Old 06-03-2020, 03:21 PM #76
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
Door Trim
I (re)added some black trim to the doors. When I purchased the truck it had these installed but I initially removed them. Unfortunately the paint underneath suffered. After a few years of looking at the artifacts of the old trim I decided it is better to have it on and cover the damaged paint. It may not be the cleanest look but I actually do not mind it. There is some practical use too as it will protect the doors to some degree.
I had to find a flat black universal product and cut it to fit. Took a few attempts to get a result I was happy with.
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 03:24 PM #77
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Hood/Fender adjustment
The front driver fender and hoodline have always been slightly misaligned. I took some time to mess with it and was able to raise the fender to match the door line and also close the hood gap. It is not 100% perfect but it is much improved.
Full Skid Plates
Old 06-03-2020, 05:24 PM #78
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Man you have done some nice work to the 3rd gen. What next on your list?
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 07:15 AM #79
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Thanks! Next project on the list is to finish the sleeping/storage platform that I started. After that I just want to get out and use it.
At first I wanted to go all-out with bumpers and gear but I think the "OEM-plus" look is more fitting to how I use it. Farther in the future I would like to get a rear locker and move to the 4:30 gears. That should be good to run 285's when paired with the 5-speed.
Full Skid Plates
Old 06-04-2020, 11:24 AM #80
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
One thing I left out. I spent more time than Id like to admit trying to locate a 2000 driver side mirror in Desert Dune. This was difficult because the mirror was redesigned in '99, heated glass was added in '00 and this was also the last year for the Desert Dune color. A "rare" 1-year mirror for all you nerds for detail out there!
So it took a while to find the right configuration in good condition but my mirrors actually match now.
Full Skid Plates
Old 05-10-2021, 08:22 PM #81
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
time for what is apparently a ~yearly update.
Just some pictures of a 4Runner doing 4Runner stuff. One instance where being pretty compact helped out.
Beer down by the river
Full Skid Plates
Old 05-10-2021, 08:30 PM #82
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Not really proud of my work here but I got my platform "done". I am not a woodworker but I have ideas for what I can do better with a V2 someday. Didn't help that the wood I used ended up being very warped. I also used those 2x6 boards because I was planning to make drawers. Once it was clear the quality was not what I dreamed up I scratched that plan for now. I will just use some plastic bins.
I have two compartments right behind the back seat that flip up and the side lids of course. Tied down with turnbuckles. The front edge is cut at an angle that matches the angle of the rear seat backrest to maximize space. A second piece attaches to form a sleeping platform with the rear seats flipped up. It is held on with two hasps normally used for a gate. Probably the only innovative thing I did here. Cant have things moving around or act as a projectile in the event of an accident.
Full Skid Plates
Old 05-10-2021, 08:33 PM #83
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Recovery points
Got some proper recovery points and shackles for the front. Also got a Factor 55 Hitchlink for the rear just to get some basic recovery gear on board.
Full Skid Plates
Old 05-10-2021, 08:37 PM #84
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Interior lighting again
This must be the 3rd time I have done this but after messing with colors and whatnot I just went with the tried and true white LEDs. Should have done it from the start as there are basically no hotspots and it works well with the colored overlays used for the climate and other areas. Brightness is cranked just for the picture. I left some orange LEDs where hot spots were not an issue.
Full Skid Plates
Old 05-10-2021, 08:50 PM #85
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Exterior lighting
Remade my little license plate light bar and swapped out the cheap pods for two Diode Dynamics Stage Series 6" light bars to act as fog lights. These are the SAE fog lens and I am very pleased. They are fun off road but honestly this was my solution for rainy weather night driving (a rare occurrence anyway) where the stock headlights fall on their face. Rather than doing retrofits.
If anyone has light bar to stock bumper mounting recommendations I am open.
I had ditch light brackets with no lights for around 8 months... Finally put on some Diode Dynamics Pro pod lights in the flood pattern.
Made my own harnesses. Just a glimpse of them here but this is cathartic and satisfying work if you invest in some decent tools. Everything is hooked up to an auxiliary fuse block under the hood. Standard stuff there.
Updated my switches accordingly. The green is left over from my first LED interior swap but oh well. Not worth buying new switches just for the color at the moment.
