sportscarfan
I would be very curious to hear how you got the window up in the bush - as I've often wondered about how to get that up. Sounds like you found a way to power the motor and unplugged it to kill it, as you said.
As soon as the rig starts, the window drops. But each time I do it, the idle and the difficulty starting is getting worse.
I'll look for this in the daylight tomorrow, thanks for the suggestion!
EDIT: IT WORKED.
Wow, I'm impressed. Thank you,
sportscarfan
! Everything is back to normal! I was wanting to fix this so I got out there tonight and took it all apart. Took some finangaling to get at the connector and get it apart, but now it is working better, just by taking the grey plug apart.
Do you think this is a bad wire or such? I would like to keep the tailgate functionality if possible - perhaps I can look into replacing it.
#7 on the parts diagram - associated with the lock cylinder...
https://parts.camelbacktoyota.com/pa...iagram=8414555
~$95. #6905535070 for the rear door lock cylinder and sensor wire. Not sure if the issue is with the wire itself, or the lock cylinder messed up...
1998 T4R SR5 Natural White 4WD 5VZ-FE-V6-3.4L / ARB / Subaru-Hilux Gauge Pack / 199mm TBU / BFG All-Terrain KO2 265/70/R16
Build Thread.
T4R & adventure photolog.
