Old 12-22-2016, 12:47 PM #1
JRivero's Avatar
JRivero JRivero is offline
Real Name: John Rivero
JRivero is on a distinguished road
JRivero's Avatar
My New Project 4Runner Limited + 1UZ
Hello, I just bought a motor to swap, the engine is a 1UZFE (1st gen), and I will install it in my 4Runner Limited 3.4 V6
From Copiapo, Atacama - Chile
I am creating this topic so that you can help me with opinions about this new proyect.
My 4R
My New Engine
My New Trans
Toyota 4Runner 1999 Limited Edition
Toytec Lift 3" / Eibach Springs / Bilstein 5100 Shocks / Body Lift 2" DIY / Wheel Spacers 1.5" / Flowmaster Super 40 / Fender Flares Sport / Custom Bumper / Headlight Proyector DIY
JRivero is offline   Reply With QuoteReply With Quote
Old 12-22-2016, 01:25 PM #2
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
If you know your way around wiring, reading wire schematics, and fluent in metal fabrication- you should be able to get it done.
If not, you may be over your head.
In for seeing cool swap progress My New Project 4Runner Limited + 1UZ
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 12-22-2016, 02:24 PM #3
jstim's Avatar
jstim jstim is offline
Real Name: Josh
jstim is on a distinguished road
jstim's Avatar
Real Name: Josh
@Singtoe already has a huge documented thread on this, use it to your advantage.
1999 Toyota 4Runner SR5 - Icon CDCV 2.5's, SCS Matte Black SR8 wheels, Audio overhaul (Alpine CDE-HD149BT, Kicker CS65s up front and CS5s in back
My build thread:http://www.toyota-4runner.org/3rd-ge...ack-pearl.html
2015 Toyota 4Runner Trail Premium traded for 2015 Ford F-250 Super Duty
Originally Posted by StreetCreeper View Post
And you also tell him that right before Absalom smokes them on the trail—he skins them first and fashions their dirty lifeless hides into camp-hats to keep warm at nite...
jstim is offline   Reply With QuoteReply With Quote
Old 12-22-2016, 02:29 PM #4
Aznwolf118 Aznwolf118 is offline
Aznwolf118 is on a distinguished road
Good luck, some 1uz tips
-you can wire it up and by pass the trac and get it to run. Don't be afraid of that.
If your wiring skills are good, you can wire the trac motor that controls the butterfly, so that the butterfly acts as kill switch
Don't be worried about dialing in kick down cable until you have the motor running soild
If you plan to use the 1uz trans and convert to 4wd you need to change the output shaft and tail housing or buy the part from Marlin crawler which makes a pre runner adopter to use with out tearing into trans
There will be some clearance issues, body lift if you want to keep factory hood
Find yourself a set of 2uz log style exhaust manifolds. It will save you a ton of pain putting the motor in and pulling it. Might need to cut flange and clock it for clearance, you will definitely be pulling motor for this
Also there are slight difference between the sc400 and ls400 versions of the motor. Example is the oil filter mount, the sc400 is tighter to body and will provide more clearance also the sc400 air box is very close to the 4runners except the air duct opening is In front instead of off to the side and into the fender we'll like the 4runners. The air boxes use the same filter tho
Also if you have motor in transitional year late 94 early 95. Be prepared for the wiring schematic not to match factory service manuals due to obd2 transition.
Get yourself a extra mass air flow.
2002 - trd s/c, header, exhaust, urd 7th...armored and expo set up
http://www.toyota-4runner.org/3rd-ge...ml#post2355344
1989 - 1UZ swap Cali Bar'd --SOLD--
http://www.toyota-4runner.org/classi...xperiment.html
Aznwolf118 is offline   Reply With QuoteReply With Quote
Old 12-23-2016, 09:00 PM #5
JRivero's Avatar
JRivero's Avatar
The harness is complete, no cuts or anything, but I need to know that transfer case is plug and play for my transmission AW 30-41LE
Old 01-08-2017, 06:47 PM #6
JRivero's Avatar
JRivero's Avatar
Progress
This week advance in the project, I completely removed the 5vz with the A340F, I will occupy the original transmission of the 1UZ (a341e) but I will install the output shaft of the original 4Runner (A340F) box, this week should have ready transmission Of the uz to present the engine and manufacture the supports to the chassis. Some photos
Old 01-08-2017, 09:41 PM #7
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Looks good.
Fellow member @alanflies did the same swap in 2014:
1UZ-FE swap 99 SR5... well here goes nothin!
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 01-08-2017, 09:54 PM #8
amalik amalik is offline
amalik is on a distinguished road
as did @Singtoe as mentioned.
it's a hell of a project. you would be the first one posting and doing it outside of the USA.
amalik is offline   Reply With QuoteReply With Quote
Old 01-08-2017, 10:32 PM #9
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Sub'd. I love these swaps!
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 01-11-2017, 10:28 PM #10
JRivero's Avatar
JRivero's Avatar
Cool 25%
Some advances today, my transmission is ready. A341 with output shaft of A340F (Original of my ex 5VZ engine + its original transfer), arrived the new Wheels with Tires and the Transmission was installed. Here are some pictures.
Old Output Shaft
New Output shaft
Transmission A341F Installed (Aisin 30-41)
My New Wheels and Tires
Old 01-11-2017, 11:34 PM #11
MandAtaco's Avatar
MandAtaco MandAtaco is offline
MandAtaco is on a distinguished road
MandAtaco's Avatar
Looking good!
Love these swaps!
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
MandAtaco is offline   Reply With QuoteReply With Quote
Old 01-11-2017, 11:56 PM #12
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
Nice progress. Looking forward to the rest.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 01-20-2017, 10:00 PM #13
JRivero's Avatar
JRivero's Avatar
Ser Hello, I had not had time to make more progress, but now I show you the progress of the project, the engine is already stated by its own means. I am waiting for the new Engine and Transmission Mounts, new Denso Radiator, Adapter for the Flowmeter and Led Watches, here some photos.
1uz , 3rd , 4runner , automatic , gen
txbonds 97 4runner limited project txbonds 3rd gen T4Rs 703 12-01-2017 08:12 PM
Fishing Monkey's 99 Limited Project fishing monkey 3rd gen T4Rs 13 04-11-2014 12:49 PM
2003 4Runner Limited JBL Upgrade Project jrlsail 4th Gen T4Rs 4 05-03-2012 01:47 PM
My Sunday project Sub replacement in my 08 Limited caj4au 4th Gen T4Rs 13 01-12-2012 08:26 PM
