thread, I saw some people had issues when swapping engines from different years.
It appears that since the '99+ 4r's came with OEM Anti-Theft that something about the Body ECU doesn't play nicely with older ECM's. Is this true? Are there work arounds?
I was planning on taking pretty much the whole wiring harness and ECM. The '96 has an aftermarket "Python" branded Anti-Theft. I was hoping to just drop the ECM/Wiring harness in and go with it. Will this work? Is it worth my time?
daYoda is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 12:06 AM #35
Willy24 Willy24 is offline
Willy24 is on a distinguished road
Oil pan
did you have any trouble swapping the oil pan over? The bolts won't line up right it seems.
Willy24 is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 12:13 PM #36
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Bolts won't line up? Are you sure it's not flipped around backwards and you're trying to put the front in the back? There's no difference in the oil pan bolt holes, the 5VZ block is the same regardless of what year or in my case, what country it's from. I have a JDM engine from a Toyota Hiace and my oil pan bolted up just fine.
326WHP 347TQ
Old 07-22-2019, 01:00 AM #37
Sweet that's what I thought. I'm going to go in tomorrow to the shop and give my mechanic a hand with it and I'll get everything figured out hopefully!
Old 07-22-2019, 09:39 AM #38
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by gamefreakgc View Post
5VZ block is the same regardless ... JDM engine from a Toyota...
Aren't all 5vz Japan Domestic Manufactured engines, some were just installed/shipped to other countries as their start in life, no? Hence why they're all the same. Or is this more to it than that?
Old 07-22-2019, 12:25 PM #39
Not where it was manufactured - where it was intended for first use. The 4Runner is a USDM vehicle produced in Japan...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-05-2023, 12:26 AM #40
silverbullet4 silverbullet4 is offline
silverbullet4 is on a distinguished road
I thought if drivetrains are different then oil pans will be different too?
silverbullet4 is offline   Reply With QuoteReply With Quote
Old 09-05-2023, 03:27 AM #41
SocalRunner15 SocalRunner15 is offline
SocalRunner15 is on a distinguished road
I'm curious: What happened to the original engine...and at what mileage?
SocalRunner15 is offline   Reply With QuoteReply With Quote
Old 09-13-2023, 04:35 PM #42
Useatorquewrench Useatorquewrench is offline
Useatorquewrench is on a distinguished road
Hopefully you had the proper wiring harness.
Useatorquewrench is offline   Reply With QuoteReply With Quote
Engine Replacement traxxi2003 Maintenance/Detailing 8 10-05-2018 03:57 PM
Engine replacement Clacquam Maintenance/Detailing 3 10-31-2014 02:07 AM
97 3.4 engine replacement to 01 3.4 HELP! 1oldyota 3rd gen T4Rs 0 11-02-2012 10:58 AM
98 2.7 engine replacement fastolds 3rd gen T4Rs 19 03-27-2012 08:24 PM
Engine Replacement Djembe4 3rd gen T4Rs 0 01-25-2011 06:44 PM
