Old 12-17-2016, 11:59 PM #1
antexity's Avatar
antexity antexity is offline
Real Name: Jonathan
antexity is on a distinguished road
antexity's Avatar
Real Name: Jonathan
Order of replacement - front end components
Have on order the following:
1) LBJ
2) Sway End Links Bushings
3) Sway Bar Bushings
4) Outer and Inner Tie Rods
5) Steering Rack Bushings
Is there a specific order I should do these in so I don't make my life a miserable hell?
1999 Hilux Surf SSRX- Two Tone White/Bluish Met. Silver |50,000 Miles|
Dedicated Studded Winter 285/75/16 Duratracs, Unknown JAWA Rims?, JAOS Skid, Satoshi Mod, 3" Lift (TBD), Kenwood DPX U77 + Subwoofer
antexity is offline   Reply With QuoteReply With Quote
Old 12-18-2016, 02:25 AM #2
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
Not really...okay, maybe yes.
They're all fairly painless. Although, that's coming from my experience- on a rig with no rust. Obviously, rust will add some time and frustration.
A tie rod/BJ remover tool made my LBJ about as easy as it gets.
The steering rack bushings are much more easily done when the tie rods are off.
That being said, I would-
1) Pull the sway bar end link nuts off.
2) Remove sway bar from frame.
3) Brake the 4 LBJ 14mm bolts loose from the knuckle- but do not remove.
4) Remove LBJ from LCA.
5) Remove LBJ from knuckle.
6) Remove ITR from rack(no need to separate the inner and outer tie rod, or even take the outer tie rod off the old LBJ)
7) Remove rack bolts, replace bushings.
As always, assembly is reverse of removal.
Oh, and have fun with the sway bar bushings. The frame side is a pain in the ass, and so are the end links.
The rack bushings were at least twice as easy as the sway bar bushings for me.
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 12-18-2016, 11:40 PM #3
antexity's Avatar
Real Name: Jonathan
antexity's Avatar
Real Name: Jonathan
Thanks for the tips! I am assuming all of this can be done while jacked up?
Old 12-21-2016, 12:22 AM #4
OldManKamps's Avatar
OldManKamps OldManKamps is offline
OldManKamps is on a distinguished road
Yup! The sway bar removal really isn't that bad at all
You just need extensions on your ratchet. And remember, they're welded nuts! The bolt goes in through the top! I had a friend chisel off the nuts because he thought they were rusted on that tight Order of replacement - front end components
2000 SR5 4x4 Millenium Silver, 2" spacer lift from PO, 351,000 kilometers! Keeping her until at least 400k then maybe 4th gen!
OldManKamps is offline   Reply With QuoteReply With Quote
Old 12-21-2016, 09:43 AM #5
meRockboost meRockboost is offline
Real Name: Rock
meRockboost is on a distinguished road
Real Name: Rock
DO the lower control arm bushings and sleeves at the same time as your steering rack. Otherwise you will have to remove your rack again to remove the bolts for your LCA
2021 Nightshade (wifey’s). 1998 Limited-locked, lifted, armored, sold. 2015 SR5, stock and sold. 2002 Sport edition, sold.
meRockboost is offline   Reply With QuoteReply With Quote
FS: 3rd Gen Front bumper components (new $250); OEM jack kit (used $100) - NE MS pendragon For Sale: T4R Items 0 07-11-2016 10:29 PM
WTB: OME front lift components!! (Spacers, 881, 883, shocks) arbeendk For Sale: Suspension/Wheels/Tires 0 06-14-2014 05:52 PM
WTB: 4th gen front end suspension lift components 03 T4R Limited Want to Buy/Trade 0 07-24-2013 01:26 PM
Fog lights, Turn Signals, Front Bumper Components F/S Desert Cowboy For Sale: T4R Items 0 11-07-2011 05:40 PM
How to order a replacement owner's manual Bust 4th Gen T4Rs 6 01-17-2006 09:31 PM
