11-22-2016, 07:49 PM
****ELECTRICAL GREMLINS please help *******
11-22-2016, 10:22 PM
So you are saying you have been driving it with the lights staying on for 7 weeks?
I don't have the EWD for a 96, but in the later models the 20A EFI fuse has nothing to do with supplying power to the ignition circuits. That is accomplished through the 40A AM1 and the 30A AM2 fuses.
Can you take a picture of your engine bay fuse block with the cover off?
I wonder if Ol' Rusty has the 96 EWD!
@ TheDurk
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
11-22-2016, 10:38 PM
Bump
01 4Runner Limited
3" Toytec lift with bilstein 5100 - 861 coils - Cooper ST MAXX - Savage bumpers - aux trans cooler - koyo rad - Tundra brake upgrade - "attic" interior cargo shelf
11-22-2016, 10:51 PM
@ TheDurk
Ol' Former Rusty....uhh Former Ol' Rusty....
I agree, I don't see how pulling the EFI would kill the lights.
OP, any evidence of an alarm system, either present or having been removed prior to your purchase?
OP, Next time they are stuck on, try pulling the TAIL relay instead of the EFI fuse.
My Backyard Frame Swap
11-25-2016, 01:31 PM
I read somewhere to do that and it worked to kill both the parking lights staying on and the ignition thinking key was in. I did find what I think is the issue though. Green wire going to tail fuse was burnt up bad! It hit a coupl other wires and broke through to them too. I'm actually swapping my entire fuse box harness just to isolate the burnt wires. I also found that my grommet on driver side firewall was pushed all the way in allowing water to get in I Beleive that's my water issue. Seems it is almost like 2 diff issues the parking lights and ignition and then the efi popping when it's wet.
11-25-2016, 01:46 PM
Sounds like you are on the right track. Good luck.
11-25-2016, 02:13 PM
Real Name: Ash
Real Name: Ash
Awesome PDF's
Sorry to thread jack but...
@ TheDurk
I'm in a '98 3.4 but where did you get such awesome PDF material pls?
1998 SR5 - 3.4/Auto/151k. Toytec, OME, Savage Off-road, Addicted Off-road, 4Crawler, Spidertrax, TBU, ePCK, B&M, ViAir, '00 grill/headlights, Firestone MT, CB mod, RB mod.
11-25-2016, 07:11 PM
Only evidence of some aftermarket shit is some vampire clips I found in a few wires under the dash and my new fuse box harness doesn't have them so not oem
11-25-2016, 07:24 PM
@ TheDurk
From members here that I have helped. They get them off TIS. $15 for a 2-day login.
