Re-Routing Trans Cooler Lines In Line With Rad Cooler Questions
I have a slight leak at my out flow barb on my B&M 70264, I think it's just a loose hose clamp there. I installed this trans cooler in 01/2015 at 152,336 mileage, bypassing my brand new radiator's trans cooling feature. This minor leak brings up the perfect time to re-route my lines and incorporate the radiator cooling portion in line with the B&M cooler, rather than bypassing. Not the place to discuss pros/cons of this method.
I noticed just now that the caps that were capping off the barbs on the radiator's portion of the trans cooler, are no longer attached and missing. I can 100% confirm they were in fact attached and in place, (albeit a bit cracked looking), on 11/5/2016 at 164560 mileage, when I drained the radiator to install a new thermostat and hoses.
Question: what would be the best way to "clean" out the radiator's portion of the trans cooler since it's been exposed to the elements etc. for a month and ~ 1,500 miles? I'm thinking hook up a garden hose and flush out the trans cooler portion, followed by excessive air drying and air compressor "blowings".
Regardless of pros/cons of running my trans cooler in line with my rad, am I opening a can of worms by potentially introducing foreign objects into my trans fluid because I didn't flush it properly?
2000 4Runner SR5 Sport
1998 Lexus LX470
