Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 10-21-2020, 12:42 PM #391
My 1997 SR5 build and repair thread
Old 10-21-2020, 03:43 PM #392
The sleeve is welded in place and primed. I’ll do more work tomorrow.
I need to paint the frame, put new rear sway bar links on and replace the seals in the gas tank as well as the suction strainer.
I’m thinking next off stretch I’ll be driving it.
Old 10-22-2020, 05:38 PM #393
The frame is painted, new rear swaybar links. Dealing with the gas tank currently. Since the tank is on the floor I may as well replace the seals to eliminate the dreaded EVAP leak codes.
I start my work stretch tomorrow. So next time I’ll be able to work on it will be next Wednesday. Not much left to do. Just the tank sending unit gasket and start putting it together.
Old 10-22-2020, 07:31 PM #394
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tank wasnt too rusted. Mostly they look alot worse then that..;)
Old 10-28-2020, 05:30 PM #395
Today between a haircut I finished the gas tank. I’ll install it tomorrow.
What is this part of the sending unit?
Is it the low level switch? It has its own wire.
Old 10-29-2020, 07:50 PM #396
Yeah, that's how the '96-'98 low fuel light works. It is a thermistor that goes low resistance when it comes out of the fuel which lights the low fuel light. That gets you the cool slow-on-and-off of that low fuel light...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-30-2020, 04:45 PM #397
So it’s back on the road.
Best part is, the steering wheel is still as strait ahead as I remember it before.
I need to install the tank skid yet.
Old 10-30-2020, 08:00 PM #398
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
That's got to feel pretty good! Congratulations.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 09:21 PM #399
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Great job.
Old 11-26-2020, 09:09 PM #400
So my upcoming projects (if you all haven’t been following along) are replacing the 53mm Alt pulley with a 50mm one to speed up the Alt at idle to try and correct the automatics problem with being in gear idling at 600rpm and the battery discharging because the Alt can only push around 40a at 600rpm
Another project is installing a wiring harness for my headlights I got from Amazon.
Old 11-27-2020, 09:47 AM #401
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Upgrading the headlights are you? I cant say I blame you.
Old 11-27-2020, 11:09 AM #402
HiLife HiLife is offline
Interested in how your Amazon 40a wiring upgrade will work for you as I'm thinking to doing that too to improve my situation.
I ran a 55/100w bulb on my street bike for 8 yrs and loved it. Thinking/wanting to go this route for the rig.
Old 11-28-2020, 06:57 PM #403
So this evening I did the 50mm Alt pulley. I did not let the engine warm up to see what happens to the output.
I also installed the headlight harness. It works if I keep my factory fogs off.
I need to look into the fog light thing.
Old 11-28-2020, 09:03 PM #404
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Interesting as the fogs should be independent from your headlights. It's like the new harness is pulling a ground through your fogs then when you kill it its loosing the ground. Or a positive. I am suspecting a grand more the positive though.
Old 11-28-2020, 11:02 PM #405
The factory fogs are part of the lighting system. I wonder if the polarity is messing it up since I went from from a switched negative to a more common switched positive.
The coil resistance of the new harness could also be a problem. The factory setup used the bulb filament as part of the circuit to control the high beam indicator. I notice the high beam indicator is more dim than before. I’ll try an wrap my head around it in the next week or so. I’m keeping as it is and will deal with it as time goes bye. Worse case I will need to switch off the fogs when I switch to high beam.
1997 Build Thread amcnult1 3rd gen T4Rs 2 07-12-2014 10:04 AM
Bvrr0's 1997 sr5 build thread bvrr0 3rd gen T4Rs 19 03-06-2014 11:08 PM
Sleeper's blue smurf build/repair thread sleeper17 3rd gen T4Rs 55 05-11-2013 02:02 PM
Tye's '87 Runner Build and repair thread mytyeerinpie Classic T4Rs 84 06-24-2012 08:43 PM
repair/ build thread 95 4runner hondaracer11 Classic T4Rs 43 09-16-2011 12:33 PM
