Old 12-08-2016, 01:38 PM #1
mountainbiker42's Avatar
mountainbiker42 mountainbiker42 is offline
mountainbiker42 will become famous soon enough
LED amber daytime running lights installed
I've always liked the way the amber day time running lights look on the newer toyotas. After weeks of planning it out in my head I pulled the trigger on x2 Oznium LED bolts. I'm more than thrilled with how they turned out. I wish i had done this a long time ago.
I found a blank fuse spot under the dash that was switched on key power. I installed an add a fuse and ran the wires up front.
LED amber daytime running lights installed-img_1522-jpg  LED amber daytime running lights installed-img_1521-jpg
2020 TRD Premium. Dobinson IMS 1.5”. 265/70 KO2’s. RCI full length aluminum. RCI sliders. LFD crossbars.
mountainbiker42 is offline   Reply With QuoteReply With Quote
Old 12-08-2016, 01:47 PM #2
MisterMo21 MisterMo21 is offline
MisterMo21 is on a distinguished road
Wow!!
That looks really great! Was it just a plug n play?
MisterMo21 is offline   Reply With QuoteReply With Quote
Old 12-08-2016, 03:12 PM #3
Pretty much. The LEDs are water tight with about a 2 foot harness on each (positive & negative wire). I bought the add-a-fuse at the parts store, ran the positive wire up front and grounded them on the body ground near the battery on the driver wheel well.
They're really bright
Old 12-08-2016, 03:21 PM #4
If you ever do a tutorial on this I would definitely be interested in learning how to do this!
Old 12-08-2016, 03:25 PM #5
t4r_rio's Avatar
t4r_rio t4r_rio is offline
Real Name: Austyn Rio
t4r_rio is on a distinguished road
t4r_rio's Avatar
Only if there was a way to get my corner lights that bright.
t4r_rio is offline   Reply With QuoteReply With Quote
Old 12-08-2016, 03:25 PM #6
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
What size did you use? And did you just drill through that little trim piece?
My Backyard Frame Swap
Old 12-08-2016, 03:32 PM #7
Not sure what size I used. But yeah I drilled a pilot hole then slowly went bigger till they fit. Be careful however drilling that thin peice. Its thin metal and my bit dug in and cought and bent the trim peice a little. I fixied it but it was extra time spent on the project.
Old 12-08-2016, 03:33 PM #8
Is there an amber LED replacement for the side markers to get them any brighter?
Old 12-08-2016, 03:36 PM #9
t4r_rio's Avatar
t4r_rio's Avatar
I have a 5 led amber in mine. Uses a 194 bulb but they are no where near that bright. They only can be seen when it's dark out
Old 12-29-2016, 03:07 PM #10
SP2PILOT SP2PILOT is offline
SP2PILOT is on a distinguished road
Is this the 1 watt or 3 watt LED?
SP2PILOT is offline   Reply With QuoteReply With Quote
Old 12-29-2016, 08:15 PM #11
They're 3 watt Oznium LEDs
Old 12-29-2016, 10:40 PM #12
MudMud MudMud is offline
MudMud is on a distinguished road
I like it!
MudMud is offline   Reply With QuoteReply With Quote
Old 12-29-2016, 11:38 PM #13
wake_rider's Avatar
wake_rider wake_rider is offline
Real Name: Michael
wake_rider is on a distinguished road
wake_rider's Avatar
Real Name: Michael
Just ordered a pair!
2000 Desert Dune Limited 4x4
wake_rider is offline   Reply With QuoteReply With Quote
Old 12-30-2016, 12:18 AM #14
spazzyone spazzyone is offline
spazzyone is on a distinguished road
Nicely done.
I thought about black vinyl covering my stock corners and adding 5 cool blue versions of the led's you got on each filler bar under the headlight so it could look something similar to this:
Side note, my intention isn't to make my 4runner look like a g-wagon. i just thought the daytime led bars they had looked good under the headlights. I saw it in person the other day and it made me think of it.
spazzyone is offline   Reply With QuoteReply With Quote
Old 12-30-2016, 01:40 AM #15
marcus clarkus's Avatar
marcus clarkus marcus clarkus is offline
marcus clarkus is on a distinguished road
Originally Posted by spazzyone View Post
Nicely done.
[IMG]http://static.cargurus.com/images/site/2012/05/01/17/09/2013_mercedes-benz_g-class-pic-4411333446140013257.png[IMG]
I wanted to see what this looks like and thought I'd share. (well, with 9 warm LEDs, not 5 cool ones)
I also tried to emulate the early 90's Land Cruiser but it looks more like a F-150 from that era
...I'm not really a fan of either, oh well
OP - nice work. I like it
1999 Toyota 4Runner SR5 V6 4x4 5spd - 317k miles as of Feb 2024
3D Printed SR5 Mudflaps
FS: 3D Printed Outlet Covers - Convert rear ashtray to 12V/USB outlets
marcus clarkus is offline   Reply With QuoteReply With Quote
amber , daytime running lights , led
Daytime running lights? halloran 3rd gen T4Rs 2 09-04-2016 10:45 PM
Daytime Running Lights Cobalt Anubis 5th gen T4Rs 3 12-24-2015 10:51 AM
I want daytime running lights Alpacamarc 3rd gen T4Rs 20 04-19-2010 01:02 PM
06 daytime running lights bobbyavidity 4th Gen T4Rs 6 08-08-2008 04:28 PM
daytime running lights Dreamw0rkz Problems & Warranty Issues 3 06-28-2007 11:57 PM
