Old 11-25-2016, 06:14 PM #1
Jackthewack's Avatar
Jackthewack Jackthewack is offline
Jackthewack is on a distinguished road
Frame mounted shackle question
Ok so I removed the bottom plastic from my bumper and I have the ends of the frame sticking out. I am in the process of making my own shield for the radiator so don't worry about that haha. Any way my question is can I just cut some holes into the end caps of the frame to mount my shackles? I think it would look cool and be really easy to access. Thanks in advance
Frame mounted shackle question-img_20161125_161009-jpg  Frame mounted shackle question-img_20161107_180910-jpg
1998 sr5 4x4 auto
Jackthewack is offline   Reply With QuoteReply With Quote
Old 11-25-2016, 07:37 PM #2
GhostRing's Avatar
GhostRing GhostRing is online now
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
If I'm not mistaken, that end cap is held in by a little 12mm bolt. No go.
If you want real shackle recovery points, I suggest getting the bolt-on shackle
mounts that attach at the factory tow hook locations.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is online now   Reply With QuoteReply With Quote
Old 11-25-2016, 07:52 PM #3
I just looked and they are absolutely bolted on. why would they not be welded on?
1998 sr5 4x4 auto
Old 11-25-2016, 08:14 PM #4
Can I weld it on and then add the shackles? My buddy is a welder so I can get some great welds on it would there be any reason to not weld them on?
1998 sr5 4x4 auto
Old 11-25-2016, 09:14 PM #5
Black798's Avatar
Black798 Black798 is offline
Real Name: Phoenix
Black798 is just really nice Black798 is just really nice Black798 is just really nice Black798 is just really nice
Black798's Avatar
Real Name: Phoenix
I still wouldn't recommend using that as a shackle mount even if it was welded. There are a couple problems I see with doing it that way.
1) those end caps are made to be crush boxes if you're in an accident so they are designed to be the first link to fail and they are only made from 1/16th inch steel.
2)Even if they were welded, they are a butt joint and have a very little contact patch that is being welded. They will be relying entirely on that weld, no matter how good the weld is I wouldn't trust it. The proper way to do it would be to brace further back into the frame so your welds have better load distribution.
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
Black798 is offline   Reply With QuoteReply With Quote
Old 11-25-2016, 09:34 PM #6
IsaiahC's Avatar
IsaiahC IsaiahC is offline
IsaiahC is on a distinguished road
IsaiahC's Avatar
You're better off buying the bolt-on mounts that go where the tow hook is. That or make your own. Only other thing would be to drill holes then plate the frame around that.
'96 4runner Limited - Automatic 4wd with factory E-locker - LT265/75r16 BF Goodrich KO2's - Toytech/Eibach front coils and LC 8 wraps with Bilstein 5100s all around - SPC UCAs - AOR Plate Front Bumper - 4xinnovations Rear Swingout Bumper - HD-SKO Sliders
IsaiahC is offline   Reply With QuoteReply With Quote
Old 11-27-2016, 12:08 AM #7
Thanks guys. I guess I'll just leave them. I thought it would look cool though
1998 sr5 4x4 auto
frame mounted hitch??...Toyota/Lexus?? drnick 5th gen T4Rs 95 11-07-2017 10:59 AM
5th Gen, Frame Mounted Hitch Receiver? Michael Siener 5th gen T4Rs 14 07-04-2016 08:29 PM
Bolt for 2 inch Receiver Mounted D-Ring Shackle Batang.Gapo General Discussions 2 07-12-2015 09:27 PM
Frame Mounted Side Steps Jamobi 5th gen T4Rs 5 11-03-2014 01:51 PM
Frame Mounted Heavy Duty Bull Bar (Looking - Please Help!) BamaDrewski 3rd gen T4Rs 8 03-27-2013 11:41 AM
