Old 10-16-2020, 07:22 PM #31
mountainbiker42's Avatar
mountainbiker42 mountainbiker42 is offline
mountainbiker42 will become famous soon enough
Did you wire them in as a series or parallel circuit?
I’d have to break out my old school text books for a refresher on OHMs law and basic electrical theory but it is possible the LED’s are drawing just enough to prevent the halogens from lighting. Electricity would still be flowing through the element in the bulb, but there may not be enough current to light it up.
This is just off the top of my head.
When I wired up mine (I’m the original poster), I ran them off a switched power source that was controlled by the ignition. The LED circuit was separate from everything else.
2020 TRD Premium. Dobinson IMS 1.5”. 265/70 KO2’s. RCI full length aluminum. RCI sliders. LFD crossbars.
mountainbiker42 is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 07:53 PM #32
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Not likely.
If it had been a canbus vehicle that may have been a possibility.
I wired several things off my marker circuits but used relays to power them.
Notwithstanding a wiring error, you'd need a multimeter to check voltage and continuity to diagnose properly vs just guessing.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 09:59 PM #33
Yes, we are just guessing. Get out a multimeter and start checking voltages and show us exactly how you wired it up
Old 10-17-2020, 01:14 AM #34
Radski07 Radski07 is offline
Radski07 is on a distinguished road
Originally Posted by octanejunkie View Post
Show your wiring, splice work
Pretty rudimentary wiring going on, the previous owner had accessory running lights wired into the side marker bulb clip. So All I did was undo their shitty work and do the same thing and by same thing all I did was run a positive and a negative off the two wires going to the bulb clip, just with better wiring techniques. When I was done wiring turned them on, checked to see if I had voltage and light and I did so I thought all was Bueno. Fast forward got new lights amber LED's off eBay. Wired them up to the positive and negative and sure enough turned on headlights and they came on working just as the side markers are supposed too. But now the side marker bulbs don't light up. So too put it simple after running new wires off the side markers and running new lights,the new lights work but original side markers don't why? I'll get around to posting photos of the rig but the wiring is nothing special just waterproof butt splices from old wires to new wires.
Radski07 is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 01:23 PM #35
Use a good body ground for negative rather than the negative in the harness; those are often switched.
amber , daytime running lights , led
Daytime running lights? halloran 3rd gen T4Rs 2 09-04-2016 10:45 PM
Daytime Running Lights Cobalt Anubis 5th gen T4Rs 3 12-24-2015 10:51 AM
I want daytime running lights Alpacamarc 3rd gen T4Rs 20 04-19-2010 01:02 PM
06 daytime running lights bobbyavidity 4th Gen T4Rs 6 08-08-2008 04:28 PM
daytime running lights Dreamw0rkz Problems & Warranty Issues 3 06-28-2007 11:57 PM
