10-08-2006, 08:07 PM
Lift with ride quality?
I'm fairly new to TR4.org and I must say there is a lot of helpful information out here. I've been researching lifts for my '96 runner and it seems that all seem to stiffen up the ride quite a bit from stock. I was wondering if there's a lift out there that has a ride comparable or bettter (doubtful) than stock. I'm not looking for anything drastic just about 1.5-2.5" of lift. Anything between that range. My trucks mainly a pavement pounder but i'd like to start wheeling it when I get a chance and the lift wound be nice. I heard of the PP springs but people usually use them with bilsteins and I hear it's rougher than stock. Any help would be greatly appreciated. I know some of you may have tried out different lifts so may have some first hand experience on this subject. Thanks
'96 SR5 4x4, Tundra/OME Lift
Praise the lifted!
10-09-2006, 01:11 AM
I see I got 27 views but not a single reply? I search and I haven't found anything about this. Maybe no one has any input?
Praise the lifted!
10-09-2006, 04:09 AM
The tundra/LC lift is suppose to have great ride quality and even better offroad abilities..
I think any suspension setup will be better than the stock ride quality... Get the OME medium setup... You should be fine with that...
2005 T4R SE
10-09-2006, 10:02 AM
Super Moderator
Super Moderator
Cheapest 1" lift is the '99 coils but here's a site that offers a full package for 4Runners which isn't as harsh as the Bils.
http://www.sleeoffroad.com/products/...suspension.htm
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
10-09-2006, 10:15 AM
if your only going to do a 1" lift and your springs/shocks are good to go, get a 1" body lift for around $80 and call it a day. you could also just get a spacer lift, like 2.5" for around 250 and ride like that until you decide if you want to spend $7-900 for some new springs and shocks.
my .02
shaun
99 limited millineum silver
TJM-17 with sonoran steel shackle hangers andknock off hella-500 lights from pepboys!
Satoshi mod
locker wire mod
fog light rewire mod
cobra 19ultra III with wilson tunable antenna and firestik hatch mount
trail gear sliders
jensen 9510 / basslink sub
pics
http://yotatech.com/showthread.php?t=96117
10-09-2006, 04:47 PM
my .02
shaun
you should be aware though that the BL will require a steering extension, and may mess with where your radiator sits, and you have to watch your fan touching the fan shroud.
plus there will be a gap btwn the body and the front bumper.
2006 4Runner Sport 4wd
XREAS
JVC kw-nx7000 head unit
10-09-2006, 06:45 PM
Where can I get an OME medium setup? Is there more than one source that you guys know of? Also Has anyone tried the PP Springs with tokico trekmasters or TRD Double cab struts?
Praise the lifted!
10-10-2006, 11:54 AM
Call the guys at Toytec. www.toyteclifts.com
Awesome service and great choices in lifts. I have the 3" OME with the drop diff.
2017 4Runner TRD Pro
10-10-2006, 01:21 PM
Well it looks like I've narrowed down my search to either the pp springs or going with a setup similar to the SS #7 kit but with the tacoma TRD DC shocks in the front and N906 coils with N86C shocks in the rear. I heard that if you don't used the top out spacer up front that you only get about 2" of lift and the N906 coils in the rear will give me about the same. Does anyone has this setup and ca verifiy what I've heard about using the spacers?
Praise the lifted!
10-10-2006, 02:13 PM
I'm not sure which kit is SS#7. The spacers I have on the front of my 4Runner are there to level out the front and rear with the 3" coils. They really aren't that much of a spacer, I'll find a pic and post it up. As far as ride quality with my kit, I really can't tell a difference, very pleased.
10-10-2006, 03:11 PM
Kit #7 is a 2.25" lift up front and a 2.5" lift in the rear. I was actually hoping to down size this a little to 2" all around with the changes to the kit I stated above. I'm not looking for a big lift. I was leaning towards the pp springs but I hear the Ome/tundra trd setup will likely better be a better ride.
Praise the lifted!
10-10-2006, 03:14 PM
Super Moderator
Super Moderator
The Tundra lift will hurt the budget more so do some research.
2010 Lexus RX350
10-10-2006, 08:35 PM
If i get the pp spring with some medium duty ome rear n86c shocks and taco trd shocks upfront will i need anything else besides a diff drop? I'm told i'll need a panhard drop bar, ebrake bracket, entended brake line(s) in addition to the diff drop. If I got the tundra setup a top spacer to get the full 2" lift.
Praise the lifted!
10-11-2006, 01:21 AM
I have a 1998 SR5 T4R 4x4 with a few good suspension mods. Pro-Comp struts up front, +2" Pro-Comp ES3000 shocks in the rear. The lift consists of a Day Star 2.5" polyurethatne kit. The ride is extremely smooth, almost as good as stock. I'm not sure of the long term ride of the Pro-Comp materials though. It does wallow/squirm a touch over bumps due to the stock length panhard bar. This is negligable, but still nolticable if the driver *really* knows what to look for.
Vince VanBenthuysen
1984 T4R SR5
1998 T4R SR5
10-11-2006, 01:26 AM
Postal Script: The total cost for the struts, shocks, spacer kit, and non-hydralic coilspring compressor was a total of $470 dollars from 4wheel parts and acessories. I was able to install the components myself with the help of an impact wrench, a six pack of Natural Light, and a pack of cigarettes by myself in a little less than four hours.
Vince VanBenthuysen
1984 T4R SR5
1998 T4R SR5
