Old 12-18-2016, 01:26 PM #1
T4Rfirefighter T4Rfirefighter is offline
T4Rfirefighter is on a distinguished road
ABS/VSC TRAC/Brake Lights and Audible Alarm
For the 3 years I've owned my 2001, I've had my ABS/VSC TRAC/brake lights and an audible alarm come on intermittently when the temperature gets down below 40 or so. This year, it has gotten worse and for the last few days, it has just stayed on constantly, even when it warms up.
I've searched and searched and searched and have come away with more questions than answers. I have pulled all 4 ABS sensors and cleaned them to ensure that wasn't the issue. I don't want to just throw money at parts and hope that does the trick, so how do I diagnose this?
2001 T4R SR5 - King 2.5" Coilovers, OME 890, 1" ToyTec BL, 285 Duratracs, CBI Hybrid, Warn M8000
T4Rfirefighter is offline   Reply With QuoteReply With Quote
Old 12-18-2016, 03:00 PM #2
ltsr's Avatar
ltsr ltsr is offline
ltsr is on a distinguished road
ltsr's Avatar
Even though you might not have a visible check engine light you should check for codes. Have you don't this? If so what were your findings?
ltsr is offline   Reply With QuoteReply With Quote
Old 12-18-2016, 08:13 PM #3
I'm at the fire station today, but I will put my reader on it tomorrow and see what I come up with.
Old 12-23-2016, 06:09 PM #4
My reader did not show any codes, but I do not have a check engine light on either. Do I need a different code reader that may show more codes than mine does?
Old 12-23-2016, 06:19 PM #5
ltsr's Avatar
ltsr's Avatar
I can't answer that question for sure. My reader has the option "stored codes" which shows codes that don't make the check engine light illuminate.
Some light reading if you haven't already:
Brake, VSC OFF, VSC TRAC, ABS lights on
TRAC OFF, VSC TRAC, ABS lights on - YotaTech Forums
Old 12-23-2016, 06:42 PM #6
My reader shows no pending or stored codes.
I don't want to just start replacing ABS sensors, and I really don't want to replace the master cylinder and ABS motor without verifying it is bad.
Old 12-23-2016, 06:59 PM #7
ltsr's Avatar
ltsr's Avatar
I agree with you. The links I sent has some information about trying other things and diagnostics approach that doesn't include spending tons of money and randomly replacing expensive sensors and parts.
Old 12-24-2016, 12:12 AM #8
beliboy32 beliboy32 is offline
beliboy32 is on a distinguished road
this happened to me as well i figured it was because my battery was dead and maybe i boosted it all wrong. Anyways later after about 25-30 minutes of driving, because i didnt want to shut it off without giving the dead battery a charge, it all went away it seemed once it warmed up it was fine..... the other variable was the new battery.
Once its cold like that again ill report back.
beliboy32 is offline   Reply With QuoteReply With Quote
Old 12-24-2016, 12:17 AM #9
dwgrahn dwgrahn is offline
Real Name: Derek
dwgrahn is on a distinguished road
Real Name: Derek
Had the same on my '01 SR5. I kept driving and eventually it died on me. I replaced the alternator and it fixed it, but I later found bad grounds. I did the big 3 upgrade and it has been peachy ever since.
dwgrahn is offline   Reply With QuoteReply With Quote
Old 12-27-2016, 12:10 AM #10
I've done the Big 3 with 2/0 and 2 AWG welding leads, plus a Group 31 AGM battery that is less than a year old, so I don't think that's my issue.
I removed the speaker that gives the audible alarm, so I can at least drive without getting a headache. I plan to do a zero point calibration at the fire station tomorrow and see what that does.
Old 10-29-2017, 10:15 PM #11
Wildbill81 Wildbill81 is offline
Wildbill81 is on a distinguished road
Ever find out what was wrong? Mine did the same thing this morning. Funny it was below 40 degrees too just like u said
Wildbill81 is offline   Reply With QuoteReply With Quote
Old 10-30-2017, 03:31 PM #12
deimen deimen is offline
deimen is on a distinguished road
Hey guys i had problem in 4 runner 2002.after i change HBB motor with pump. Brake started work perfect. Only one problem ligts is on and Firestone not can read ABS CODES. They say they not see ABS.
And not possible to do zero point calibration
My question.
What can be wrong?
Were is brain of ABS system?
ABS module (come with master silinder) or ABS TRAC VSC COMPUTER CONTROL MODULE (what is left side of driver.)
Thank you.
deimen is offline   Reply With QuoteReply With Quote
ABS, VSC Trac, and Brake idiot lights on, audible alarm. What gives? Kardolf 4th Gen T4Rs 5 09-11-2015 02:48 PM
VSC, ABS and brake lights on with audible alarm- Help gmccune13 4th Gen T4Rs 5 11-07-2014 07:09 PM
'check engine', 'trac off', and 'vsc' lights came on. Plus 'abs' and 'brake' lights thehadley4 3rd gen T4Rs 0 10-23-2011 01:51 PM
Is there an audible alarm on 07 T4R V-6 related to driving over a curb? jow 4th Gen T4Rs 4 06-03-2011 03:17 PM
VSC TRAC, TRAC OFF, ABS and BRAKE lights ENRIQUE Problems & Warranty Issues 3 02-03-2011 10:57 PM