Full Skid Plates
Old 05-11-2021, 01:23 PM #86
JZiggy's Avatar
JZiggy JZiggy is online now
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
@raKnizek Nice build thread buddy!
I am planning a very similar lift to what you did back in 2017. My current ride height is basically the same as yours pre-lift and I'm shooting for the same (or slightly less) height than you gained with your lift.
I'll be using a Dobinsons kit with IMS shocks and JBA UCAs + PCK of course. Just wanted to query you on a few things:
- How did the ride quality change after the lift?
- Are you happy with the JBAs? What caster did you dial in when aligned?
- Why are the front control arm bumpstop extensions necessary?
- Would you do anything different if you had to do it over again?
Thanks!
JZiggy is online now   Reply With QuoteReply With Quote
Old 05-11-2021, 07:55 PM #87
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Thanks!
Thank you!
Interested to see what you think of the Dobinsons. I see the brand mentioned a lot recently. Maybe they will become the new bread and butter recommendation for 3rd gens?
The ride is undoubtedly more firm after lifting. But remember most people, myself included, are comparing old worn out suspension with brand new stuff and unless you're the original owner, or have driven one with new stock suspension, it may not be the most genuine comparison. That being said the ride feels more refined and the shocks take the edge off bumps much better. The body is very well controlled over bumps (with stock sway bars and extended links) despite being taller. It almost feels sporty in its own way. But you will feel that extra height during higher speed turns as it leans in with a notable (but predictable) delay relative to the steering input.
Tires made almost as big of a difference in my opinion. I tried load E General grabbers and it was too rough for me. Even with the new suspension. Moving to a load C helped solve that. But every tire will be different. Adding to that, mud terrain tires made my steering a bit more vague and it has a different response than with the all terrains (or highway tires).
JBAs are great. I replaced the bushings after not many miles but I did not grease them as much as I should have. And the bushings have been redesigned since then with channels to allow for better grease distribution. I have felt that they have allowed for the travel my coil-overs have. Owner and customer service have been excellent too. I even got an email reminder to grease the bushings based on when I purchased them.
I do not believe those front bump stop spacers were needed. I just did not know at the time and have since removed them. I should probably get the front DuroBumps to match the rear.
I don't think there is anything major I would do differently. Maybe get the rear DuroBumps from the start. The stock ones are just super hard. Other than that maybe I would just go for a 2.5 rear. More to future-proof rather than outright necessity. I would love to try other setups, too.
Full Skid Plates
Old 05-11-2021, 09:03 PM #88
JZiggy's Avatar
JZiggy's Avatar
Originally Posted by raKnizek View Post
Thank you!
Yes I have seen a lot of feedback that Dobs shocks provide a comfortable ride... we'll see I guess. Right now I have stock 99 springs with 4600s and airbags in the back. It rides a little stiff but it's not too bad. Does not soak up big bumps well... honestly our little 2000 CRV does a much better job at that!
Thanks for the feedback. How much did you have to extend your swaybar links with that level of lift?
Old 05-12-2021, 06:52 PM #89
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
You may want to double check me on this but I am pretty sure I used 3rd gen rear links up front and 2nd gen front links in the rear. It is some confusing combo like that but it is a relatively common change to get a little extra length. Should be able to confirm that with a search.
I also dug up my alignment sheet. I believe this is my most recent one. Camber is 2.7 degrees right and 3.1 left. Specified range is 2.3-3.8, so all good!
Full Skid Plates
Old 10-22-2021, 05:52 PM #90
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Gas tank skid plate
Finally got myself Lil Skip's gas tank skid. This thing is well made and beefy. Fits right at home with the front and center skids already on the truck.
I also repurposed my old LED pods as reverse lights and put them on an independent circuit. I felt a little bad about cutting the dash to install the 3-switch bracket but it turned out nice and fits in well I think.
Full Skid Plates
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
Maintenance Must Do's? 2000 t4r TheArkMaster 3rd gen T4Rs 16 09-27-2016 11:43 AM
Time for Maintenance/Mods 2000 2wd 4Runner Patrick1991 3rd gen T4Rs 8 08-27-2015 10:52 PM
2000 4runner 120k maintenance cash Maintenance/Detailing 3 12-05-2010 05:50 PM
Used 2000 4Runner Limited Maintenance? warr0088 3rd gen T4Rs 4 01-27-2008 11:51 PM
