Old 12-30-2016, 11:49 AM #16
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
Originally Posted by mountainbiker42 View Post
I've always liked the way the amber day time running lights look on the newer toyotas. After weeks of planning it out in my head I pulled the trigger on x2 Oznium LED bolts. I'm more than thrilled with how they turned out. I wish i had done this a long time ago.
I found a blank fuse spot under the dash that was switched on key power. I installed an add a fuse and ran the wires up front.
I am just curious how it looks at night?
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 07:22 PM #17
mountainbiker42's Avatar
mountainbiker42 mountainbiker42 is offline
mountainbiker42 will become famous soon enough
It looks really cool. Especially with my amber side markers on along with these LEDs. My jeep friend is even impressed
2020 TRD Premium. Dobinson IMS 1.5”. 265/70 KO2’s. RCI full length aluminum. RCI sliders. LFD crossbars.
mountainbiker42 is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 07:43 PM #18
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
Anyone know if these could be tied into the turn signal lamps so that they blink with the turn signals? While they certainly look cool just lit up — I would want extra functionality with them if possible...cause other drivers are idiots of course, and anything I can do to help prevent them from running into me is a good thing.
I'm curious if combining LEDs and normal bulbs on the same circuit is OK. Wouldn't the normal bulb provide enough resistance to prevent the LED hyper flash too?
"Variety is for your mind, not your body " —OS
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 01-16-2017, 12:02 AM #19
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
We done OP, I like the look a lot. I found these http://a.co/gVDAges on Amazon. How did you wire yours in, turn on with the markers?
I suspect yes, you can wire them on with your markers and inline to flash with your turn signals using a pair of relays in series. I like the idea I might try it.
In my experience, LEDs draw so little voltage that combining them would probably be best. If using LEDs in lieu of standard bulbs you'd probably want to add a resistor.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 01-16-2017, 12:09 AM #20
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
If anyone is interested in brighter corners, my 7443 retrofitted corners are for sale. Built using 100% OEM parts(aside from LED).
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 01-21-2017, 03:46 PM #21
Following the OPs lead, I ordered two of these Ozmium LEDs from Amazon and will install them this weekend.
I am thinking about placing them INSIDE my headlamp, upper inside corner on the flat/wavy triangle behind the glass.
Regardless where I install them, I will probably wire them to turn ON with the marker lights.
I might use the filler panel below the headlamp for an LED turn signal/DRL combo possibly using something like this -> http://a.co/4kxcV7I
White LED DRL and flashing Amber when turn signal is on (3-wire connection)
Old 03-22-2017, 02:18 AM #22
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Just came across this question... you should be able to (1) IF you have conventional incandescent bulb for your turn signal (i.e., 26-watt 1156's), and (2) IF your turn signal is switched positive (which most signal lights are).
Wire this way:
1) Positive side Oznium Bolt LED light to positive of marker light circuit.
2) Negative side of the Oznium LED to positive of TURN SIGNAL that side.
The added Oznium LEDs will blink alternately with the stock turn signals.
Similar to how I wired my first-gen:
Mine in action:
https://youtu.be/ad4Ga8nNQug
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 03-22-2017, 04:11 AM #23
Real Name: Woody
Real Name: Woody
Wire this way:
Mine in action:
I like this! In your video I like how the lights alternate. Also I hadn't thought of a low mounted rear blinker like that either. Kinda like that too.
Old 03-22-2017, 04:52 AM #24
RAD4Runner's Avatar
RAD4Runner's Avatar
Should be a piece of cake. Just need to verify your turn signal wiring / color code / wire Identification. Also...
NOTE: For best/guaranteed results, use LED lights for the marker/clearance/parking lights and conventional incandescent bulb (OR LED with resistor in parallel) for stock turn signal.
Low-mounted is basically same as the rear side markers on 80's cars and the FJ80, but wired to blink alternately with stock turn signals.
Someday, I'll wire up the front corner clearance lights to also blink at same time as the fender-mounted one. Should be a half-hour job.
How it works explained here.
Old 10-14-2020, 11:52 PM #25
Radski07 Radski07 is offline
Radski07 is on a distinguished road
LEDs spliced to side markers now halogens won't work.
Sorry y'all don't really understand how this posting a question things works but this thread is as close as I could find to post in, #newb #jerry but anyway i wanted to add some LED lights in sequence with my side markers/running lights so i spliced in wires and then ran those to some amber LED's I got from eBay the LED's turned on with my headlights and work as the side markers lights would. But now the halogen lights that are in the side markers won't come on. Before I wired the LED's in the halogens were working as they should even with the new wires spliced in. Any help is much appreciated just trying to have both lights work I'll post some photos for reference tomorrow.
Radski07 is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 01:57 AM #26
RAD4Runner's Avatar
RAD4Runner's Avatar
OOPS, sorry, replied to wrong thread
Good excuse to say HOWDY, anyway
Old 10-15-2020, 08:29 AM #27
What year and model vehicle?
Sent from my Pixel 4 XL using Tapatalk
Old 10-16-2020, 02:31 AM #28
1999 toyota 4runner sr5 any help is much appreciated I hope someone has the answer
Old 10-16-2020, 11:25 AM #29
datsuyama datsuyama is offline
datsuyama is on a distinguished road
Looks good!
I think I'm going to have to order some of these! Thanks for sharing.
datsuyama is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 11:43 AM #30
Show your wiring, splice work
amber , daytime running lights , led
Daytime running lights? halloran 3rd gen T4Rs 2 09-04-2016 10:45 PM
Daytime Running Lights Cobalt Anubis 5th gen T4Rs 3 12-24-2015 10:51 AM
I want daytime running lights Alpacamarc 3rd gen T4Rs 20 04-19-2010 01:02 PM
06 daytime running lights bobbyavidity 4th Gen T4Rs 6 08-08-2008 04:28 PM
daytime running lights Dreamw0rkz Problems & Warranty Issues 3 06-28-2007 11:57 PM
