12-25-2019, 11:16 AM
#301
I finally got time to bleed the rear brakes. Just a gravity bleed for now, but got plenty of air bubbles out of each wheel cylinder. Brakes feel even better now.
It appears the PO put new calipers and wheel cylinders on it but kept the old cracked front hoses. I need to look at the rear brake hose some time.
12-29-2019, 10:51 PM
#302
Real Name: Jeff
Real Name: Jeff
Cracked hoses scare me. Good thing you noticed. I like working brakes.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
12-29-2019, 11:15 PM
#303
Its such a night and day difference. Now I need to turn sharp right at parking lot speed and see if my ABS still activates.
01-18-2020, 01:31 PM
#304
Recently I’ve been seeing my Brake Warning Light coming on. I’m like WTF?
My MC level is at the low mark. So I look for leaks thinking a rear wheel cylinder is suspect and it ended up being a leak at the passenger upper brake hose connection.
I swear I made it tight, but I got a bunch of wrench turns on it before it was tight. There is no evidence of any air getting into the system and my pedal now feels like a rock.
Oops!!!!
01-18-2020, 02:08 PM
#305
Real Name: Jon
Real Name: Jon
Oops!!!!
You found it. That's all that matters. As we all boo boo from time to time.
02-28-2020, 05:50 PM
#306
This oil change I added Ceritec to the oil since I now have 10,000 miles on the new engine. At the same time I also drilled two 2” holes into the air box air filter cover to get warmer air into the engine to help atomize the fuel.
Before I was getting low to mid 18’s for mpg. The last 4 tanks I’ve been getting mid to upper 19’s for mpg. Was it the Ceritec or was it the warmer air. It’s still winter with morning drives to work in the low 20’s to upper 30’s and the drive home has been the mid 30’s to the 40’s.
I was worried about my 8psi of oil pressure at idle with hot oil. It makes me happy that I have the highest oil pressure of anyone that responded to my question on oil pressure at idle with hot oil.
Gene
04-16-2020, 10:56 AM
#307
My 1997 SR5 build and repair thread
My steering over the last few days has started to wander. Looking at the lower control arms while moving the steering wheel the drivers side arm moves visibly.
It’s time for lower control arm bushings.
04-16-2020, 11:12 AM
#309
Originally Posted by brillo_76
How many miles on your bushings?
281,000 miles. It’s time.
04-16-2020, 04:00 PM
#310
I couldn’t get the pivot bolts loose so I made an appointment with the guy I trust. Tuesday it will be done. I hope.......
I also hope John doesn’t get mad at me for having him do this.
04-24-2020, 05:30 PM
#311
So it took them a day and a half and I picked it up this afternoon. They sent it across the street to get an alignment before I picked it up.
So it was:
990 in labor
240 on OEM Toyota parts
69 for the wheel alignment.
Steve (owner) told me everyone is now deaf from hearing the impact all day Tuesday.
I’m glad I didn’t have to deal with it. It would have taken me much longer laying on my back on a creeper, and I would have only been able to start working on it today again with my off stretch starting again.
So that’s what I did with my stimulus check.
07-10-2020, 05:49 PM
#312
Well with 280,700 miles, this axle seal leak is expected. But I did clean the vent, if the leak comes back it’s seal time.
07-16-2020, 02:56 PM
#313
Bump to the top for @
08-25-2020, 05:50 PM
#314
Well, I pulled the drivers side read drum and still have a gear oil leak. So, I guess it’s time to do seals. It’s got 281,000 miles on the seals
I do want to get a new fill plug for the axle I’m at it. I pulled the fill plug hoping the previous owner overfilled the rear because that’s another cause for a leak. Sadly, the oil level is around 1/4” below the fill plug.
08-25-2020, 06:07 PM
#315
Real Name: Jeff
Real Name: Jeff
Bummer, but that job isn't too bad. Are you going to extend the rear diff breather?
Build
